Old 4th December 2024, 23:31   #1  |  Link
jay123210599
Shutter Encoder 709 Colors
Here is a sample of my video without any colorimetry flags:
https://www.mediafire.com/file/0r160...video.mkv/file
Now use Shutter Encoder make png files and/or an apng out of it. Do they have the 709 colors or the 601 ones? Did they have the gAMA and cHRM tag issues?
You can get Shutter Encoder here:
https://www.shutterencoder.com/
jay123210599 is offline   Reply With Quote
Old 4th December 2024, 23:58   #2  |  Link
Z2697
True.
Z2697 is offline   Reply With Quote
Old 5th December 2024, 00:35   #3  |  Link
Z2697
"C:\Users\a\Desktop\Shutter Encoder 18.6 Windows 64bits\Library\ffmpeg.exe" -strict -2 -hide_banner -threads 0  -i "C:\Users\a\Desktop\sample tagless video.mkv" -compression_level 0 -sws_flags bicubic -an -y "C:\Users\a\Desktop\sample tagless video_%06d.png"
go figure
Old 5th December 2024, 22:30   #4  |  Link
jay123210599
Maybe you'll wanna fix thread title typo.
(click EDIT button, then ADVANCED EDIT, on 1st post)
Fixed it
Old 5th December 2024, 23:29   #5  |  Link
jay123210599
go figure
What's this? What does the command mean? Did the PNGs and APNGs have the right colors? Do they have tag issues?
Old 9th December 2024, 14:08   #6  |  Link
Z2697
This is the command that Shutter Encoder uses when converting video to PNG image sequence.
Since it calls FFmpeg CLI tool the same "limitation" applies.
Old 9th December 2024, 15:27   #7  |  Link
jay123210599
So it would call the wrong colors and have tag issues for PNG and APNG?
Old 9th December 2024, 15:33   #8  |  Link
poisondeathray
No
To recap: for unflagged colorimetry input files, it uses Rec601 for the YUV=>RGB conversion. No PNG chunks written in that case.
See this thread (again)
http://forum.doom9.org/showthread.php?t=185921
I tested Shutter 18.6 - behaviour is the same as default ffmpeg . As you would expect for that command line. There is no other "logic" used in Shutter.
Old 9th December 2024, 16:33   #9  |  Link
jay123210599
Originally Posted by poisondeathray View Post
No
I added colorimetry flags using this command:
-map 0 -c copy -bsf:v h264_metadata=colour_primaries=1:transfer_characteristics=1:matrix_coefficients=1
It should produce the right colors, but will it have the tag issues?
https://www.mediafire.com/file/jsydt...video.mkv/file
Old 9th December 2024, 16:39   #10  |  Link
poisondeathray
If you add colorimetry tags to the input file, the output file with have PNG chunks and colors will appear incorrect in many programs, including browsers
See this thread (again). You questions were already asked, multiple answers and options give
3) If you add the colorimetry flags to the source, or for sources with colorimetry flags already present , the ffmpeg PNG's will display incorrect colors in many programs, including browsers (!) - because of gAMA and cHRM tag issue. Other formats like GIF are not affected
In case you've forgotten what you asked 2 weeks ago, and the many answers already provided, use search
http://forum.doom9.org/forum-rules.htm
1a) Use the search function before posting. Chances are your question has already been answered.
Old 9th December 2024, 17:03   #11  |  Link
jay123210599
I just want to check and see if Shutter Encoder had the same problems for PNG and APNG as ffmpeg.
Also, can I can correctly assume that the PNG chunks apply to APNG as well, and for unflagged sources, ffmpeg and Shutter Encoder will use 601 by default for all formats like JPG and GIF, and even video formats like MP4 and MKV?
Old 9th December 2024, 17:17   #12  |  Link
poisondeathray
You don't have to assume. You already asked. Already answered
See this thread
http://forum.doom9.org/showthread.php?t=185921&page=2
But what about APNG?
Yes ffmpeg apng is affected .
See this thread
Again, 601 by default for YUV to RGB conversions.
But not all your formats are necessarily RGB
To remind you, JPG usually does not use RGB, but YUV and full range 601 as per the spec JPEG spec, and GIF uses PAL8
See this thread, post 15
Mp4 and MKV are container formats. So it would depend on what you used inside the MP4 and MKV
Old 9th December 2024, 17:41   #13  |  Link
Z2697
The entity "Jay" (SCP-Doom9-123210599) keeps asking questions follwoing one or more of these rules:
1) The question can easily be looked up with a simple web search engine search.
2) The question can easily be answered by performing the actions involved in the question. "F*ck around and find out".
3) The question is ambiguous.
4) The question is subjective.
5) The question is a variation of previously asked question(s).
Old 9th December 2024, 21:41   #14  |  Link
jay123210599
In that case, I'm just going to add flags to my videos and convert it to lossless animated WEBP with the format being bgra, because I know by now that without flags it won't get the 709 colors I want.
Then I'll extract the frames from the WEBP using IrfanView as PNGs where it won't have any tag issues and display the right colors.
Old 9th December 2024, 21:58   #15  |  Link
poisondeathray
Or you could use the zscale filter as suggested in that thread. It would be much faster, no intermediate files or extra HDD space (hard drives do break from usage eventually). 1 step instead of 3
Old 9th December 2024, 22:23   #16  |  Link
poisondeathray
In that case, I'm just going to add flags to my videos and convert it to lossless animated WEBP with the format being bgra, because I know by now that without flags it won't get the 709 colors I want...
Also, BTW that proposed 2nd step converts incorrectly. If video has 709 colorimetry flags, it uses 601 for the actual conversion for lossless webp. It even gives you a warning
[libwebp_anim @ 000000b84c414100] Using libwebp for YUV-to-RGB conversion. You may want to consider passing in RGB instead for lossless encoding.
Old 10th December 2024, 00:53   #17  |  Link
jay123210599
Well, this is the command I used after adding the flags to my video, and I had not gotten a warning.
Old 10th December 2024, 01:28   #18  |  Link
poisondeathray
Ok, that looks mostly correct for flagged input, but there are avoidable rounding errors from -vf format's use of swscale's default fast low quality conversion mode. If you look at that same thread, it mentions the swscale issue and workarounds
You decide what's best for you, but IMO it's pointless to use "lossless" if you incur avoidable rounding errors
Old 10th December 2024, 03:12   #19  |  Link
jay123210599
How should I avoid their rounding errors?
Old 10th December 2024, 03:47   #20  |  Link
poisondeathray
Either use the sws accurate flags, or zscale. It was already mentioned and instructions given in yes... that same thread
But if you're using ffmpeg anyways to export webp, then irfanview - you might as well export PNG or apng once directly and correctly from ffmpeg - and skip the adding metadata , webp, and irfanview steps. It was already mentioned... yes in that same thread, the commands to use. No use repeating everything here again
colorspace, ffmpeg gui, image-quality
