Old 3rd December 2024, 02:37   #1  |  Link
jay123210599
APNG Tag Problem
Do APNGs have the same problem as PNGs where, if made by ffmpeg, the APNG's will display incorrect colors in many programs, including browsers, because of gAMA and cHRM tag issues? If so, how do I fix it?
jay123210599 is offline   Reply With Quote
Old 3rd December 2024, 05:42   #2  |  Link
poisondeathray
Yes same problem if input file has colorimetry flags. Same fix
See this thread
https://forum.doom9.org/showthread.php?t=185921
See this post and the replies
But what about APNG? So even if I use a video with colorimetry flags, it will still get the wrong colors for PNG files because of the gAMA, cHRM tags? How do I strip them to solve the problem?
Old 3rd December 2024, 13:13   #3  |  Link
jay123210599
And if my input doesn't have colorimetry flags, it would use 601 colors instead of 709 ones, and we don't that. If I add colorimetry flags to my video and then convert it to PNG and APNG, I will have the tag issues, right?
Old 3rd December 2024, 15:19   #4  |  Link
poisondeathray
Yes, 601 by default, unless otherwise specified. You can specify the conversion as mentioned in the other thread. Typically 709 is used for HD
Yes, because it's now flagged. So use one of the methods that work - there were several of them listed
You're asking the same thing over and over again....
Old 4th December 2024, 01:28   #5  |  Link
filler56789
SuperVirus
filler56789's Avatar
But of course.
https://forum.videohelp.com/members/224252-gamemaniaco
«Your software patents have expired.»
filler56789 is offline   Reply With Quote
colorspace, ffmpeg, ffmpeg gui, image-quality
