Old 28th October 2019, 07:26   #1  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
Intel SVT-AV1
I wanted to make a thread dedicated to discussing Intel's SVT AV1 encoder, as it seems to be quite good and rapidly improving. I'm seeing fantastic results using fixed QP encoding, though as far as I can tell rate control is pretty basic still.
For example, using fixed QP 44 encoding of a 1080p24 hand drawn animation source, I was able to get very nice looking video (average VMAF of 93.6) at 2.8 Mbps using enc-mode 1 (next to the slowest preset).
Speed is quite good for AV1 - I got 0.2 fps on my i7-7700k. This encoder scales very well and saturated my whole system!
What have others seen?
Old 28th October 2019, 10:24   #2  |  Link
Tadanobu
The last time I made subjective comparisons, SVT AV1 was behind libaom in term of grain and very fine details, even at speed 0. The image looked a bit smoothed, like comparing stock x265 with stock x264. But for real world scenarios, the quality for speed for compression was already quite good. Speeds 3/4 give very decent results and are way faster than libaom and rav1e. It's very promising.
Tadanobu is offline   Reply With Quote
Old 28th October 2019, 19:21   #3  |  Link
Blue_MiSfit
Any suggested encoding settings other than the usual "pick the slowest preset you can tolerate"?
Old 29th October 2019, 04:14   #4  |  Link
quietvoid
My line for 10 bit tests:
SvtAv1EncApp.exe -i sample.y4m -enc-mode 4 -bit-depth 10 -irefresh-type 2 -q 17 -tile-rows 6 -tile-columns 6 -output-stat-file out.stats -input-stat-file out.stats -enc-mode-2p 6 -b out.ivf
Has to be executed twice for 2 pass QP.
quietvoid is offline   Reply With Quote
Old 30th October 2019, 18:12   #5  |  Link
Blue_MiSfit
Thanks for sharing.
Just to be clear, do you use tile-rows and tile-columns to make decoding more parallel?
Also, you set irefresh-type to 2 (which makes the encoder use closed GOP), is this for an adaptive streaming use case?
Old 30th October 2019, 18:53   #6  |  Link
quietvoid
Using tiles makes both encoding and decoding "parallel", decoding scales better.
From what I've read, irefresh-type 1 (default) produces a non-seekable output.
Also I omitted 'intra-period 24' because that's specific to my tests (just an input source divided in scenes of 24 frames), but that requires closed GOP.
Old 30th October 2019, 20:40   #7  |  Link
Blue_MiSfit
I see. And you see a quality benefit to 2 pass even when using fixed QP?
Old 30th October 2019, 22:35   #8  |  Link
quietvoid
Have not compared, but 2 pass is only fixed QP for now.
I don't even know if it's worth using because of that.
Old 30th October 2019, 22:48   #9  |  Link
Blue_MiSfit
Scratching my head a bit trying to understand the 2 pass procedure. You literally run that full command above two times (specifying enc-mode enc-mode-2p input-stat-file and output-stat-file each time)?
Old 30th October 2019, 23:01   #10  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
. Speed is quite good for AV1 - I got 0.2 fps on my i7-7700k. This encoder scales very well and saturated my whole system!
1) 0.2 FPS on 4c/8t means that on epyc 64c/128t you would get less than 3fps. That's still pathetic encoding speed.
2) Saturated all CPU 8 threads during encoding is not a spectacular achievement. 100% CPU usage on ryzen 9 3850x would be something.
Old 30th October 2019, 23:48   #11  |  Link
quietvoid
Currently that's how it works, it will change to be more user friendly.
However I'm looking at the user guide and I think my 2 pass options are wrong.
-output-stat-file is for the first pass, -input-stat-file is for the 2nd pass. The two should probably not be used at the same time like I did (I used an example cmd from an issue ).
-enc-mode-2p is the preset at which the first pass is done, from what I understand.
Perhaps like this:
First pass: SvtAv1EncApp.exe -i sample.y4m -enc-mode 4 -bit-depth 10 -irefresh-type 2 -q 17 -tile-rows 6 -tile-columns 6 -output-stat-file out.stats -enc-mode-2p 6 -b out.ivf
Second pass: SvtAv1EncApp.exe -i sample.y4m -enc-mode 4 -bit-depth 10 -irefresh-type 2 -q 17 -tile-rows 6 -tile-columns 6 -input-stat-file out.stats -enc-mode-2p 6 -b out.ivf
Old 31st October 2019, 03:23   #12  |  Link
Blue_MiSfit
That was with very high quality encoding. This is still AV1 0.2 fps isn't too bad, to be honest.
Using faster settings (preset 5) I was able to achieve 4 fps, which is quite fast for 1080p AV1 with 4 cores. The fastest preset delivers 12 fps for me.
Regarding point 2, I think that's exactly what SVT AV1 is designed for, particularly when encoding multiple bitrates in parallel for ABR delivery. A full ABR ladder encoded live appears to be one of the goals of the project. libaom has terrible threading last I checked, as many big OTT VOD services will run encodes single threaded.
Old 31st October 2019, 03:41   #13  |  Link
Blue_MiSfit
Okay I finally got 2 pass working. @quietvoid you're correct, you have to use -enc-mode-2p with -output-stat-file for the first pass and -enc-mode with -input-stat-file for the second pass.
Here's a quick example using the fastest speed preset and raw 8 bit yuv input, targeting 1080p at 3 Mbps VBR.
First Pass
svtav1encapp -i Beauty.yuv -w 1920 -h 1080 -fps-num 24000 -fps-denom 1001 -intra-period 96 -irefresh-type 2 -rc 2 -tbr 3000000
-enc-mode-2p 8 -output-stat-file stats.file -b Beauty_svtav1_8_3000.ivf
Second Pass
-enc-mode 8 -input-stat-file stats.file -b Beauty_svtav1_8_3000.ivf
I get an output that decodes okay (and looks awful, predictably), but curiously there's an error during the second pass:
Error in freed returnVal 0
Odd.
Rate control seems to at least hit the target, it achieved 2995 Kbps which is within tolerance.
Any ideas on that error?
Old 31st October 2019, 15:49   #14  |  Link
Tadanobu
I think I've read somewhere that high -tile-rows and -tile-columns values are bad for quality encode. Can somebody confirm this ? I have deleted my test encodes but I think I tried not to go above 2x2. Or is it CPU related ?
Old 1st November 2019, 07:29   #15  |  Link
Blue_MiSfit
It makes sense to me that these would impact quality somewhat, since they're a bit like slices for MPEG codecs.
I don't know exactly how much they would impact quality.
Old 3rd November 2019, 03:27   #16  |  Link
Blue_MiSfit
Yikes. It's not too bad for small numbers of tiles, but it blows up really fast.
Using fixed QP 45, here's some results. Not a full BD-Rate analysis, but some food for thought. I used identical values for tile-column and tile-row for each of the below examples
row/column  | bitrate   | fps    | vmaf average
    0       | 4867      | 4.52   |   91.773
    1       | 4923      | 4.94   |   91.759
    2       | 5000      | 4.88   |   91.725
    4       | 5346      | 4.88   |   91.676
    6       | 5995      | 5.01   |   91.557
So, similar encoding quality across the board but with an enormous bitrate cost when using 6 columns + rows with 1080p, almost 23% more bits.
I imagine the impact would be less for UHD.
Old 3rd November 2019, 10:05   #17  |  Link
Tadanobu
Yeah, I made some new tests and I can confirm that. Higher numbers give higher bitrates while the encoding speed is not significantly faster. I can't see any good reason to use it at the moment.
So, here are some screenshots for subjective comparison. Source is 8bits 1080p, encoded with an i7-8750H using ffmpeg.
Speed went from 0.01FPS (-q 20 -enc-mode 0) to 8.07FPS (-q 50 -enc-mode 8). I personally find -q 20 -enc-mode 4 to be a good balance but it is still as slow as 0.89FPS.
Cropped and zoomed in
https://i.imgur.com/Q0IDhhL.jpg
https://i.imgur.com/JuviCld.jpg
https://i.imgur.com/jBSR00P.jpg
https://i.imgur.com/XCZucKs.jpg
https://i.imgur.com/Sw9fTs5.jpg
https://i.imgur.com/fzT3jba.jpg
https://i.imgur.com/RMlXto3.jpg
https://i.imgur.com/FM7Iwj8.jpg
https://i.imgur.com/ZoNvbsh.jpg
https://i.imgur.com/YQiPuvE.jpg
Full frames
https://i.imgur.com/y6VX0j9.png
https://i.imgur.com/9QHBAnK.png
https://i.imgur.com/IuhcV8j.png
https://i.imgur.com/IkDEXT5.png
https://i.imgur.com/oHFdv3Q.png
https://i.imgur.com/mCavZbf.png
https://i.imgur.com/G4n1vtt.png
https://i.imgur.com/TJ72o5A.png
https://i.imgur.com/3wWDFld.png
https://i.imgur.com/B83rdXk.png
Old 3rd November 2019, 11:38   #18  |  Link
nevcairiel
I would generally recommend to use at least two tiles at this point for the significant decoding boost it gives. Two tiles, compare to only one, almost doubles possible decoding speed, which for a new codec like this is quite significant.
Old 3rd November 2019, 21:26   #19  |  Link
Blue_MiSfit
Interesting, so to make two tiles, would you set tile-row to 2 and leave tile-column at 0 (or vice versa)?
[edit]
Just did some research, the config params are log2 values.
e.g.
param -> actual
1 -> 2
2 -> 4
3 -> 8
4 -> 16
I have no idea WHY this is the case (seems to be in order to use the same syntax as libaom)...
Did a quick sanity check, using -tile-columns 1 gave slightly better metrics than -tile-rows 1, but that's just a couple quick tests. It will likely be content dependent based on motion.
[/edit]
Old 4th November 2019, 21:06   #20  |  Link
Tadanobu
Thanks for the tiles trick. I'll use it from now on.
By the way, what do you guys think of SVT HEVC and SVT VP9 ? Is it my tests that are wrong or do they compress better than SVT AV1 ?
Visually speaking, SVT HEVC has been giving me very nice results. SVT VP9 is a little bit behind in term of compression, but I have almost similar results with faster encoding. Even -enc-mode 0 is ~3.5FPS, not bad. -enc-mode 10 goes up to 82FPS and the difference with -enc-mode 0 is barely perceptible. I need to do more tests, but seriously I'm impressed.
