Old 25th March 2012, 03:36   #1  |  Link
cigsmh
New avisynth and mencoder GUI
Hi guys,
I took me 1 year to build this program that used avisynth and mencoder to join practically unlimited number of videos with different attributes ( resolution, framerate, bitrate, audio channels) . There is also the avisynth based video/audio editor and avisynth filter builder to add any filter to the program. The name of the software is "Smart Video Merge".
The software is freeware and available at the aggeron dot com
Initially I crated this software as commercial, but than changed it to freeware. Enjoy.
There are more gui for mencoder and ffmpeg on my site.
P.S
Ignore activate button on the website , I dd not have time to remove it. No activation is needed the software is free.
By the way no spyware or other malware is included.
cigsmh is offline   Reply With Quote
Old 25th March 2012, 12:18   #2  |  Link
Taurus
Taurus's Avatar
Mmmh, avisynth not detected on program start.
Every attempt to install it from "Smart Video Merge" leads to an error message.
And yes Avisynth is healthy and running.
WinXP 32bit.
Taurus is offline   Reply With Quote
Old 27th March 2012, 00:00   #3  |  Link
cigsmh
I just downloaded and installed it on winxp 32 running in the vmware. Very smooth installation. Did you install avisynth into the Program Files folder?
Old 27th March 2012, 15:42   #4  |  Link
Taurus
Taurus's Avatar
I've never ever had problems with avisynth installs...
"Smart Video Merge" installer is burked.
It should notice if there is a working avisynth installation.
And yes, avisynth is in program files folder.
Even uninstalling and clearing up leftovers from avisynth folder did not resolve the error messages.
And yes, no leftovers in windir...too
Sorry, I give up.
avisynth gui, ffmpeg gui, mencoder gui
