Old 14th June 2025, 12:55   #1  |  Link
buddha9
buddha9's Avatar
How to convert from "DTS-ES™ Discrete 6.1" to "7 WAV files" with FFmpeg?
Hi!
I need to convert a file from "DTS-ES™ Discrete 6.1" to "7 WAV" files with FFmpeg.
Is this the right command? I need to import on Davinci Resolve the 7 wavs later...
I don’t want to go wrong with the name of channels.
ffmpeg -hide_banner -i 'input.dts' `
-filter_complex "channelsplit=channel_layout=6.1[FL][FR][FC][LFE][BC][SL][SR]" `
-map "[FL]" -c:a pcm_s24le [-L-]_Front_Left_Channel.wav `
-map "[FR]" -c:a pcm_s24le [-R-]_Front_Right_Channel.wav `
-map "[FC]" -c:a pcm_s24le [-C-]_Front_Center_Channel.wav `
-map "[LFE]" -c:a pcm_s24le [-LFE-]_LFE_Channel.wav `
-map "[BC]" -c:a pcm_s24le [-CS-]_Back_Center_Channel.wav `
-map "[SL]" -c:a pcm_s24le [-LS-]_Left_Surround_Channel.wav `
-map "[SR]" -c:a pcm_s24le [-RS-]_Right_Surround_Channel.wav
Thanks!
AviSynth+ 3.7.3
buddha9 is offline   Reply With Quote
Old 14th June 2025, 13:24   #2  |  Link
buddha9
buddha9's Avatar
I download a genuine "DTS-ES Discrete 6.1" file from https://drive.google.com/drive/folde...roiDOS2vEX7N4b
Drop it on Audacity.
Listen audio from there.
So the channels order is clear now and the ffmpeg command on first post is perfect.
Thanks to all
AviSynth+ 3.7.3
Old 15th June 2025, 07:35   #3  |  Link
tebasuna51
tebasuna51's Avatar
Yep, it is ok.
You can use also to obtain the mono channels:
eac3to input.dts output.wavs
Some old dts decoders can output other order using the old format [FL][FR][FC][LFE][BL][BR][BC]
when Surround channels were decoded like Back [BL][BR], instead Side [SL][SR] like modern decoders must do.
Old 28th June 2025, 08:54   #4  |  Link
buddha9
buddha9's Avatar
Yep, it is ok.
Many thanks!
I think I'll use your solution (eac3to)!
AviSynth+ 3.7.3
dts-es, ffmpeg
