Old 7th January 2025, 20:06   #21  |  Link
GeoffreyA
Donor
Originally Posted by poisondeathray View Post
My comments for "pallete optimization" for PNG were "in general" . It's a commonly used lossy technique for web graphics
If you're referring to apngasm specifically , the optimizations used there should be lossless according to the instructions.
Noted. I didn't read the Readme.
GeoffreyA is offline   Reply With Quote
Old 8th January 2025, 16:52   #22  |  Link
jay123210599
Here are my test files: https://www.mediafire.com/file/2ooty..._APNGs.7z/file
1-1 and 2-1 uses both color and palette optimization.
1-2 and 2-2 does use color nor palette optimization.
1-3 and 2-3 only uses palette optimization.
1-4 and 2-4 only uses color optimization.
All of them use zlib for compression.
jay123210599 is offline   Reply With Quote
Old 8th January 2025, 17:29   #23  |  Link
GeoffreyA
Donor
Good job on the testing, and well organised. Looks like it's of no use turning on those settings because the files are exactly the same size; even the hashes are identical.
I must say, Jay, I couldn't help but smile seeing the second set of APNGs. Thanks for bringing a bit of humour to the evening. What anime is that?
Old 8th January 2025, 17:32   #24  |  Link
Z2697
Keijo, perhaps
Z2697 is offline   Reply With Quote
Old 8th January 2025, 17:57   #25  |  Link
jay123210599
You mean the colors? How did you prove they were the same?
Old 8th January 2025, 18:53   #26  |  Link
Z2697
cmp
md5sum
sha1sum
sha256sum
b3sum
Or even just look crc32 already in the 7z archive LOL
Old 8th January 2025, 18:55   #27  |  Link
GeoffreyA
Donor
I didn't test the colours. I just looked at the file sizes and hashes in 7-Zip. Whether they are the same as the PNGs, I do not know, but they, the APNGs, are identical to each other.
Old 8th January 2025, 18:59   #28  |  Link
GeoffreyA
Donor
Originally Posted by Z2697 View Post
Keijo, perhaps
Okay, I haven't seen that one, or indeed, any of this genre.
Old 8th January 2025, 19:52   #29  |  Link
Z2697
Me neither
Wait it's a genre?
Old 8th January 2025, 20:23   #30  |  Link
GeoffreyA
Donor
Me neither
Wait it's a genre?
Well, I wouldn't be surprised. It's an out-of-the-ordinary concept
Old 8th January 2025, 21:59   #31  |  Link
jay123210599
How do I check the hashes of the APNGs?
Old 9th January 2025, 07:17   #32  |  Link
GeoffreyA
Donor
For my part, the easiest way is with 7-Zip. Inside its file explorer, right click on a file, then CRC, and select the hash method, or "*" to calculate all methods. Also, in archives, the CRC32 of each file is listed in one of the columns.
ffmpeg, png
