#1 | Link |
From PNGs to APNGs
I have 227 PNGs. I want to make APNGs out of them where each APNG has 50 frames in them. I also want to make all of the APNGs in one setting. How do I do that using ffmpeg?
#2 | Link |
"From APNGs from PNGs",
Typo ?, Maybe "To APNGs from PNGs", or "From PNGs to APNGs". Select EDIT, Advanced EDIT, on first post to edit thread title.
#3 | Link |
APNG implementaion in ffmpeg is subpar. You use https://apngasm.sourceforge.net/
#4 | Link |
Donor
![]() Join Date: Jun 2024
Here's a working method for the time being. I tried to do it all automatically, but nested FOR loops are problematic in Windows batch files. So, you will have to change the "start" and "end" variables each time. The first time would be "start=1" and "end=50" and the second time, "start=51" and "end=100" and so on. Your filenames will have to be in the format of "1.png" and so forth, starting from 1. Please run this on a copy of your original folder in case something gets accidentally overwritten. I'll see if I can improve to do everything automatically.
setlocal EnableDelayedExpansion set start=1 set end=50 mkdir "OUT" (for /l %%i in (!start!, 1, !end!) do @echo file %%i.png) > "Jay2025.txt" ffmpeg -f concat -r 23.976 -i "Jay2025.txt" "OUT\FINAL_%RANDOM%.apng" pause |
#5 | Link | |
Donor
#6 | Link | |
#9 | Link |
Well, the default frame delay is 1/10 sec. How do I adjust it so my output APNG has 23.976 fps?
Also, which compressions for the tools are lossless, zlib, 7zip, or Zopfli? How does the number of iterations affect the compression/speed/quality? If I choose to optimize the palette and/or original color type of the PNGs, will it affect the quality of the APNG? |
#11 | Link | |
Donor
#14 | Link | |
#16 | Link | |
Palette optimization for PNG can be lossless if it's a very simple source with a few colors . This technique is typically used for simple graphics / logos with a few colors |
#17 | Link | |
#18 | Link | |
In simple cases (e.g. simple logo with 6 colors) you might not get rid of any colors You can test it yourself. If you cannot "see" the quality loss, measure it with an objective metric such as PSNR. This method was shown to you in other threads. Another indirect way is to count the number of unique colors e.g. imagemagick. If you start with say 6,467,433 . But you optimize the pallette and now you have 1,234,453. You've lost millions of colors => quality loss "mathematically lossless" means the decoded data is the same - or bit for bit identical |
#19 | Link | |
Donor
These are my findings; but you've got to test it out yourself because your files may yield different results. Regarding the delay, use the ratio of 1001/24000. It yields 23.976 fps. Yesterday, I was under the impression that one could add a decimal number to the program, but actually, it has to be in the form of a fraction. |
#20 | Link | |
My comments for "pallete optimization" for PNG were "in general" . It's a commonly used lossy technique for web graphics
If you're referring to apngasm specifically , the optimizations used there should be lossless according to the instructions. Quote:
| Tags |
| ffmpeg, png |
| Display Modes | |
