Old 5th November 2024, 16:27   #1  |  Link
jay123210599
Automatic Same Name
When doing any operation in ffmpeg, how do I automatically make the output file have the same name as the input file?
For example, I remux a single mkv file to mp4, and I want the output mp4 to have the same name as the input mkv.
Using a script is not allowed.
jay123210599 is offline   Reply With Quote
Old 11th November 2024, 21:13   #2  |  Link
Selur
Selur's Avatar
What OS?
Isn't anything called in a bash (on Windows) or a terminal (Linux/Mac) basically a script?
if you know the name and can use a environment variable probably do something like:
set p=INPUT_NAME && call ffmpeg -i "YOUR_PATH_TO/%p%.mkv" "OUTPUT_PATH/%p%.mkv"
(INPUT_NAME, YOUR_PATH_TO and OUTPUT_PATH are variables that need to be set)
Cu Selur
Hybrid here in the forum, homepage, its own forum
Old 13th November 2024, 02:32   #3  |  Link
jay123210599
Originally Posted by Selur View Post
What OS?
Cu Selur
I'm in Windows, and I don't want to use scripts. This is for cases like ffmpeg.
Old 13th November 2024, 04:05   #4  |  Link
Z2697
Originally Posted by jay123210599 View Post
i'm in windows, and i don't want to use scripts. This is for cases like ffmpeg.
no.
I think the only case where FFmpeg will parse formatted filename is with image2 muxer/demuxer
Z2697 is offline   Reply With Quote
Old 13th November 2024, 11:59   #5  |  Link
Is the OP wanting some kind of ffmpeg GUI ?
(requirement seems a little 'fuzzy')
Old 13th November 2024, 18:17   #6  |  Link
hello_hello
You could try AnotherGUI. https://www.videohelp.com/software/AnotherGUI
Use the Executables menu to tell AnotherGUI where ffmpeg is.
A preset for remuxing a file as an MP4 might look like this (added to the First Pass section of the preset configuration), but of course it can be a preset for performing any type of ffmpeg conversion.
-i "<FullSourceFileName>" -y -threads 1 -vcodec copy -acodec copy "<OutputPath><OutputFileName>.mp4"
Once you've created the preset, select it and drag and drop a file or files onto AnotherGUI (any file type that can be remuxed as an MP4), then click "Go". The default output name is the same as the input.
Old 17th November 2024, 15:08   #7  |  Link
jay123210599
I don't want a GUI. I want to put in something that will get me the same name for the output from the input, like %d or something.
Old 19th November 2024, 09:31   #8  |  Link
tebasuna51
tebasuna51's Avatar
If you don't want GUI's or scripts you can run that command line in a folder with the mkv's you want convert to mp4:
FOR %I in (*.mkv) DO "YOUR_PATH_TO\ffmpeg.exe" -i "%I" "%~nI.mp4"
Old 21st November 2024, 14:13   #9  |  Link
jay123210599
What if I have only a single mkv I want to convert to mp4?
Old 22nd November 2024, 09:08   #10  |  Link
GeoffreyA
Donor
It will work for a single file.
GeoffreyA is online now   Reply With Quote
ffmpeg
