Old 14th October 2024, 08:33   #1  |  Link
yuygfgg
Use libavfilter in vapoursynth?
I'm encoding on Apple Silicon Macs. However, KNLMEANSCL and libavfilter's nlmeans_opencl don't work correctly here for some reason. Luckily, libavfilter as a nlmeans_vulkan. Is it possible to use it inside vpys? Or I will have to port the code myself?
yuygfgg is offline   Reply With Quote
Old 14th October 2024, 09:41   #2  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
You have to port it.
Myrsloik is offline   Reply With Quote
Old 14th October 2024, 12:46   #3  |  Link
ChaosKing
CPU version of KNLMEANSCL https://github.com/AmusementClub/vs-nlm-ispc
I have no idea if can be compiled for mac or not.
EDIT: I'm blind https://github.com/AmusementClub/vs-...me-ov-file#arm
Old 14th October 2024, 12:55   #4  |  Link
yuygfgg
I've used that for a long time. It's good and very fast, but I'm still seeking if I can offload some work from CPU to GPU. Currently the gpu only works for nnedi3cl and eedi3cl.
Old 14th October 2024, 19:09   #5  |  Link
Z2697
If you are going to port somthing, is a somewhat general interface of libavfilters possible? So most of the FFmpeg's filters can be used...
(Talk about general interfaces I think vs-placebo, then I think perhaps you can use nlmeans shader)
Last time I checked, vs-nlm-ispc got completely "smashed" by the opencl version in terms of speed, is it different in Apple Silicon chips? What performance is it that you would call it "very fast"?
What is the "not work correctly" mean by the way? Is it crashing, or is it have corrupted output frames?
Z2697 is offline   Reply With Quote
Old 14th October 2024, 21:59   #6  |  Link
ChaosKing
Performance king would be vs-nlm-cuda, but I don't think cuda is supported on mac?
Old 15th October 2024, 01:47   #7  |  Link
yuygfgg
nlm_ispc is about 45 fps, it's high performance compared with bm3dcpu(~6fps)
not work correctly means it output broken images.
Old 15th October 2024, 10:48   #8  |  Link
Z2697
Can you elaborate on what parameters is used in that speed comparison, and share a screenshot of the broken output?
Old 16th October 2024, 02:44   #9  |  Link
yuygfgg
yeah cuda don't support mac. I'm now learning apple's metal, it's like 80% similar with cuda. But it's swift that made it hard to use in vapoursynth plugins.
ffmpeg, libavfilter, vapoursynth
