8th March 2019, 01:49 | #301 | Link | |
8th March 2019, 21:07 | #302 | Link | |
Release 2.0.0.1 Beta
Link: https://github.com/Revan654/staxrip/...0.0.1.Beta.rar The File size did shrink some how. Last Release: 297 MB, This Release: 274 MB |
9th March 2019, 08:59 | #303 | Link |
Thanks for the new Beta.
I found one issue so far. When trying to use ffmpeg and QSVEncC I get the following error message: Video encoding using QSVEnc 3.17 failed with exit code: 1 (0x1) The exit code might be a system error code: STATUS_WAIT_1 The exit code might be a system error code: Unzulässige Funktion. y4m: failed to parse y4m header. It worked before in StaxRip.2.0.0.0 without any problems. There seems to be an issue with the provided ffmpeg.exe. Updating the ffmpeg.exe to the latest version fixes this in case anyone else has this error. |
9th March 2019, 18:13 | #304 | Link |
Revan654,
thank you for the new Beta! Can I copy my *.srip template- files from 2.0.0.0-release to 2.0.0.1-beta? I have about 10 templates and it is much work to generate the files new in every version. ...when I update Avisynth+ in my windows 10 system over the 2.0.0.1-beta, are problems to be expected in the operation of the previous version 2.0.0.0-release? Thank you for help Last edited by wallander; 9th March 2019 at 18:23. |
11th March 2019, 10:42 | #307 | Link |
@Revan654
The visual clitch I reported does still appear using your latest release. Was that built before you fixed the issue? I checked the file modified date but it's not present in the rar archieve, using the packer from www.7-zip.org the dates are preserved. To prepare a release or test build I used a utility written in VB.NET, for mpv.net I use powershell, looks like so. Code:
$scriptDir = Split-Path -Path $PSCommandPath -Parent $exePath = $scriptDir + "\mpv.net\bin\Debug\mpvnet.exe" $version = [Diagnostics.FileVersionInfo]::GetVersionInfo($exePath).FileVersion $desktopDir = [Environment]::GetFolderPath("Desktop") $targetDir = $desktopDir + "\mpv.net-" + $version if (Test-Path $targetDir) { rd $targetDir -recurse } Copy-Item $scriptDir\mpv.net\bin\Debug $targetDir -recurse $addonDir = $targetDir + "\Addons" remove-item $addonDir -Recurse -Include *mpvnet.exe, *mpvnet.exe.config, *mpvnet.pdb $7zPath = "C:\Program Files\7-Zip\7z.exe" $args = "a -t7z -mx9 $targetDir.7z -r $targetDir\*" Start-Process -FilePath $7zPath -ArgumentList $args Code:
Shared Sub ReleaseStaxRip() Dim sourceDir = "D:\Projekte\VS\VB\StaxRip\bin\" Dim version = Assembly.LoadFile(sourceDir + "StaxRip.exe").GetName.Version Dim releaseType = "-stable" If version.Revision <> 0 Then releaseType = "-test" If Not Directory.Exists(sourceDir) Then Msg("Source directory not found." + BR2 + sourceDir, MessageBoxIcon.Error) Exit Sub End If Dim info = FileVersionInfo.GetVersionInfo(sourceDir + "StaxRip.exe") Dim targetDir = Path.Combine(Environment.GetFolderPath(Environment.SpecialFolder.Desktop), "StaxRip-x64-" + info.FileVersion + releaseType + "\") FileSysUtil.DeleteDir(targetDir) FileSystem.CopyDirectory(sourceDir, targetDir) For Each i In Directory.GetDirectories(targetDir + "Apps\Plugins\vs") Dim cacheDir = i + "\__pycache__" If Directory.Exists(cacheDir) Then FileSysUtil.DeleteDir(cacheDir) Next FileSysUtil.DeleteDir(targetDir + ".vs") FileSysUtil.DeleteDir(targetDir + "Apps\qaac\QTfiles64") FileSysUtil.DeleteFile(targetDir + "debug.log") FileSysUtil.DeleteFile(targetDir + "_StaxRip.log") FileSysUtil.DeleteFile(targetDir + "StaxRip.vshost.exe") FileSysUtil.DeleteFile(targetDir + "StaxRip.vshost.sln") FileSysUtil.DeleteFile(targetDir + "StaxRip.vshost.exe.config") FileSysUtil.DeleteFile(targetDir + "StaxRip.vshost.exe.manifest") FileSysUtil.DeleteFile(targetDir + "Apps\eac3to\log.txt") FileSysUtil.DeleteFile(targetDir + "Apps\DGIndex\DGIndex.ini") FileSysUtil.DeleteFile(targetDir + "Apps\MKVToolNix\mkvtoolnix.ini") FileSysUtil.DeleteFile(targetDir + "Apps\MKVToolNix\mkvtoolnix-gui.ini") FileSysUtil.DeleteFile(targetDir + "Apps\ProjectX\X.ini") FileSysUtil.DeleteFile(targetDir + "Apps\AVSMeter\AVSMeter.ini") For Each i In Directory.GetFiles(targetDir, "*.ini", IO.SearchOption.AllDirectories) Msg(i, MessageBoxIcon.Exclamation) Exit Sub Next Pack({targetDir}.ToList) If releaseType = "-test" Then For Each i In { "C:\Users\Frank\Dropbox\public\StaxRip\Builds\", "C:\Users\Frank\OneDrive\StaxRip test build\"} FileSystem.CopyFile(targetDir.TrimEnd("\"c) + ".7z", i + DirPath.GetName(targetDir) + ".7z", UIOption.AllDialogs) Process.Start(i) Next End If End Sub Shared Sub Pack(args As List(Of String)) For Each i In args If i.EndsWith("\") Then i = i.TrimEnd("\"c) Dim targetName = i + ".7z" i += "\" + "*" Using p As New Process p.StartInfo.FileName = Environment.ExpandEnvironmentVariables("%programfiles%\7-Zip\7z.exe") p.StartInfo.Arguments = " a -t7z -mx9 """ + targetName + """ -r """ + i + """" p.Start() p.WaitForExit() If p.ExitCode <> 0 Then Throw New Exception("7z failed with exit code " + p.ExitCode.ToString + ".") End Using Next End Sub
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 11th March 2019 at 10:51. |
12th March 2019, 02:04 | #309 | Link |
don't think the files synced up.
This version will have the fix: https://ci.appveyor.com/project/Reva...uild/artifacts. Not sure what the problem was with the UI not scaling at on some DPI's. |
12th March 2019, 04:47 | #311 | Link |
@Revan654
It renders fine now, thanks! I've made a pull request to install FFTW only if needed: https://github.com/Revan654/staxrip/pull/87/files Last edited by stax76; 12th March 2019 at 05:45. |
12th March 2019, 14:23 | #313 | Link |
Very minor cosmetic issue
A very small cosmetic issue. When on the main StaxRip window, where you see the video codec and container chosen on the RHS, the descriptions for the x265 quality settings are the same as x264. As x265 is more efficient than x264, should the descriptions for x265 be changed? For example, quality of 26 shows as "very low" for both x264 and x265. Should a setting of 26 for x265 be set to "medium"?? There is a link below to an ffmpeg doc saying that CRF 23 on x264 is about the same as CRF 28 on x265. https://trac.ffmpeg.org/wiki/Encode/H.265 |
12th March 2019, 15:00 | #314 | Link |
I've been wanting to try StaxRip 2.0.0.0 after it was recently recommended to me but I'm having a difficult time getting it to run.
When I first run it and try to load a video it prompts me to install avisynth+ which installs fine. Then it prompts me to install FFTW, and when I click on that it returns an error. I have also manually added the .dll's described in the link http://avisynth.nl/index.php/QTGMC but it still gives me the error. Any idea on how to get running? Thanks. |
12th March 2019, 18:03 | #315 | Link | |
12th March 2019, 18:05 | #316 | Link | |
I just have way to many projects I'm working on, Plus switching from c# to VB can be slightly annoying. I don't have allot of extra time to make some changes I have ideas for. Plus I have to switch from WPF to WinForms. Last edited by Revan654; 12th March 2019 at 18:08. |
12th March 2019, 22:19 | #318 | Link |
Hello friends, I have come to ask for the help of everyone with a problem that I try to solve for months and I can not find a way to solve it.
I already activated the HDR in windows 10 and QLED55q6fn TV and everything seems to work normal, since in games the HDR activates normally and stays show. I use staxrip to convert my videos, usually movies I down in 1080p remux h264 (.mkv) or 4k h265 all without HDR. But all the videos I try to convert with the staxrip using x265 10bit adding HDR settings does not look good, it looks like the image is too red, and with too much contrast or gamma I can not say for sure what it is exactly. I also used the Nvidia h265 10bit configuration with HDR configuration and it conforms to the phitos. already tried to convert the video with commands ffmpeg adding HDR commands and the same thing happens. already tried all kinds of configuration and nothing. What can I be doing wrong? follow images below and images of the current staxrip, use version 2.0.0.0 - x64. Setting the video after conversion mediainfo Video ID: 1 Format: HEVC Format / Info: High Efficiency Video Coding Commercial name: HDR10 Format profile: Main 10 @ L6.2 @ High Codec ID: V_MPEGH / ISO / HEVC Duration: 2 h 29 min Bit rate: 5 883 kb / s Width: 1 920 pixels Height: 1 080 pixels Display aspect ratio: 2.40: 1 Frame rate mode: Constant Frame rate: 23.976 (24000/1001) FPS Color space: YUV Chroma subsampling: 4: 2: 0 Bit depth: 10 bit Bits / (Pixel * Frame): 0.118 Stream size: 6.14 GiB (91%) Language: English Default: Yes Forced: No Color range: Limited Primary color: BT.2020 Transfer characteristics: PQ Matrix coefficients: BT.2020 non-constant Mastering display primary color: BT.2020 Mastering display luminance: min: 0.0001 cd / m2, max: 1000 cd / m2 Maximum Content Light Level: 1000 cd / m2 Maximum Frame-Average Light Le: 1 cd / m2 images with HDR color problem images without HDR enabled image Staxrip config |
13th March 2019, 04:14 | #319 | Link |
I'm having an issue with 2.0.1beta where it seems to fail the audio conversion from DTS to AAC\M4A. If i roll back to the 2.0.0 bundle it works as it should.
EDIT: Gah it's mediainfo.dll causing it, copied the 2.0.0 version over the top of the 2.0.1 version and it works. Code:
-------------------------- System Environment -------------------------- StaxRip : 2.0.0.1 Windows : Windows 10 Education 1809 Language : English (New Zealand) CPU : Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz GPU : Radeon RX 580 Series Resolution : 2560 x 1440 DPI : 96 ------------------------ MediaInfo Source File ------------------------ W:\-UPLOAD-\XxXxXxXxXxX.1080p.x264.5.1.DTS.mkv General Complete name : W:\-UPLOAD-\XxXxXxXxXxX.1080p.x264.5.1.DTS.mkv Format : Matroska Format version : Version 4 File size : 36.6 MiB Duration : 55 min 28 s Overall bit rate : 92.3 kb/s Encoded date : UTC 2019-03-08 21:40:34 Writing application : mkvmerge v31.0.0 ('Dolores In A Shoestand') 64-bit Writing library : libebml v1.3.6 + libmatroska v1.4.9 IsTruncated : Yes Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings : CABAC / 4 Ref Frames Format, CABAC : Yes Format, ReFrames : 4 frames Codec ID : V_MPEG4/ISO/AVC Duration : 55 min 28 s Nominal bit rate : 8 732 kb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.176 Writing library : x264 core 144 r2525 40bb568 Language : English Default : Yes Forced : No Audio ID : 2 Format : DTS Format/Info : Digital Theater Systems Codec ID : A_DTS Duration : 55 min 28 s Bit rate mode : Constant Bit rate : 1 509 kb/s Channel(s) : 6 channels Channel layout : C L R Ls Rs LFE Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 SPF) Bit depth : 24 bits Compression mode : Lossy Stream size : 599 MiB Language : English Default : Yes Forced : No Text #1 ID : 3 Format : VobSub Muxing mode : zlib Codec ID : S_VOBSUB Codec ID/Info : Picture based subtitle format used on DVDs Language : English Default : No Forced : No Text #2 ID : 4 Format : VobSub Muxing mode : zlib Codec ID : S_VOBSUB Codec ID/Info : Picture based subtitle format used on DVDs Language : English Default : No Forced : No Menu 00 : 00:00.000 : en:00:00:00.000 00 : 01:19.830 : en:00:01:19.830 00 : 06:37.480 : en:00:06:37.480 00 : 15:21.629 : en:00:15:21.629 00 : 25:20.811 : en:00:25:20.811 00 : 35:55.904 : en:00:35:55.904 00 : 45:14.754 : en:00:45:14.754 00 : 54:10.622 : en:00:54:10.622 ------------------ Demux MKV using mkvextract 31.0.0 ------------------ D:\Staxrip.2.0.0.1.Beta\Apps\Support\MKVToolNix\mkvextract.exe "W:\-UPLOAD-\XxXxXxXxXxX.1080p.x264.5.1.DTS.mkv" tracks 2:"C:\TMP\XxXxXxXxXxX.1080p.x264.5.1.DTS_temp\XxXxXxXxXxX.1080p.x264.5.1.DTS ID3 English" 3:"C:\TMP\XxXxXxXxXxX.1080p.x264.5.1.DTS_temp\XxXxXxXxXxX.1080p.x264.5.1.DTS ID4 English" 1:"C:\TMP\XxXxXxXxXxX.1080p.x264.5.1.DTS_temp\XxXxXxXxXxX.1080p.x264.5.1.DTS ID1 English.mka" --ui-language en Extracting track 1 with the CodecID 'A_DTS' to the file 'C:\TMP\XxXxXxXxXxX.1080p.x264.5.1.DTS_temp\XxXxXxXxXxX.1080p.x264.5.1.DTS ID1 English.mka'. Container format: Digital Theater System (DTS) Extracting track 2 with the CodecID 'S_VOBSUB' to the file 'C:\TMP\XxXxXxXxXxX.1080p.x264.5.1.DTS_temp\XxXxXxXxXxX.1080p.x264.5.1.sub'. Container format: VobSubs Error: Failed to create the VobSub data file 'C:\TMP\XxXxXxXxXxX.1080p.x264.5.1.DTS_temp\XxXxXxXxXxX.1080p.x264.5.1.sub': open file error Start: 3:50:01 PM End: 3:50:01 PM Duration: 00:00:00 General Complete name : C:\TMP\XxXxXxXxXxX.1080p.x264.5.1.DTS_temp\XxXxXxXxXxX.1080p.x264.5.1.DTS ID1 English.mka File size : 0.00 Byte -------------- Demux xml chapters using mkvextract 31.0.0 -------------- D:\Staxrip.2.0.0.1.Beta\Apps\Support\MKVToolNix\mkvextract.exe "W:\-UPLOAD-\XxXxXxXxXxX.1080p.x264.5.1.DTS.mkv" chapters "C:\TMP\XxXxXxXxXxX.1080p.x264.5.1.DTS_temp\XxXxXxXxXxX.1080p.x264.5.1.DTS_chapters.xml" File 'W:\-UPLOAD-\XxXxXxXxXxX.1080p.x264.5.1.DTS.mkv': container: Matroska Track ID 0: video (MPEG-4p10/AVC/h.264) Track ID 1: audio (DTS) Track ID 2: subtitles (VobSub) Track ID 3: subtitles (VobSub) Chapters: 8 entries Start: 3:50:01 PM End: 3:50:02 PM Duration: 00:00:00 -------------- Demux ogg chapters using mkvextract 31.0.0 -------------- D:\Staxrip.2.0.0.1.Beta\Apps\Support\MKVToolNix\mkvextract.exe "W:\-UPLOAD-\XxXxXxXxXxX.1080p.x264.5.1.DTS.mkv" chapters "C:\TMP\XxXxXxXxXxX.1080p.x264.5.1.DTS_temp\XxXxXxXxXxX.1080p.x264.5.1.DTS_chapters.txt" --simple File 'W:\-UPLOAD-\XxXxXxXxXxX.1080p.x264.5.1.DTS.mkv': container: Matroska Track ID 0: video (MPEG-4p10/AVC/h.264) Track ID 1: audio (DTS) Track ID 2: subtitles (VobSub) Track ID 3: subtitles (VobSub) Chapters: 8 entries Start: 3:50:02 PM End: 3:50:02 PM Duration: 00:00:00 ----------------------- Indexing using ffmsindex ----------------------- D:\Staxrip.2.0.0.1.Beta\Apps\Plugins\both\ffms2\ffmsindex.exe "W:\-UPLOAD-\XxXxXxXxXxX.1080p.x264.5.1.DTS.mkv" "C:\TMP\XxXxXxXxXxX.1080p.x264.5.1.DTS_temp\XxXxXxXxXxX.1080p.x264.5.1.DTS.ffindex" Writing index... done. Start: 3:50:02 PM End: 3:50:02 PM Duration: 00:00:00 -------------------------- VapourSynth Script -------------------------- import os import sys ScriptPath = 'D:/Staxrip.2.0.0.1.Beta/Apps/Plugins/VS/Scripts' sys.path.append(os.path.abspath(ScriptPath)) import vapoursynth as vs core = vs.get_core() import importlib.machinery psharpen = importlib.machinery.SourceFileLoader('psharpen', r"D:\Staxrip.2.0.0.1.Beta\Apps\Plugins\VS\Scripts\psharpen.py").load_module() mvsfunc = importlib.machinery.SourceFileLoader('mvsfunc', r"D:\Staxrip.2.0.0.1.Beta\Apps\Plugins\VS\Scripts\mvsfunc.py").load_module() adjust = importlib.machinery.SourceFileLoader('adjust', r"D:\Staxrip.2.0.0.1.Beta\Apps\Plugins\VS\Scripts\adjust.py").load_module() havsfunc = importlib.machinery.SourceFileLoader('havsfunc', r"D:\Staxrip.2.0.0.1.Beta\Apps\Plugins\VS\Scripts\havsfunc.py").load_module() core.std.LoadPlugin(r"D:\Staxrip.2.0.0.1.Beta\Apps\Plugins\both\ffms2\ffms2.dll") core.std.LoadPlugin(r"D:\Staxrip.2.0.0.1.Beta\Apps\Plugins\vs\fmtconv\fmtconv.dll") core.std.LoadPlugin(r"D:\Staxrip.2.0.0.1.Beta\Apps\Plugins\vs\AWarpSharp2\libawarpsharp2.dll") core.std.LoadPlugin(r"D:\Staxrip.2.0.0.1.Beta\Apps\Plugins\vs\CTMF\CTMF.dll") core.std.LoadPlugin(r"D:\Staxrip.2.0.0.1.Beta\Apps\Plugins\VS\DCTFilter\DCTFilter.dll") core.std.LoadPlugin(r"D:\Staxrip.2.0.0.1.Beta\Apps\Plugins\VS\Deblock\Deblock.dll") core.std.LoadPlugin(r"D:\Staxrip.2.0.0.1.Beta\Apps\Plugins\vs\DFTTest\DFTTest.dll") core.std.LoadPlugin(r"D:\Staxrip.2.0.0.1.Beta\Apps\Plugins\vs\EEDI2\EEDI2.dll") core.std.LoadPlugin(r"D:\Staxrip.2.0.0.1.Beta\Apps\Plugins\vs\EEDI3m\EEDI3m.dll") core.std.LoadPlugin(r"D:\Staxrip.2.0.0.1.Beta\Apps\Plugins\vs\FFT3DFilter\fft3dfilter.dll") core.std.LoadPlugin(r"D:\Staxrip.2.0.0.1.Beta\Apps\Plugins\vs\FluxSmooth\libfluxsmooth.dll") core.std.LoadPlugin(r"D:\Staxrip.2.0.0.1.Beta\Apps\Plugins\vs\HQDN3D\libhqdn3d.dll") core.std.LoadPlugin(r"D:\Staxrip.2.0.0.1.Beta\Apps\Plugins\both\KNLMeansCL\KNLMeansCL.dll") core.std.LoadPlugin(r"D:\Staxrip.2.0.0.1.Beta\Apps\Plugins\vs\BM3D\BM3D.dll") core.std.LoadPlugin(r"D:\Staxrip.2.0.0.1.Beta\Apps\Plugins\vs\mvtools\libmvtools.dll") core.std.LoadPlugin(r"D:\Staxrip.2.0.0.1.Beta\Apps\Plugins\VS\nnedi3\libnnedi3.dll") core.std.LoadPlugin(r"D:\Staxrip.2.0.0.1.Beta\Apps\Plugins\VS\nnedi3\NNEDI3CL.dll") core.std.LoadPlugin(r"D:\Staxrip.2.0.0.1.Beta\Apps\Plugins\vs\Sangnom\libsangnom.dll") core.std.LoadPlugin(r"D:\Staxrip.2.0.0.1.Beta\Apps\Plugins\vs\scenechange\scenechange.dll") core.std.LoadPlugin(r"D:\Staxrip.2.0.0.1.Beta\Apps\Plugins\VS\SVPFlow\svpflow1_vs64.dll") core.std.LoadPlugin(r"D:\Staxrip.2.0.0.1.Beta\Apps\Plugins\VS\SVPFlow\svpflow2_vs64.dll") core.std.LoadPlugin(r"D:\Staxrip.2.0.0.1.Beta\Apps\Plugins\vs\TTempSmooth\TTempSmooth.dll") core.std.LoadPlugin(r"D:\Staxrip.2.0.0.1.Beta\Apps\Plugins\VS\nnedi3\vsznedi3.dll") clip = core.ffms2.Source(r"W:\-UPLOAD-\XxXxXxXxXxX.1080p.x264.5.1.DTS.mkv", cachefile = r"C:\TMP\XxXxXxXxXxX.1080p.x264.5.1.DTS_temp\XxXxXxXxXxX.1080p.x264.5.1.DTS.ffindex") clip = core.fmtc.bitdepth (clip, bits=16) clip = core.resize.Spline36(clip, 1280, 720) clip = havsfunc.SMDegrain(clip, tr=4, RefineMotion=True, thSAD=500) clip = psharpen.psharpen(clip) clip.set_output() -------------------------- Script Properties -------------------------- Source Frame Count : 1058 Source Frame Rate : 23.976024 Source Duration : 00:00:44.1270000 Target Frame Count : 240 Target Frame Rate : 24.000000 Target Duration : 00:00:10 ----------------------- MediaInfo Audio Source 1 ----------------------- General Complete name : C:\TMP\XxXxXxXxXxX.1080p.x264.5.1.DTS_temp\XxXxXxXxXxX.1080p.x264.5.1.DTS ID1 English.mka File size : 0.00 Byte ------------------ Error Find Gain 1 using ffmpeg 4.1 ------------------ Find Gain 1 using ffmpeg 4.1 failed with exit code: 1 (0x1) The exit code might be a system error code: STATUS_WAIT_1 The exit code might be a system error code: Incorrect function. --------------------- Find Gain 1 using ffmpeg 4.1 --------------------- D:\Staxrip.2.0.0.1.Beta\Apps\Encoders\ffmpeg\ffmpeg.exe -i "C:\TMP\XxXxXxXxXxX.1080p.x264.5.1.DTS_temp\XxXxXxXxXxX.1080p.x264.5.1.DTS ID1 English.mka" -sn -vn -hide_banner -af volumedetect -f null NUL [matroska,webm @ 0000020a4b453900] Format matroska,webm detected only with low score of 1, misdetection possible! [matroska,webm @ 0000020a4b453900] EBML header parsing failed C:\TMP\XxXxXxXxXxX.1080p.x264.5.1.DTS_temp\XxXxXxXxXxX.1080p.x264.5.1.DTS ID1 English.mka: Invalid data found when processing input --------------------- Find Gain 1 using ffmpeg 4.1 --------------------- D:\Staxrip.2.0.0.1.Beta\Apps\Encoders\ffmpeg\ffmpeg.exe -i "C:\TMP\XxXxXxXxXxX.1080p.x264.5.1.DTS_temp\XxXxXxXxXxX.1080p.x264.5.1.DTS ID1 English.mka" -sn -vn -hide_banner -af volumedetect -f null NUL [matroska,webm @ 0000020a4b453900] Format matroska,webm detected only with low score of 1, misdetection possible! [matroska,webm @ 0000020a4b453900] EBML header parsing failed C:\TMP\XxXxXxXxXxX.1080p.x264.5.1.DTS_temp\XxXxXxXxXxX.1080p.x264.5.1.DTS ID1 English.mka: Invalid data found when processing input Start: 3:50:09 PM End: 3:50:09 PM Duration: 00:00:00 Start: 12:00:00 AM End: 3:50:10 PM Duration: 17691135:50:10
A Man Eating Duck Last edited by AMED; 13th March 2019 at 04:18. |
aac, hdr, hevc, nvenc, staxrip, x264, x265 |
