5th March 2017, 20:38 | #42861 | Link |
Any idea what causes my stuttering with x264 10bit content, same clip with x265 10bit plays fine
Render stats: x264 10bit www.imgur.com/LMdpoQl.png x265 10bit www.imgur.com/lrlqcBo.png |
5th March 2017, 20:48 | #42862 | Link | ||
The only reliable way I know is if your receiver or TV report the incoming bitdepth. Quote:
5th March 2017, 20:51 | #42863 | Link | |||
and the default is 10 bit if possible. if you are using a 1080p >TV< it is currently getting 10 bit. this is different with nvidia the option in the nvidia control panel doesn't really mean a lot. if the driver get's 10 bit from any software like madVR it is output 12 bit and 8 bit with 8 bit input. but i haven't tested this with nvidia in a long time. all this works on with windows 7... and be aware that only the some flagship screens are using true 10 bit panels. |
5th March 2017, 21:02 | #42864 | Link | |
How big is the difference in render times? Can you see a difference in the listed algorithms in the OSD? |
5th March 2017, 21:12 | #42865 | Link | ||
Here is another example : original : http://www.mediafire.com/file/z27qsd.../original2.png v0.91.1 : http://www.mediafire.com/file/1h6f9b17dvkt0v2/old2.png v0.91.6 : http://www.mediafire.com/file/jfvxw096d0fk60f/new2.png You can see in DiCaprio's eyes and all around them the gain in details and sharpness. You can also see it on the green trees behind him (at the right side of his face in the image). I also miss this. Even if I don't need it anymore, others may want it back. Last edited by Neo-XP; 5th March 2017 at 21:52. |
5th March 2017, 21:17 | #42866 | Link | |||
i'm used to about 36 ms with this version it is currently 40-53 ms Quote:
i will double check it with the old version. i found a file where it still works for some time so something is odd here and the resolution is the same. |
5th March 2017, 21:22 | #42868 | Link | |
Will do some further NGU AA tests tomorrow, but I'm very positive so far. Would it be possible to take a look at edge smoothing for NGU VH 4x at some time? A stronger smoothing effect would be helpful for low-res content that isn't extremely aliased and thus doesn't require NGU AA. The current smoothing solution for NGU VH 4x has a too weak effect. |
5th March 2017, 21:28 | #42869 | Link | |
Edit: Disabling D3D11 solved this, something wrong with s/w decoding + D3D11 fullscreen for me!
Specs: I7-6700K | GTX 1080 8GB | 16GB DDR4 | Last edited by eero94; 5th March 2017 at 21:33. |
5th March 2017, 21:50 | #42871 | Link | |||||||
Anyway, it doesn't matter too much, NGU Soft/Standard/Sharp will all change again soon. Quote:
Strange. Could be a GPU driver thing. |
5th March 2017, 22:19 | #42873 | Link |
Visual Novel Dev.
Hi @madshi!
I like the new upscaling refinement page! Not entirely sure if NGU AA low is equal with NNEDI 16 neurons quality wise, and I'm not entirely sure if it looks exactly the same so it might still be okay to keep it around if it's not too much effort. I mean, NNEDI looks good by itself, but NGU looks pretty good as well. This new version doesn't have PixArt installed within, no?
Visual Novels! https://www.facebook.com/seventh.heart.studios/ https://audiophile-heaven.blogspot.com/ https://www.youtube.com/watch?v=27VWU3ydRY8 |
5th March 2017, 22:47 | #42875 | Link |
I think the new image upscaling/doubling settings are a mess and difficult to interpret if you are a noob...way too many drop-down menus.
What is the difference between upscaling and doubling? Why am I able to double and quadruple the same image?
HOW TO - Set up madVR for Kodi DSPlayer & External Media Players Last edited by Warner306; 5th March 2017 at 22:50. |
5th March 2017, 23:28 | #42877 | Link | |
If they don't even understand the basic concepts being offered there (ie. what doubling means), it doesn't matter how the options look. The "let madVR decide" modes are already much easier then before.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 5th March 2017 at 23:43. |
5th March 2017, 23:41 | #42879 | Link |
I dont know what madvr settings to use. example, super-xbr ? Using amd 470 card.
I dont know why we need to choose between two extremes (win10 vs linux) when we can have both with a neat UI. Last edited by dioxholster; 5th March 2017 at 23:44. |
