Old 18th March 2017, 16:37   #221  |  Link
TheFluff
Excessively jovial fellow
Originally Posted by WolframRhodium View Post
However, as an example, some people has been widely using gauss for years, and this phenomenon will continue. How can you come down to your conclusion?
The Gauss resizer isn't even a resampler at all, mathematically speaking. As far as I can recall I don't think people really use it all that much for actually resizing things; they use it to blur things. Use something else for that.
Blackman is a bad windowed sinc; use lanczos instead.
Old 18th March 2017, 16:44   #222  |  Link
feisty2
I'm Siri
feisty2's Avatar
Originally Posted by TheFluff View Post
It's handled automatically, yes, assuming that the _Field or _FieldBased frame props are set correctly. Unlike Avisynth, VS (and zimg) understands that an interlaced clip that you call separatefields() on does not magically become progressive, so if you feed a field-separated clip to the internal resizer, resize it horizontally and then weave it again it'll still be handled correctly (there won't be any jumping up and down).
No. None of the extra ones are all that useful anyway.
gaussresize is more useful than you think, it could be used as a non-ringing convolution filter, and it's far more powerful than std.convolution, cuz:
a. it works with any radius (using the "taps" parameter)
b. it does not require you to manually calculate the coefficient matrix, you could simply control the filtering strength using the "p" parameter.
If I got new ideas, will post here: https://github.com/IFeelBloated
feisty2 is offline   Reply With Quote
Old 18th March 2017, 16:49   #223  |  Link
WolframRhodium
The combination of lanczos and gauss in upsampling is popular. But zimg doesn't have gauss, that's a problem.
Another example is feisty2's Vine/Plum.
WolframRhodium is offline   Reply With Quote
Old 18th March 2017, 16:58   #224  |  Link
TheFluff
Isn't that exactly what I said? Write an actual Gaussian convolution filter if that's what you want, instead of shoehorning it into a resampler-that-isn't.
Old 18th March 2017, 17:07   #225  |  Link
feisty2
I'm Siri
feisty2's Avatar
gaussresize is already highly optimized as a part of the resample function in fmtc, I could write a Gaussian filter any day of the week but I'm NOT a professional programmer, so that's gonna be a lot worse (performance-wise) than the existing gaussresize approach anyways, and I'm definitely not wasting my time just to mess with stupid things like that.
Old 18th March 2017, 17:31   #226  |  Link
WolframRhodium
What's more, fmtconv contains various dithering mode and custom resample kernel, but what about zimg?
Old 18th March 2017, 17:45   #227  |  Link
TheFluff
Dithering: Bayer pattern, random noise (magnitude 0.5) and Floyd-Steinberg are supported. Do you have any particularly convincing arguments as to why anything else is vastly superior? Having more options just for the sake of having more options is Avisynth mentality.
Custom convolution kernels: what is the actual practical use case for this? Is there any reason you can't just use a separate convolution filter?
I mean, yeah you can do a ton of interesting shit with a highly customizeable general-purpose FIR filter, but customization and flexibility is kinda hard to combine with ease of use, optimization and maintainability. If you want a filter that can do anything, it probably won't be very well suited to being a fast and reliable image resizer for real world inputs. The reason I'm trying to convince people to switch to zimg is that for 95% of the most common use cases it does what fmtconv does but is faster and easier to use. I know I told you to submit feature requests, but please keep them within the scope of what is reasonable to have in standard image resizer. For exotic stuff, write exotic filters.
Old 18th March 2017, 17:56   #228  |  Link
feisty2
I'm Siri
feisty2's Avatar
Having more (not significantly worse, like x86 is worse than x64, xp is wore than win10, so I never compiled x86 binaries or obsolete xp binaries for my plugins) options is always better, simply because people could ignore opinions they don't need, and anyone gets to choose what's useful to him/her (which is also why I love c++ and dislike java )
Old 18th March 2017, 17:56   #229  |  Link
WolframRhodium
dithering: “Filter Lite”. See madvr's thread for why someone love it
kernel: https://forum.doom9.org/showthread.php?t=166080
Old 18th March 2017, 18:11   #230  |  Link
TheFluff
You're wrong, and very predictably so. You will probably understand this when you have more experience, and I'm probably telling you this completely in vain because I think it's hard to actually internalize this before you've actually experienced it. I was wrong in exactly the same way when I was younger and I don't think anyone could have convinced me to understand that, back then.
More code (and hence more combinations of possible code paths) isn't free, it's bought with the most expensive resource of all - developer attention. More code paths means more tests and more maintenance. More complex code with more paths through it becomes harder to reason about, understand and predict. With more code, it becomes harder to change your mind, refactor and redesign.
You and I - and all other programmers - are much dumber than we'd like to think we are. Things need to be kept simple in order for us to be able to reasonably keep working with them.
Old 18th March 2017, 18:40   #231  |  Link
TheFluff
I'm sure a lot of madvr users love a lot of things but I care exceedingly little about them. Adding more dithering options is a pain in the butt and has basically no visible effect on output bitdepths >= 8. I myself sure as heck can't see any meaningful difference between madvr's different error diffusion modes with 8-bit output, and I definitely can't say which one looks better. If you want dithering because you want things to look nice on your shitty 6-bit monitor, then perhaps you should in fact dither on playback instead of trying to encode it into your (probably lossily compressed) video? Especially when dither pattern preferences are so subjective. Filter lite is also supposed to be faster but zimg's Floyd-Steinberg implementation is already really optimized so who cares.
Custom kernels is in a similar spot. Yes you can get marginally improved results in some ways on certain (mostly small) images, but almost nobody uses it and there are tradeoffs with every kernel. If you care about this kind of custom tweaking a standard resizer probably isn't right for you.
If you want fmtconv for its customizeability, you can keep using it! It's fine! It's just that for the vast majority of common use cases (like most of the ones posted in this thread) zimg does the same thing faster and with a bit less effort. That's all I'm saying.
Old 19th March 2017, 03:39   #232  |  Link
junh1024
I'll just leave this here:
Functionality is an ASSET.
Code is a LIABILITY.
(tldr so having the LEAST code that does the MOST stuff is desireable)
junh1024 is offline   Reply With Quote
Old 16th June 2017, 20:14   #233  |  Link
juhok
juhok's Avatar
Now on FreeBSD Ports! https://www.freshports.org/graphics/...synth-fmtconv/
juhok is offline   Reply With Quote
Old 14th November 2017, 20:42   #234  |  Link
MonoS
What is the correct way to downscale in linear light (gamma corrected) an HDR stream?
I tried to come up with a script, but i'm not so confident it is correct as i already screwed up multiple times in this regards
MonoS is offline   Reply With Quote
Old 17th January 2018, 15:40   #235  |  Link
fadedmaple
fadedmaple's Avatar
strange
Hi,I find a problem.When i use fmtc like this ,it will tell me "transfer: unsupported color family."
src16 = core.fmtc.bitdepth(src,bits=16)
UV = core.fmtc.resample(src16,1920, 1080, kernel="Spline36")
gray = core.std.ShufflePlanes(src16, 0, colorfamily=vs.YUV)
gray = core.fmtc.transfer(gray, transs="2020", transd="linear")
gray = core.fmtc.resample(gray, 1920, 1080, kernel="Spline36")
gray = core.fmtc.transfer(gray, transs="linear",transd="2020")
src = core.std.ShufflePlanes([gray,UV], [0,1,2],vs.YUV)
It works only when the colorfamily specified it with GARY 。
I am a noob in this , can explain why?THX
gray = core.std.ShufflePlanes(src16, 0, colorfamily=vs.GRAY)
fadedmaple is offline   Reply With Quote
Old 17th January 2018, 15:53   #236  |  Link
sneaker_ger
See fmtconv doc.
As input, the function accepts only RGB and grayscale colorspaces.
Old 17th January 2018, 16:35   #237  |  Link
fadedmaple
fadedmaple's Avatar
thanks
Originally Posted by sneaker_ger View Post
See fmtconv doc.
Thanks for you repley.
Maybe my expression is wrong,What is the difference between Y plane and GRAY?
Old 8th December 2018, 05:49   #238  |  Link
asarian
Speaking of resizing, if I want to downsize an UHD Blu-ray, would this be the best way to go about it?
core.std.LoadPlugin("DGDecodeNV.dll")
video = core.dgdecodenv.DGSource("i:/jobs/test.dgi", fulldepth=False)
vid = core.fmtc.resample (clip=vid, w=1920, h=1080)
Or does core.fmtc.resample need a special parameter, optimized for reduction?
Gorgeous, delicious, deculture!
asarian is offline   Reply With Quote
Old 8th December 2018, 06:39   #239  |  Link
Wolfberry
Helenium(Easter)
Wolfberry's Avatar
The default kernel of fmtconv is bicubic with b=c=1/3 a.k.a. "Mitchell-Netravali" which should be enough for normal use.
If you are using the dll from the official release, I will recommend to use the one from ChaosKing's FATPACK or the one in my signature as it is compiled with a newer compiler and might save you from random crashes.
Try muvsfunc's SSIM_downsample if you are not satisfied with the results of plain bicubic.
Monochrome Anomaly
Wolfberry is offline   Reply With Quote
Old 8th December 2018, 07:00   #240  |  Link
asarian
Cool. Thx.
