11th November 2010, 04:58 | #1 | Link |
xbox 360 compatible avi from blu-ray mkv
Have successfully converted from a blu-ray mkv but had some issues along the way.
First I tried ffmpeg ffmpeg -i input.mkv -threads 8 -acodec ac3 -ac 6 -ab 640k -vtag XVID -vcodec mpeg4 -sameq -maxrate 25000k -bufsize 5000k output.avi but the output resulted in out of sync audio/video when converting from DTS-HD audio and h.264 video from handbrake. so then I separated the files individually as I could not find another program to convert DTS-HD audio. for video ffmpeg -i input.mkv -threads 8 -an -vtag XVID -vcodec mpeg4 -sameq -maxrate 25000k -bufsize 5000k output.avi You need the rate limit or else or you xbox 360 will stutter try to replicate the quality of h.264. I choose the buffer randomly as I'm no expert since to it needs one to limit the rate. for audio ffmpeg -i input.mkv -vn -threads 8 -acodec ac3 -ac 6 -f ac3 -ab 640k output.ac3 I tried muxing them through avidemux but when I shared them through upnp on xbmc to my xbox 360 I could not fast forward. I muxed them instead through a wine set up of virtualdub and it worked perfect. I'm trying to figure out what the difference is so I can do it all under linux without wine. Anyone else have any feedback or another way let me know. You need to get to xvid avi or else you can't do surround sound with a 360 and my goal was to do this while losing as little quality as possible. My end result was a 9 gig file at full 1080P with Dolby Digital (although I counldn't check the channel mapping as I currently don't have a 5.1 system). |
11th November 2010, 11:05 | #2 | Link | |
ffmpeg -i video.avi -vcodec copy -i audio.ac3 -acodec copy output.avi |
12th November 2010, 09:08 | #4 | Link |
Then there's MEncoder. It has a tweakable A/V sync method, so it should work with some settings at least.
You could also try muxing with MEncoder. Last edited by nm; 12th November 2010 at 09:12. |
16th November 2010, 01:43 | #5 | Link |
When I try to use mencoder with ac3 I get Failed to open audio demuxer. I did the same when I put the ac3 in an avi container by itself. It does work fine with mp3 though. I did however get this to work. This is what I did.
for video ffmpeg -i input.mkv -threads 8 -an -vtag XVID -vcodec mpeg4 -sameq -maxrate 25000k -bufsize 5000k output.avi for audio ffmpeg -i input.mkv -vn -threads 8 -acodec ac3 -ac 6 -f ac3 -ab 640k output.ac3 mux step 1 avidemux --load video.avi --external-ac3 audio.ac3 --audio-map --save tmp.avi results in avi that can't be fast forward so final step mux step 2 mencoder -ovc copy -oac copy -mc 0 -noskip -o final.avi tmp.avi Result works perfect. A little overcomplicated and seems somewhat unnecessary but gets the job done. now just have to figure out how to hard code forced PGS subtitles and I should be off to the races with all my movies Last edited by boykillsworld; 16th November 2010 at 01:54. |
16th November 2010, 12:27 | #6 | Link | ||
But actually, I meant encoding everything with MEncoder, which should work with pretty much any version: Code:
mencoder -ovc lavc -oac lavc -channels 6 -lavdopts threads=8 -lavcopts vcodec=mpeg4:vqscale=3:vrc_maxrate=25000:vrc_buf_size=5000:acodec=ac3:abitrate=640 input.mkv -o out.avi Quote:
If language selection fails, try with -demuxer lavf or use -sid SID (where SID is a numerical ID printed by mplayer -v). You'll need a recent MEncoder version since PGS support was added last summer. Last edited by nm; 16th November 2010 at 12:30. |
19th November 2010, 02:05 | #7 | Link |
Running MEncoder SVN-r29978-4.4.1
Doing it in one step with mencoder resulted in no sound with stuttering video in xbmc didn't even bother with 360. I'm running ElementOS on my HTPC which is based off Ubuntu 9.10. I could not locate a more updated SVN on a PPA and compiling from scratch is a pain that I haven't experienced since Fedora 5. I'm going to stick with the couple extra commands. |
19th November 2010, 12:28 | #8 | Link | ||
sudo apt-get remove mplayer mencoder sudo apt-get install subversion sudo apt-get build-dep mplayer svn checkout svn://svn.mplayerhq.hu/mplayer/trunk mplayer cd mplayer ./configure make sudo make install Quote:
21st November 2010, 15:10 | #10 | Link | ||
What happens if you remux the output AVI with MEncoder like you did with the Avidemux output? Quote:
25th November 2010, 01:26 | #12 | Link |
Ok for subtitles this is what I did
first encode with mencoder and select sid for subs step 1 Code:
mencoder -ffourcc XVID -slang eng -ovc lavc -of lavf -lavfopts format=avi -oac lavc -channels 6 -lavdopts threads=8 -lavcopts vcodec=mpeg4:vqscale=1:vrc_maxrate=25000:vrc_buf_size=5000:acodec=ac3:abitrate=640 -sid SID movie.mkv -o movie.avi step 1 alt Code:
mencoder -ffourcc XVID -forcedsubsonly -ovc lavc -of lavf -lavfopts format=avi -oac lavc -channels 6 -lavdopts threads=8 -lavcopts vcodec=mpeg4:vqscale=1:vrc_maxrate=25000:vrc_buf_size=5000:acodec=ac3:abitrate=640 movie.mkv -o movietmp.avi Audio is out of sink and this is fixed with avidemux Code:
avidemux --load movietmp.avi --save movietmp2.avi Everything works fine except for some reason you can't fastforword with the 360 so Code:
mencoder -ovc copy -oac copy -mc 0 -noskip -o movie.avi movietmp2.avi Another thing I find strange is that mencoder and ffmpeg seem to be limited to 100% cpu usage but I have 4 cpus so it could use 400%. The 100% seems spread across the processors with the 8 threads but it would be nice to increase the encoding speed. Last edited by boykillsworld; 22nd December 2010 at 04:24. |
25th November 2010, 11:15 | #13 | Link | |
Edit: simple instructions to build MPlayer/MEncoder SVN with ffmpeg-mt git. Code:
sudo apt-get remove mplayer mencoder sudo apt-get install subversion git sudo apt-get build-dep mplayer # Get MPlayer svn checkout svn://svn.mplayerhq.hu/mplayer/trunk mplayer cd mplayer # Get ffmpeg-mt: git clone git://gitorious.org/~astrange/ffmpeg/ffmpeg-mt.git # Copy libswscale to ffmpeg-mt cp -a ffmpeg/libswscale ffmpeg-mt/ # Replace ffmpeg by ffmpeg-mt mv ffmpeg ffmpeg.orig mv ffmpeg-mt ffmpeg # Build MPlayer and MEncoder ./configure make # Install sudo make install Last edited by nm; 25th November 2010 at 14:03. |
27th November 2010, 02:10 | #14 | Link |
Compiled and installed fine but got a floating point exception when trying to use this with ffmpeg-mt so went back to standard ffmpeg. Adding threads worked ok though got me to 120% cpu usage and 18.5 fps. Its not so bad though as I encode 3 at once doing this at night.
Thanks for your help nm. |
21st December 2010, 07:45 | #15 | Link |
boykillsworld,
First of all, great work. I found your guide extremely useful. A buddy of mine and I came up with this script to sort of automate the process: Code:
#!/bin/bash # Used for transcoding files. # Arguments should be as follows: # $0 -i [required] -o <optional> $3 <optional> # transcode.sh original file new file name mencoder flags # Any deviation from the above shold report an error. cleanUp() { if [[ -f ${oFileTmp} || -f ${nFileTmp} ]]; then rm ${oFileTmp} ${nFileTmp} > /dev/null 2>&1 fi; } usage() { echo "Usage: transcode -i INFILE -o <NewFileName> <Additional MEncoder Parameters>..." } nFile="" nFileTmp="nTmp.avi" oFile="" oFileTmp="oTmp.avi" mencoderParameters="" decodeParameters="\ -ffourcc XVID \ -forcedsubsonly \ -subfont-text-scale 2 \ -ovc lavc \ -of lavf \ -lavfopts format=avi \ -oac lavc \ -channels 6 \ -ofps 23.976 \ -lavcopts vcodec=mpeg4:vqscale=1:vrc_maxrate=15000:vrc_buf_size=5000:acodec=ac3:abitrate=640:threads=6:cmp=2:subcmp=2:trell=yes:v4mv=yes:mbd=2 \ " encodeParameters="\ -ovc copy \ -oac copy \ -mc 0 \ -noskip \ " # Ensure proper usage if [ $# -lt 1 ]; then usage exit 1 fi # Parsing command line parameters. # -o specifies the name of the output file, other mencoder flags # are parsed and passed to mencoder. until [ -z "$1" ] ; do case "$1" in -o) oFile="$2" oFile=${oFile%.avi} shift ;; -i) nFile="$2" shift ;; -*) if [ "$2" = "-*" ]; then mencoderParameters="$mencoderParameters $1" else mencoderParameters="$mencoderParameters $1 $2" shift fi ;; *) echo "Unrecognized option: $1" usage exit 1 ;; esac shift done # Run some sanity checks. # Make sure we managed to get an input file. if [ -z "$nFile" ]; then echo "No input file specified." usage exit 1 fi # Make sure the file exists. if [ ! -f "$nFile" ]; then echo "Input file \"$nFile\" does not exist." usage exit 1 fi # If no outfile was specified, use the infile if [ -z $oFile ]; then oFile=${nFile} fi # Make it so we don't have a .mkv.avi filename. oFile=${oFile%.???} echo "Infile: $nFile" echo "Outfile: $oFile.avi" echo "MEncoder params: $mencoderParameters" # Do preliminary clean-up, can't hurt (in case things are left # sitting around from the last run... cleanUp # Note the use of && between commands to ensure execution completion # before moving on to the next command. While all of these must # complete sequentially, error checking isn't done between steps # at this time. It's just assumed you have permissions and space. echo "The following commands will be invoked:" echo - mencoder "${nFile}" ${decodeParameters} ${mencoderParameters} -o ${nFileTmp} && echo - avidemux2_cli --load ${nFileTmp} --save ${oFileTmp} && echo - mencoder ${encodeParameters} -o "${oFile}.avi" ${oFileTmp} mencoder "${nFile}" ${decodeParameters} ${mencoderParameters} -o ${nFileTmp} && avidemux2_cli --load ${nFileTmp} --save ${oFileTmp} && mencoder ${encodeParameters} -o "${oFile}.avi" ${oFileTmp} if [ $? -ne 0 ]; then echo "Conversation failed between mencoders & avidemux." exit 1 fi # Clean-up and exit. cleanUp exit 0 Since I'm running a wireless network at home, I don't have the luxury of streaming over the network. I dump the files onto a 2TB external USB harddrive that I've formatted with HFS+ (I love the irony of having a Mac OS filesystem hooked up to a Microsoft device) - this way I'm able to dump files >4 GB on it and the Xbox plays nice. Anyway, much appreciate the time and effort you put into figuring this stuff out. ~ A Last edited by Andevellicus; 21st December 2010 at 07:56. |
22nd December 2010, 04:17 | #16 | Link |
I'm glad someone got some use out of this.
I go through a month of trying to figure out how to do this and converted 10 movies. Then the new Call of Duty comes out and I RROD my Xbox. Granted I purchased it broken for $75 then X-clamp fixed it with Arctic Silver and got two years out of it. Guess that isn't bad for an Xbox from 2006. I'll see if I can bring it back to life during my Christmas vacation. I guess I'm not surprised if you had to rate limit it further. My original clips were previously compressed with handbrake which may have smoothed it out some. Your limit may be the result of a slow external drive also. I believe 100 mb/s ethernet is actually slower than usb 2.0, however, I think Microsofts implementation of HPS+ may be piss poor. Although, I do not know how you would ever prove this. I have a script similar to this for converting blu-ray. It grabs the largest video track then sends that through handbrake as a high profile mkv and muxes in all English audo and subtitles. I launch it from the record button on my remote control and it takes like 8 hours. Last edited by boykillsworld; 22nd December 2010 at 04:36. |
4th January 2011, 23:31 | #17 | Link |
Few more notes: Apparently the Xbox has some issues with ODML and improper indexing which can cause momentary stuttering as well as an inability to skip back after a certain point in the movie. Long story short, the work around is to include -noodml in the mencoder flags, and then to rebuild the ODML index explicity. Thus here are the commands that I issue:
This decodes the video sans ODML: Code:
mencoder "${nFile}" \ -noodml \ -ffourcc XVID \ -subfont-text-scale 3 \ -ovc lavc \ -of lavf \ -lavfopts format=avi \ -lavcopts vcodec=mpeg4:vqscale=1:vrc_maxrate=15000:vrc_buf_size=5000:acodec=ac3:abitrate=640:threads=8:cmp=2:subcmp=2:trell=yes:v4mv=yes:mbd=2 -oac lavc \ -channels 6 \ -ofps 23.976 \ -o ${iFileTmp} Explicitly rebuild the ODML index using the -idx option: Code:
mencoder ${iFileTmp} \ -ovc copy \ -oac copy \ -mc 0 \ -noskip \ -idx -o ${nFileTmp} Fix A/V sync: Code:
avidemux2_cli --load ${nFileTmp} --save ${oFileTmp} Ensure fast forwarding and rewinding: Code:
mencoder \ -ovc copy \ -oac copy \ -mc 0 \ -noskip \ -o "${oFile}.avi" ${oFileTmp} Replace ${nFile}, ${iFileTmp}, ${nFileTmp}, ${oFileTmp}, and ${oFile} with actual file names. Some of this is redundant (for instance I haven't bothered to see if instead of doing two mencoder copies I can just rebuild the index in the last step, but this works for me. Thanks again for all the help. ~ A |
360, mkv, xbox, xvid. linux |
