2nd July 2005, 10:31 | #22 | Link | |
clueless n00b
And all that is using the regular 32 bit version of Windows. There is not even a 64 bit version of x264 as far as I can recall. I guess I could go hunting for drivers and if everything is available, give the 64 bit version a shot.
2nd July 2005, 12:22 | #23 | Link |
any idea of encoding speed for divx6 @ 1080 res using telecide and decimate? thats the reason i'm getting one of these puppies my 2500+ sadly isn't up to the job
C2D E6600, Corsair Nautilus 500 W/C, D975XBX mobo 2x1GB PC6400 G.Skill ZX, 7950 GX2, 4x 74GB Raptor RAID-0, 750GB Seagate, 30" Dell 3007fpw |
2nd July 2005, 13:16 | #24 | Link |
clueless n00b
Only DivX Helium contains SMP optimizations
And we Euros don't even have 1080 sources to work with (well, extremely few and I'd need to get a PCI-E DVB-S card to capture something since the SN25P is PCI-E only (not that I'd want it any other way.. I wished DVD burner makers would release more SATA drives so I could disable IDE entirely and use only the SATA-II ports)). I've been studying the Anandtech benchmarks and made a startling discovery: the dual core tests, the FX-57 tests.. they don't all use the same media encoding benchmarks or use the same sources.. that is extremely deplorable as only using the exact same scenario really allows you to properly compare CPUs.
2nd July 2005, 19:52 | #26 | Link | |
2nd July 2005, 20:55 | #27 | Link |
@ Doom9
Have you tried overclocking your X2 ? I'm just curious how far it can go... I'm sure it may work absolutely steadily at 5000+ (and even beyond) without increasing the Vcore. Wouldn't it be nice? Last edited by Leo 69; 2nd July 2005 at 20:58. |
2nd July 2005, 20:58 | #28 | Link |
i think you can get the core's on a 4400 to 2.6-8 on air fairly easily. not sure about the 4600+
2nd July 2005, 21:09 | #29 | Link |
I'm going to buy a 4800+ when and if MSI finally releases a BIOS update for my board. I wonder if the 1mb of cache on the 4800+ makes a difference or not. I think it will when it comes to encoding.
2nd July 2005, 21:51 | #30 | Link |
clueless n00b
I have my doubts about the cache size.. so I saved the money and got for the smaller cache size.. cache sometimes helps but often it has no effect. I haven't tried overclocking.. it may reach 2.6 GHz easily but I've had 3 crashes so far (blue screen moving files over, freezes when burning DVDs), and until I'm convinced that the system is 100% rock stable I wouldn't even dream changing anything to non standard settings.
As far as the barebone goes, I consider it an improvement over the SN95, but we're definitely not there yet noise-wise.. I hope we'll get to a Dell 8400 level eventually.
2nd July 2005, 22:12 | #31 | Link | ||
2nd July 2005, 22:46 | #32 | Link |
clueless n00b
bah, that PC will go back to the shop.. 3rd freeze today, and the machine was under no particular stress.. not unlike when I got the last barebone, but there the problems ocurred more frequently. Either it's those high speed RAM modules that I also used last time (and that after making me wait for 4 weeks they replaced along with the MB), or the MBs are really prone to error
3rd July 2005, 00:05 | #33 | Link |
download ultimate boot cd (it's free)
run memtest of course and a couple of CPU stress testers cpu-burn in lucifer Mersenne Prime Test
www.mrbass.org DVDShrink | DVD2DVD | DVDFAB | Mac guides |
3rd July 2005, 02:11 | #34 | Link |
clueless n00b
I'm afraid I'll have to reconnect audio and use my "old" PC again tomorrow to run some tests.. not that I'd really have to.. I paid 100 bucks to have my PC assembled just so that in the error case I can throw it back in their face.. but it's always good knowing what's going on. Though the last time I ran memtest for hours upon hours, and switched out every component but the mainboard and CPU.. it was those last two parts. Since they changed RAM and MB last time and I have the exact same effects.. it might just be the MB yet again.. and my confidence in barebones is dropping again
3rd July 2005, 02:41 | #35 | Link | |
3rd July 2005, 04:04 | #36 | Link |
@doom9
i went onto shuttles website (i was looking to buy the SN25P), but nowhere did it mention support for dual cores, nor did it have any bios updates. either it already handles it, or poorly tries to. now that i've researched it and all, the lack of a PCI slot (wtf am i going to put into the PCIE 1x slot), compounded with your experiences with your system, which has very close specs to one i was going to put together, im holding off on the SN25P, or at least going to look into other SFF brands. thanks for your Dual Core stories. -sandman1687 |
3rd July 2005, 12:32 | #37 | Link | |
clueless n00b
As far as BIOS support, I think you missed this: http://global.shuttle.com/ADVNews/NewsDetail.asp?CTID={A69AC49F-B90C-445E-A412-560BA5F2A03D} The problems I'm having have nothing to do with dual core.. they're exactly the same I've had with the last barebone, which used the same kind of RAM. Last time they asked about my RAM timing.. (I built it myself them), this time they should've taken are of that. If it's RAM again I'll go back to regular stuff and forget about the high speed Kingston modules.
3rd July 2005, 13:25 | #38 | Link |
clueless n00b
well, I guess normally red is a bad sign, but memtest just came up with a load of red lines, so that's it.. faulty memory (again). And I figured the 100 bucks for assembly included a stress test which would've certainly prevented me from getting faulty components yet again.
@markrb: thanks for the tip on that CD.. it is extremely useful.
3rd July 2005, 17:02 | #40 | Link |
ah sorry about that.
how do you find MSI boards anyway? never tried them before
