Old 2nd August 2018, 09:29   #41  |  Link
unix
Is there ColorMask for vapoursynth?
unix is offline   Reply With Quote
Old 2nd August 2018, 10:24   #42  |  Link
ChaosKing
Yes, it's included.
(see long list in 1st post)
VapourSynth Portable FATPACK || VapourSynth Database || https://github.com/avisynth-repository
Old 2nd August 2018, 13:58   #43  |  Link
unix
But I couldn't find it (TColorMask)! ^^"
Old 2nd August 2018, 16:00   #44  |  Link
ChaosKing
Argh sorry, I read "colorbars" as "colormask" @1 post xD
But I was sure that I saw it somewhere ... https://github.com/DJATOM/VapourSynth-TColorMask
Edit: I tried to compile it with g++ (msys2) but got some warnings and vs editor doesn't open with my compiled plugin. Maybe someone has visual studio installed and could try to compile it.
Old 3rd August 2018, 11:55   #45  |  Link
unix
Thank you =)
Old 3rd August 2018, 12:59   #46  |  Link
WolframRhodium
Originally Posted by Pat357 View Post
I have a Nvidia GTX-1070 TI, which has all this.
What extra package do I need to install then ?
Some pre-compiled dlls from OpenCV with CUDA enabled are required, which I had lost them already.
I consider bilateral as a theoretically sound but not practical enough algorithm due to its high computational complexity. I prefer Guided Filter, Edge BMA Filter, LLSURE or other edge-preserving filters provided by OpenCV over bilateral filter.
WolframRhodium is offline   Reply With Quote
Old 3rd August 2018, 15:14   #47  |  Link
DJATOM
DJATOM's Avatar
It seems code requires correction, as T—MGetFrame and T—MFree should be TCMGetFrame and TCMFree. Weird thing that it passed compilation in VS2015. I'll fix and post release soon.
Upd: https://github.com/DJATOM/VapourSynt...eleases/tag/r1
Me on GitHub | My Telegram
PC Specs: Ryzen 3900X (no OC with 250W Air cooling), Asus ROG Crosshair Hero VII (WiFi) @ chipset x470, 32 GB RAM @ 3333MHz OC, Gigabyte RTX 2070, Kingston A1000 @ 240 GB
DJATOM is offline   Reply With Quote
Old 3rd August 2018, 18:57   #48  |  Link
ChaosKing
thx
Ahhh I changed T—MGetFrame to TNMGetFrame locally
Edit:
Made also a PR to vsrepo
Old 3rd August 2018, 20:33   #49  |  Link
DJATOM
DJATOM's Avatar
— is actually Russian С, and it placed on the same position as in English layout, that's why I didn't noticed. Shit happens.
Old 21st October 2018, 05:03   #50  |  Link
Selur
Selur's Avatar
Any plans for an updated version for Python 3.7 and Vapoursynth R45 ?
Old 21st October 2018, 08:59   #51  |  Link
ChaosKing
Yes, I just waited for R45 final.
Old 23rd October 2018, 13:24   #52  |  Link
ChaosKing
New release with Python 2.7.1, VS R45 and some new scripts.
Old 24th October 2018, 00:30   #53  |  Link
WorBry
Just checked out VapourSynth Portable FATPAK. Don't seem to be able to open the scripts in VirtualDub2 (64bit) for encoding - 'AVI Import Error' - so I assume that, like Myrsloik's portable version, output is VSPipe only ?
https://forum.doom9.org/showthread.p...99#post1753199
Nostalgia's not what it used to be
WorBry is offline   Reply With Quote
Old 24th October 2018, 09:28   #54  |  Link
ChaosKing
VirtuabDub opens the files in a different way. You could try to extract vdub inside the VapourSynth64 folder (where python.exe is). But I think this won't work. I will test it later myself.
Old 24th October 2018, 10:31   #55  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
It needs a registered VFW handler in the registry. So no. Unless you manually add that and go otherwise portable.
Myrsloik is offline   Reply With Quote
Old 24th October 2018, 13:24   #56  |  Link
ChaosKing
@Myrsloik, these are the only reg entries that are necessery to get it to work in vdub, correct?
https://github.com/vapoursynth/vapou...aller.iss#L176
Old 24th October 2018, 13:35   #57  |  Link
Myrsloik
Myrsloik's Avatar
Yes yes YEEEEEEEEEES (this message is now long enough)
Old 21st November 2018, 23:16   #58  |  Link
ChaosKing
Added seek-test MOD https://www.dropbox.com/s/45pqnaslap...-test.zip?dl=1
Its basically seek-test from here https://gist.github.com/dubhater/3a2...ae25cd47ff78d2 with some argparse code + AVISource.
Just extract into root folder and drag&drop your video onto the bat file.
Reliability tester of VapourSynth Source Filters - seek test
Setting End to 100 frames
Press 1 for FFMS2000
      2 for L-SMASH-Works
      3 for D2V Source
      4 for AVISource
Number: 1
ffms2
Clip has 101 frames.
Hashing: 100%
Clip hashed.
Requested frame 0, got new frame with hash fb37336400e36e64070c1ca795fa62d8.
    Previous requests: 98 14 66 61 75 54 41 77 26 86 0
Seeking: 100%
Test complete. Seeking issues found :-(
Old 25th November 2018, 03:42   #59  |  Link
Blovesx
Hello,
Could I get a script from someone who's knowledgable with VapourSynth concerning waifu2x? I'm actually learning, playing and teaching how to use .avs, x264 all the options what they do, mean as well as plugins for AviSynth. My head is already about to explode from all the informations. Someone can be so kind and post me a script ready to use with waifu2x? I will set the settings by myself just learning another thing right now will be just too much. I don't know how this Vapour thing works but can I use the plugin simply to resize my video without the need to encode it again?
I have files ready from converting a DVD trough AviSynth to .mp4 format using x264 so can I just resize my video without the need to re-encoding it again?
Blovesx is offline   Reply With Quote
Old 25th November 2018, 05:19   #60  |  Link
Selur
Selur's Avatar
Here's an example script here WaifuX is used to resize a 640x352 clip to 1280x704:
# Imports
import vapoursynth as vs
core = vs.get_core()
# Loading Plugins
core.std.LoadPlugin(path="I:/Hybrid/64bit/vsfilters/ResizeFilter/Waifu2x/Waifu2x-w2xc.dll")
core.std.LoadPlugin(path="I:/Hybrid/64bit/vsfilters/Support/fmtconv.dll")
core.std.LoadPlugin(path="I:/Hybrid/64bit/vsfilters/SourceFilter/FFMS2/ffms2k.dll")
# Loading F:\TestClips&Co\files\test.avi using FFMS2K
clip = core.ffms2.Source(source="F:/TESTCL~1/files/test.avi",cachefile="E:/Temp/avi_078c37f69bb356e7b5fa040c71584c40_41.ffindex",format=vs.YUV420P8,alpha=False)
# making sure input color matrix is set as unspec
clip = core.resize.Point(clip, matrix_in_s="unspec",range_s="limited")
# making sure frame rate is set to 25/1
clip = core.std.AssumeFPS(clip, fpsnum=25, fpsden=1)
# Setting color range to TV (limited) range.
clip = core.std.SetFrameProp(clip=clip, prop="_ColorRange", intval=1)
# resizing clip to 1280x704
# adjusting bit depth to 32bit
clip = core.fmtc.bitdepth(clip=clip,bits=32)
# resizing using Waifu2x
clip = core.w2xc.Waifu2x(clip=clip, scale=2)
# adjusting bit depth back to 8bit
clip = core.fmtc.bitdepth(clip=clip,bits=8)
# Output
clip.set_output()
if uses ffms2k as source filter and fmctconv to convert to 32bit and bach to 8bit.
Filters always lie inside a separate folder on my systems so I don't rely on auto-loading, but load each filter manually.
Not really. In Vapoursynth and Avisynth you first use a source filter to open a (or multiple) source file, filter it and output raw video, so you normally would want to reencode the output of that script one way or the other.
Cu Selur
