Old 30th July 2016, 13:52   #41  |  Link
feisty2
I'm Siri
feisty2's Avatar
Originally Posted by ~SimpleX~ View Post
Oh, well, it doesn't. I have i7 2600k, which is Sandy Bridge.
then you have to compile a compatible binary yourself, auto compiling files for GCC are provided with the source code
If I got new ideas, will post here: https://github.com/IFeelBloated
feisty2 is offline   Reply With Quote
Old 30th July 2016, 21:15   #42  |  Link
kolak
Is there a real gain in quality due to such a high precision implementation?
Old 31st July 2016, 07:46   #43  |  Link
feisty2
I'm Siri
feisty2's Avatar
guess there's quality gain more or less, but mainly for being free of clamping (more mathematically correct) in floating point format rather than higher precision
Old 31st July 2016, 12:29   #44  |  Link
kolak
I've tried it and have not seen any "real" difference.
Old 31st July 2016, 20:10   #45  |  Link
feisty2
I'm Siri
feisty2's Avatar
you might not see any "real" difference between int8 and int16 most of the time, not to even mention int16 and float32
I started this for my OCD about placebo precision, wanted it to be as mathematically correct as possible, but the actual reason that makes this useful is there're HDR videos out there, HDR videos contain colors even brighter than white or even darker than black, and integers couldn't handle stuff like that, and floats could.
Old 1st August 2016, 12:15   #46  |  Link
kolak
I'm not trying to say your work is worthless.
Nothing wrong with having options as there may be cases when it may be useful (as you already mentioned).
Old 3rd August 2016, 16:18   #47  |  Link
feisty2
I'm Siri
feisty2's Avatar
r5
Bug Fixes
1. truemotion was corrupted(bug inherited from jackoneill's branch), fixed.
2. the SATD implementation was completely incorrect, did some research and rewrote that from the beginning, SATD works correctly now
Old 3rd August 2016, 16:25   #48  |  Link
feisty2
I'm Siri
feisty2's Avatar
@~SimpleX~
r5 features no SIMD extension, try it and it will probably not crash this time
Old 4th August 2016, 00:13   #49  |  Link
~SimpleX~
I've made some stupid compatibility layer for mv and mvsf (mvmulti, 8..32 bit support, incomplete function set). Maybe it would be useful for someone.
~SimpleX~ is offline   Reply With Quote
Old 4th August 2016, 00:40   #50  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
You should check sample_type, not the number of bits
Myrsloik is offline   Reply With Quote
Old 4th August 2016, 07:50   #51  |  Link
~SimpleX~
Missed that part, thanks! Updated.
Old 4th August 2016, 08:41   #52  |  Link
feisty2
I'm Siri
feisty2's Avatar
theoretically you cannot expand DegrainN to the partial sum of a series like ∑[x=1, y](DegrainRadius[x] * P[x]) (∑[x=1, y]Radius[x] = N, ∑[x=1, y]P[x]=1), it works but the result is very different from DegrainN
         mv123 = core.mv.Degrain3(clip, super, *v[:6], **kwargs)
         mv456 = core.mv.Degrain3(clip, super, *v[6:], **kwargs)
         sm = core.std.Merge(mv123, mv456, 0.4615)
is poles apart from mvsf.Degrain6, and you should not obfuscate them in your "degrain" function.
edit: made the statement more rigorous
Old 4th August 2016, 11:23   #53  |  Link
~SimpleX~
I took that code from MCTemporalDenoise. I'd love to have Degrain at least up to 6 in jackoneill's plugin, but for now... Maybe I should remove that part completely and stick to Degrain1..Degrain3 for integral samples?
Old 4th August 2016, 11:29   #54  |  Link
feisty2
I'm Siri
feisty2's Avatar
remove it, definitely, nothing wrong with this approach, it's just DIFFERENT from how DegrainN works in mvtools and you should never obfuscate different stuff together like they are the same stuff..
Old 24th October 2016, 15:06   #55  |  Link
feisty2
I'm Siri
feisty2's Avatar
r6:
new block sizes: 2x2, 64x64, 64x32, 128x128, 128x64, 256x256, 256x128
switched to fftw3.3.5
Old 7th November 2016, 21:07   #56  |  Link
groucho86
Hi feisty2,
I'm using BlockFPS to get to a lower FPS (29.97i to 59.94p via QTGMC then to 23.976p) using this code :
clp = core.fmtc.bitdepth(clip,bits=32,fulls=False,fulld=True)
super = core.mvsf.Super(clp,pel=4,hpad=16,vpad=16,rfilter=4)
bw_1  = core.mvsf.Analyze(super,isb=True,blksize = 16,overlap=0,search=3,badrange =-24)
fw_1  = core.mvsf.Analyze(super,isb=False,blksize = 16,overlap=0,search=3,badrange =-24)
clp = core.mvsf.BlockFPS(clp, super, bw_1, fw_1, num=24000, den=1001, blend=False)
clp.set_output()
The video freezes about halfway through. I wonder if it's similar to the problem that was fixed in jackoneill's version.
groucho86 is offline   Reply With Quote
Old 19th December 2016, 10:30   #57  |  Link
feisty2
I'm Siri
feisty2's Avatar
r7
Bug Fix
fixed a clip length calculation bug in BlockFPS, reported by groucho86
New Feature
extended SATD to 64x64 128x128 and 256x256 blocks
Uncategorized
replaced Hadamard ordered SATD with the Sequency ordered variant, levels faster..
Old 3rd January 2017, 19:34   #58  |  Link
Mystery Keeper
Beyond Kawaii
Mystery Keeper's Avatar
Could you please do Mask too? I found it can be used to limit the destructive effect of temporal denoising.
...desu!
Mystery Keeper is offline   Reply With Quote
Old 4th January 2017, 07:43   #59  |  Link
feisty2
I'm Siri
feisty2's Avatar
will do that for the next update
Old 9th February 2017, 08:35   #60  |  Link
feisty2
I'm Siri
feisty2's Avatar
r8
New Feature
mvsf.Mask
Uncategorized
converted some ugly C89 style code to C++14 style
