Old 6th September 2012, 18:30   #41  |  Link
Bloax
The speed of stupid
Bloax's Avatar
Crf 19.25 would probably do. ('Tis why you mess around with it.)
Bloax is offline
Old 6th September 2012, 18:39   #42  |  Link
Groucho2004
Funny. I call your 19.25 and raise you 0.03.
Groucho's Avisynth Stuff
Groucho2004 is offline
Old 6th September 2012, 18:54   #43  |  Link
detmek
Originally Posted by zmejce View Post
Yep, x264 is better than DivX even with lower birate.
x264 @ 13.3Mbps with the MPC-HC filters it looks almost like the Blu-Ray.
Which commands I should use for the command-line x264 and vdub?
I saw this from Handbrake 0.9.5 High Profile:
ref=2:bframes=2:subq=6:mixed-refs=0:weightb=0:8x8dct=0:trellis=0
I don't want to use Psychovisual or such effects, and I want the file to be at about 15Mbps.
Also when I set command-line encoder in vdub, is the procedure the same (File->Save as->avi)?
If not, then how?
1. In VirtualDub folder create new folder "External encoders" and put all exe files and dependencies in that folder.
2. In Options - External encoders set an encoders, something like this:
For x264:
Command arguments: --crf 20 --tune film --b-adapt 2 --direct auto --demuxer raw --input-csp i420 --input-res %(width)x%(height) --fps %(fpsnum)/%(fpsden) -o "%(tempvideofile)" -
Output filename: %(outputname).264
For neroaac:
Command arguments: -q 0.4 -ignorelength -if - -of "%(tempaudiofile)"
Output filename: %(outputname).m4a
For mkvmerge:
Command arguments: -o "%(outputname)" --default-duration 0:%(fpsnum)/%(fpsden)fps "%(tempvideofile)" "%(tempaudiofile)"
and create encoder sets by combining video, audio and muxer presets.
3. You start encoding with File - Export - Using external encoder.
detmek is offline
Old 6th September 2012, 23:22   #44  |  Link
zmejce
Thank you, I'll try that
zmejce is offline
Old 8th September 2012, 14:12   #45  |  Link
zmejce
detmek, do you recommend the same x264 settings for dvd-ripping?
or they are just for hd?
I'm asking because when I'm ripping DVD's with handbrake and High profile x264, it produces a very smooth image (DivX is better in that case).
zmejce is offline
Old 8th September 2012, 14:57   #46  |  Link
detmek
For DVD rip I would go with CRF 18.
But, I don't like smooth images. I prefer to preserve fine details so Divx/Xvid is not my choice.
If you want smoother image remove --tune film. You could use some denoiser/smoother in VirtualDub or add --nr xxx (where xxx is in 100-1000 range) to use x264 internal denoiser. Changing deblock to 1:1 or 2:2 will also smooth image.
Try and see what you like.
detmek is offline
Old 8th September 2012, 15:16   #47  |  Link
zmejce
Ok, thanks, I'll try it these days.
zmejce is offline
Old 8th September 2012, 16:52   #48  |  Link
zmejce
detmek, and which settings for dvd's that are already ripped to divx 2000kbps (they have excellent quality)?
zmejce is offline
Old 8th September 2012, 17:08   #49  |  Link
Groucho2004
You should really use your original DVDs.
Old 8th September 2012, 19:31   #50  |  Link
Bloax
The speed of stupid
Bloax's Avatar
If you don't want a smooth image, you should probably try --tune Grain, which both adjusts AQ to prefer noise, and reduces the deblocking strength.
Bloax is offline
Old 8th September 2012, 20:53   #51  |  Link
detmek
I wouldn't recommend you to reencode those files.
As
If you still want to reencode those rips use the same settings as for original DVDs, except denoising part. Divx rips are already smooth.
detmek is offline
Old 9th September 2012, 03:31   #52  |  Link
zmejce
detmek, some videos I might need to transcode, ex. 720x480 tv caps downloaded from internet (there's no dvd released) and they are encoded to divx ~2000kbps.
And what should I do to remove automatic deblocking-sharpening filter on x264 command-line which you posted above?
zmejce is offline
Old 9th September 2012, 03:38   #53  |  Link
Closing for rule 6 violation.
http://forum.doom9.org/forum-rules.htm
Further violations may lead to strikes.
Guest is offline
2012, divx, tests, x264, xvid
