#1641 | Link |
Uh i run into more Bug i guess...
I have a Stream from German PayTV (Sky Disney Cinemagic HD). Ive tested the Stream already for errors. They are none (according to DVR-Studio HD2 and TSDoctor) On processing with DGIndexNV 2011 i get the message: Found NALU Type 16, len 8231909 undefined, ignore NALU, moving on... It doesnt matter what i click then.. DGindexNV crashed badly. (Yes to Continue reporting, No to disable, ...) I cannot Process this Stream. I Try again with the 32Bit Version but i guess it will be the same... Edit: Yep 32bit Version same error and crash. Chris Last edited by MOS-Marauder; 13th June 2010 at 15:14. |
#1643 | Link | |
Well u should know what Your Tool outputs (Error Msgs). The Problem is: that error happenes in the 2nd Half of a 8 GB FIle. So the only way then would be to upload it complete... but where? Chris |
#1645 | Link | |
I know what my program outputs, but I need to determine if it is a program bug or a stream problem, and to do that I have to be able to recreate the problem. As I clearly stated:
Do you really think I can do anything about that without a sample stream to reproduce the issue? Quote:
#1648 | Link |
Build 2012
* Fixed a problem that could cause the source filters to hang if the last picture
in the stream is incomplete (due to bad editing). * Implemented film % detection for AVC video. * Silently ignore leading frames that are missing their required SPS/PPS's. * Fix a problem that caused AVC sequence extensions to be reported as illegal NALUs. * Fix a problem that caused seeking on the timeline in DGIndexNV to report failure to create the video decoder for some low-end NV cards. http://neuron2.net/dgdecnv/dgdecnv.html |
#1649 | Link | |
Load the stream. Find the place where it happens. Make a project range for some space before and after the bad point. Do File/Output Trimmed TS. Upload the resulting stream to mediafire.com and post the link here. Please be sure to have a good amount of stream before the error point. |
#1650 | Link | |
Finally i managed it... I havent noticed that there is a Save Trimmed Option yet *G* I used 2012 for it.. and guess what? it showed that NALU Msg but then didnt crash anymore. (rechecked with 2011 - crash) The Error will show up in the middle of the File. http://www.mediafire.com/download.php?o2wo24yjnld Chris Last edited by MOS-Marauder; 14th June 2010 at 10:58. |
#1652 | Link | |
Now that u say it... i also see it .So if i want to use it i have to cut that part out ? Seems a Decoding Glitch from Sky. If i use it like it is, i can create the DGI but on Encoding later it stops at that point. Chris |
#1657 | Link |
Acid fr0g
Using x64 build with MEGUI_x64. Everything works fine!
Thanks Neuron! P.S: About auto crop - Usually it is better to avoid horizontal cropping to avoid resizing on full hd LCD. Should you put a feature in mod buttons such as 1st press horizontal crop, 2nd press vertical crop, 3rd both?
@turment on Telegram |
#1659 | Link |
Feature requests
Couple of feature requests:
1. Add a debug option (like 'info=1' in DGMPGDec). 2. Have an option to auto-resize pixels based on the aspect ratio info in the video stream (if present), i.e. aspect_ratio_information in a MPEG2 stream |
#1660 | Link |
Acid fr0g
The point is that sometimes only a few pixels lack to reach 1080 (i.e. they are black) and DGIndex crops them. Usually it is better to keep them not to get the video resized when playing.
| Thread Tools | |
| Display Modes | |
