#825 | Link |
Other topic: Has anyone every tried to tunnel *all* FindVUK down/uploads (including DNS) via Tor?
I'm not really that experienced with Windows ... and a quick Google search didn't show any "official"/trusted solutions to tunnel all through Tor. |
#826 | Link |
Big Bit Savings Now !
TOR = The One Ring...
The One to find them, The One to bind them, The One to rule them all ? Not.
#827 | Link |
@Emulgator
https://www.torproject.org/ |
#828 | Link | ||||
who is why, and why is who:
"To bypass shortcuts and find suffering...is called QUALity" (Die toten Augen von Friedrichshain) "Data reduction ? Yep, Sir. We're that issue working on. Synce invntoin uf lingöage..." Last edited by Emulgator; 29th August 2024 at 01:36. |
#830 | Link |
FindVUK seems to fail on every disc validation with 13.0.2.5 when I try it. Rolling back to 13.0.2.4 seems to at least fix this issue for the first disc validation thought it sometimes fails on subsequent disc inserts. Usually, cancelling and re-running FindVUK for the affected disc seems to address the issue.
#832 | Link | |
Proxy Support in FindVUK
Recently I've been looking whether FindVUK can be taught to use a proxy (mostly for Tor, see above). By chance I've noticed that FindVUK seems to recognise the Code:
http_proxy If you set it to something (like localhost:9150) where nothing listens, Find VUK fails e.g. with downloading from the DB. I've asked Nalor via PM, and got the hint that this is not implemented by FindVUK itself but probably the language it's written in. It actually supports also other proxy types (not only HTTP): https://www.purebasic.com/documentat...httpproxy.html Quote:
btw: For Tor, care must be taken to use the right proxy type, especially with respect to DNS. Also, I haven't checked whether FindVUK really uses this everywhere (i.e. for all uploads/downloads)... if you need to be sure, you should check yourself. |
#838 | Link |
All of the download links for FindVUK are dead. Running the Synchronize script gives these errors:
# 23 # [I] FindVUK_Main / / Update enabled - check for update # 933 # [W] update / UPD_CheckUpdateAndDownload / Incorrect release information found >< >< >< # 933 # [W] FindVUK_Main / / Update check failed >#UPD_ERR_READFILE< |
#840 | Link | |
I'm using DVDFAB 13.0.2.7 to get VUK of a UHD disk and got this message.
Using 13.0.2.6 simply says my firmware is not supported and cannot even make it to get unit keys. Looking forward to updating. Please PM me if you need the dump file. Log file is attached. Quote:
