Old 10th June 2023, 13:03   #1  |  Link
Rob105
Use custom variable with ConditionalReader()
How to make this work so box_width is read from box_width.txt right now its fixed on value 70 regardless what ConditionalReader outputs 130.
PHP Code:
v1 colorbars(1920,1080).converttoyuy2()
box_width 70
#Make box overlay
box BlankClip(width=box_widthheight=130color=$000000).AddBorders(5,5,5,5,color=color_white)
#place overlay in video
Overlay(v1boxx=740y=600)
ConditionalReader("C:\Users\User\Downloads\AVISynth\box_width.txt""box_width"true
Rob105 is offline   Reply With Quote
Old 11th June 2023, 17:41   #2  |  Link
Gavino
Avisynth language lover
ConditionalReader() is for setting the value of a variable on a per-frame basis, so that the variable can be used inside another run-time filter such as ScriptClip().
But here you are using the variable box_width only to set the width of the blank clip, which happens at compile-time, before any frames are read.
You can get the effect you want by putting the required value (eg 130) as the only contents of the file and setting the variable by adding
box_width = Import("box_width.txt")
at some point before the call to BlankClip().
(And of course in addition removing the call to ConditionalReader()).
