Old 17th January 2020, 03:26   #1  |  Link
ShowTextFiles.avs - Show textfiles on blank video
This may or may not be a useful utility, posted as I would have found it of use. [Is real tedious to view 10,000 text files in a Notepad style app]
# ShowTextFiles.avs
    Req RT_Stats, v1.43+, Grunt.
    Scan directory of text files, showing first few lines of each file on frame [original intent to aid recovery of accidentally deleted text files from 10,000 possible recovered txt files].
    Outputs list of Files with SearchWord found to DebugView, even when DEBUG=False
DIR = ".\recup_dir.1"        # Directory to scan, or if DO_FSEL then Initial directory in File Selector
WildCard="*.txt"        # Pipe Separated Wildcards, eg "*.txt|*.csv"
W=1024        # Frame Width
H=720        # Frame Height, 1st ((Height/20)-2) lines are shown on frame, top 2 lines show filename and Searchword Found frame when activated.
FPS=100.0        # Returned clip FPS, suggest 2.0 if not using SearchWord, or 100.0 if known Searchword present.
DO_FSEL = False        # Use FileSelector if true, best use VDub2. [DONT use in AvsPMod, although might now be fixed, dont know]
SEARCHWORD="Galaxy Note"        # If eg SearchWord contained in first ((Height/20)-2) Lines then will hi-lite shown text in YELLOW ("" = no search) Best use VDub2 if searchword.
FULLSEARCH=True        # If true, search entire file, not just the visible lines shown on frame.
DEBUG=False        # Debug info to DebugView (Google)
myName="ShowTextFiles: "
Global Found = -1        # Searchword most recent found frame number.
Global FoundCnt=0        # Count of searchWord finds
FPS=FPS.Float
DIR = RT_GetFullPathName(DIR)
DIR = (DO_FSEL) ? RT_FSelFolder("Select Directory to scan for files",dir=DIR,Debug=true) : DIR
(DEBUG) ? RT_DebugF("Directory=%s",String(DIR),name=myName) : NOP
Assert(!DIR.IsInt || DIR!=0, "RT_FSelFolder: User Cancelled Directory Select")           # User Cancelled
Assert(!DIR.IsInt, "RT_FSelFolder: Error="+String(DIR))                                  # Some other error
TEMP = RT_GetSystemEnv("TEMP")
TempList=TEMP + "\~" + RT_LocalTimeString + ".tmp"
(DEBUG) ? RT_DebugF("TempList=%s",TempList,name=myName) : NOP
FileCnt = RT_WriteFileList(DIR + "\" + WildCard,TempList)                                # Text files found
(DEBUG) ? RT_DebugF("FileCnt=%d",Filecnt,name=myName) : NOP
Assert(FileCnt>=0, "RT_WriteFileList: Error writing file list")
Assert(FileCnt>0, "RT_WriteFileList: No Files found")
BlankClip(Length=FileCnt,Width=W,Height=H,fps=FPS)
ARGS="TempList,SearchWord,FullSearch,Debug"
SSS = "ShowTextOnFrameFn(" + ARGS + ")"
Last.ScriptClip(SSS,args=ARGS,Local=True)                                                # Req Grunt
Return last
Function ShowTextOnFrameFn(clip c,String TempList,string SearchWord,Bool FullSearch, Bool Debug) {
    c
    myName="ShowTextOnFrameFn: "
    n=current_frame
    DoSearch=SearchWord!=""
    LinesMax     = Height/20                                                             # Max lines of text from file, to show on frame.
    (DEBUG) ? RT_DebugF("%d] TemplList=%s LinesMax=%d",n,TempList,LinesMax,name=myName) : NOP
    Fullname = RT_ReadTxtFromFile(TempList,Lines=1,Start=n).RT_TxtGetLine                # Get line with text filename and strip n/l
    Node = FullName.RT_FilenameSplit(12)                                                 # Name node + Extension
    (DEBUG) ? RT_DebugF("Node=%s",Node,name=myName) : NOP
    Lines = RT_FileQueryLines(FullName)                                                  # Lines of text in target text file
    (DEBUG) ? RT_DebugF("Lines=%d",Lines,name=myName) : NOP
    GetLines = Max(Min(LinesMax-2 , Lines),0)                                           # Limited number of lines to read
    (DEBUG) ? RT_DebugF("GetLines=%d",GetLines,name=myName) : NOP
    Sometext = (GetLines>0)?RT_ReadTxtFromFile(FullName,Lines=GetLines,Start=0):""      # Read first few lines of text file
    (DEBUG) ? RT_DebugF("SomeText=%s",SomeText,name=myName) : NOP
    ShortFound = (DoSearch && !FullSearch) ? (RT_FindStr(Sometext,SearchWord,Sig=False,Pos=1)>0)  : false                         # RT_FindStr returns 0 on Not Found.
    Longfound  = (DoSearch && FullSearch && Lines>0)  ? (RT_FileFindStr(FullName,SearchWord,Sig=False,Pos=1,Start=0,Lines=Lines)>=0) : false # RT_FileFindStr returns line number [0 is possible line number]
    IsFound=(ShortFound || LongFound)
    (DEBUG) ? RT_DebugF("ShortFound=%s LongFound=%s SomeText='%s'",ShortFound,LongFound,SomeText,name=myName) : NOP
    Global FoundCnt = (IsFound) ? FoundCnt+1 : FoundCnt                                  # Update FoundCnt
    Global Found = (IsFound) ? n : Found                                                 # Update to most recent found position
    (IsFound) ? RT_DebugF("%d/%d] Foundcnt=%d %s\n%s\n**************************************************\n",n,Framecount-1,FoundCnt,Node,SomeText) : NOP
    return (Found<0)
        \ ? RT_Subtitle("%d/%d] \a!%s\a-\n\n%s",n,Framecount-1,Node,SomeText)
        \ : RT_Subtitle("%d/%d] \a!%s    \a6%d SEARCHWORDS FOUND, Latest  @ %d\a%c\n\n%s",n,Framecount-1,Node,FoundCnt,Found,(Found==n)?RT_Ord("6"):RT_Ord("-"),SomeText)
EDITED:
SearchWord Found
EDIT: Should be Avs v2.58 compatible.
EDIT: I've managed to find 2 of the 3 missing files, so far, 19 more directories of files to scan [already manually deleted many files that were way too large, 9000+ files to go].
EDIT: Added, Outputs list of Files with SearchWord found to DebugView, even when DEBUG=False
Shows current Found Count. and latest Found frame, to both Frame, and DebugView.
If you are sure search word will be found, can bump up the FPS to 100.0 or so, and watch clip or output of DebugView.
EDIT: Added, FULLSEARCH to config.
Dont look like I'm gonna find the 3rd missing file (cant remember what was in it).
EDIT: Recovered files were recovered using PhotoRec [part of TestDisk recovery package], Photorec scans the recovered txt files to ascertain that they contain only text, not binary,
and gives them a generated filename [where not known] and a .txt extension.
TestDisk:- https://www.cgsecurity.org/wiki/TestDisk
PhotoRec:- https://www.cgsecurity.org/wiki/PhotoRec
TestDisk on wikipedia:- https://en.wikipedia.org/wiki/TestDisk
PhotoRec on wikipedia:- https://en.wikipedia.org/wiki/PhotoRec
Old 17th January 2020, 06:52   #2  |  Link
Above scipt updated.
Found Bug in RT_stats v1.43 and latest RT_Stats v2 Beta,
RT_FileFindStr(String FileName,string FndS,bool "Sig"=True,int "Pos"=1,int "Start"=0,int "Lines"=0)
 Finds unnamed string 'FndS' in 'FileName' text file, starting at line 'Start' and searching 'Lines' number of text lines.
 FileName: Name of a file containing text to search.
 FndS: is a string and will be considered terminated early at the first carriage return [Chr(13)] or newline [Chr(10)], carriage returns
 and newlines will not be findable using this function.
 Sig: Default=True, does case significant comparison, insignificant if false.
 Pos: Default=1, is the character start position in an individual line of text to start searching for the FndS string.
   Allows you to skip search on first Pos-1 characters within all lines of text.
   If Pos less than 1, then will return -ve number (usually -1), Not Found.
 Start: Default 0, is the 0 relative starting line where the searching begins in the text file.
 Lines: Default 0(all lines). Number of lines text to seach, starting at 'Start' line.
 A -ve return is 'Not Found'. On success returns the line number of the first instance of a found string in the Start and Lines
  range of lines. An empty "" FndS will always return -ve result, ie Not Found.
 see RT_FileQueryLines, to inquire number lines in a text file.
 see RT_ReadTxtFromFile to extract a range of lines from a text file.
 NOTE, Character position 'Pos' is 1 relative whereas multi-line line 'Start' index is 0 relative.
  Care must be taken if mixing RT_FindStr and RT_TxtFindStr or RT_FileFindStr, RT_FindStr returns 0 on error, the other
 two return -ve on error(0 denoting valid line zero).
With FULLSEARCH=True in above script, and a zero length text file, will return 0 (line number zero) result, where it should return -ve error, not found.
I have fixed the bug in the above script, and will update RT_Stats dll's soon.
Script bugfix in Blue.
    c
    n=current_frame
    return (Found<0)
EDIT: Bug did not fire any wrong detections for any of ~10,000 text files, I just tried creating a dummy null length text file to test, and it failed (showed Searchword detection).
I have rarely used RT_FileFindStr() in existing scripts, maybe 2 or 3.
EDIT: Recovered files were recovered using PhotoRec [part of TestDisk recovery package, selecting to recover only .txt files], Photorec scans the recovered txt files to ascertain that they contain only text, not binary,
and gives them a generated filename [where not known] and a .txt extension. PhotoRec would likely not even try to recover 0 length files as they are likely not
detected as txt files, so did not produce any problem producing recovered files.
recovery
