#2061 | Link |
Matroska find' ich toll
Hi clsid
Since when can MPC-HC process the ProjectionPoseRoll element and rotate the video? My test file from the Matroska Playback repo is suddenly rotated correctly. The test version at the time was 1.8.6 and it didn't work there. |
#2062 | Link |
Parsing of the element was added to LAV 0.75.1 (mid 2021), all you need after that is a video renderer that can perform rotations based on the metadata.
#2065 | Link |
A 2D image does not rotate around those axis.
#2067 | Link |
Its a 2D image, you want to rotate it into a third dimension, with a 2D video renderer. Why? Cameras don't record like this, displays dont show like this, renderers dont render like this.
#2069 | Link |
MediaInfo.dll in MPC-HC.2.0.0.138.x64.zip
Just FYI, the MediaInfo.dll inside the MPC-HC.2.0.0.138.x64.zip development build is the 32 bit version. The one installed by MPC-HC.2.0.0.138.x64.exe is the proper 64 bit flavor.
And as always, thank you greatly for your continued work on this. Edit - now fixed. Last edited by Cutterkin; 17th September 2023 at 19:33. |
#2070 | Link |
Rotate a frame in MKV
I found a problem with rotation.
I used the following command. Code:
ffmpeg -display_rotation 90 -i "movie.mp4" -y -c copy movie90.mp4 ffmpeg -display_rotation 90 -i "movie.mp4" -y -c copy movie90.mkv MPC-HC and MPC-BE rotate the MP4 frame counterclockwise (same as ffplay.exe), but rotate the MKV frame clockwise. Is there a bug in MPC-HC and MPC-BE or in FFmpeg?
MPC-BE 1.6.10 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource |
#2072 | Link | |||
Element Specifications > ProjectionPoseRoll Quote:
Therefore, we read the notes. Specification Notes > Rotation Quote:
If I understood everything correctly, then support for frame rotation for MKV in MPC-BE and MPC-HC is done incorrectly.
#2073 | Link |
Oh yes, you are right.
What a inaccurate description LOL. You could ask Steve for better text there. I'm also confused now. I can understand the counter-clockwise method but we have positive and negative values and this changes the direction too. Negative value plus counter-clockwise = clockwise? Before ProjectionPoseRoll element there was the Tags method and there was only positive values for a clockwise rotation. 90 means clockwise rotation and why should now value 90 with ProjectionPoseRoll a counter-clockwise and -90 is then the clockwise rotation? really weird. |
#2074 | Link |
I tried to look at the ffmpeg code, but its written very confusingly. One path negates the rotation, the other one doesn't, it doesn't use the defined helper functions to get the rotation but calculates it itself for some reason or another.
From my understanding of the wording of it, I would think that the ffmpeg code is at fault here, because the forward vector of an image should be coming out of the image towards the user? But its a very weird way to describe it without an example or reference file to confirm.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 24th September 2023 at 13:11. |
#2075 | Link |
Big Bit Savings Now !
Coming from most physic rules, (and geometry does see ccw as positive too) the right-hand rule should imply that:
If thumb points to viewer (positive values assumed), then index finger would point ccw for positive Z-rotation values. (hope I did not screw that one up ;-)
#2076 | Link |
Update yt-dlp
MPC-HC 2.1.2 |
#2078 | Link |
Provide a sample.
Any other people with same problem?
MPC-HC 2.1.2 |
