#62 | Link |
hi pinterf, since you work on mvtools, dogway said that denoising chroma with luma only vectors is bugged
See My Avisynth Stuff |
#64 | Link | |
!chroma ? Assert(plane==0, "Denoising chroma with luma only vectors is bugged in mvtools and thus unsupported") : nop()
#66 | Link |
I have run the script you linked
chroma=false plane=4 super_search=MSuper(chroma=chroma?true:(plane==0?false:true)) bv2=super_search.MAnalyse(isb = true, delta = 2,chroma=chroma) bv1=super_search.MAnalyse(isb = true, delta = 1,chroma=chroma) fv1=super_search.MAnalyse(isb = false, delta = 1,chroma=chroma) fv2=super_search.MAnalyse(isb = false, delta = 2,chroma=chroma) MDegrain2(super_search, bv1, fv1, bv2, fv2, thSAD=200,plane=plane) Since I had to deal with the code, did it seriously and unified the MDegrain1/2/3 code for better understanding. It became much more general and a bit faster (at least for MSVC). As a result of generality: now we have a new MDegrain4 and MDegrain5. Note that MDegrainN still exists but if there are no special extra SAD parameters, it calls MDegrain1/2/3. No change, it did call them before - but now calls MDegrain4 and MDegrain5 for tr=4 or 5. (Reason by the docs: because they are faster). Then I became curious whether I can make mvtools co-operate with the latest avs+ dev build, so went on. I had already made MSuper work for 16 bit in the past. The analyzation parts (b and f vectors) still work at 8 bits (haven't ported yet MAnalyze), but MDegrain1/5 can use a 16 bit input and 16 bit super clip and the output is also native 16 bits Code:
a=Avisource("Hi8.avi").assumefps(25,1).trim(0, 499) a=a.ConvertToYUV444() sup = a.MSuper(pel=1) #pel=2 fv1 = sup.MAnalyse(isb=false, delta=1, overlap=4) bv1 = sup.MAnalyse(isb=true, delta=1, overlap=4) fv2 = sup.MAnalyse(isb=false, delta=2, overlap=4) bv2 = sup.MAnalyse(isb=true, delta=2, overlap=4) fv3 = sup.MAnalyse(isb=false, delta=3, overlap=4) bv3 = sup.MAnalyse(isb=true, delta=3, overlap=4) fv4 = sup.MAnalyse(isb=false, delta=4, overlap=4) bv4 = sup.MAnalyse(isb=true, delta=4, overlap=4) fv5 = sup.MAnalyse(isb=false, delta=5, overlap=4) bv5 = sup.MAnalyse(isb=true, delta=5, overlap=4) sup16=a.ConvertBits(16).MSuper(pel=1) a.ConvertBits(16).MDegrain5(Sup16, bv1, fv1, bv2, fv2, bv3, fv3, bv4, fv4, bv5, fv5, thSAD=10000). Info() ConvertBits(8, dither=0) And the last info: Earlier last week I have found some more YV12/YUY specific codes (x/2) in MFlow/MFlowFPS, which may have issues at YV24 in 2.7.0.22d. I hope these occurences were the last ones of this type. PS: no release, just status report Last edited by pinterf; 26th September 2016 at 21:54. Reason: clarify no release |
#70 | Link | |
first, I edit the SMDegrain to accept this case the sample http://rgho.st/private/64kh5qQPS/203...c92d8518f840c5 here frame 55 without filter http://i.imgur.com/24VWm23.png and here with SMDegrain(chroma=false) http://i.imgur.com/fIkzlH1.png
#71 | Link |
Ok, here is my script
FFMS2("chroma.mp4") #ConvertToYUV444() chroma=false plane=4 # 0:Luma 1:U 2:V 3:UV 4:All #ConvertBits(12) #10-16 #super_search=MSuper(chroma=chroma?true:(plane==0?false:true)) super_search=MSuper(chroma=true) bv1=super_search.MAnalyse(isb = true, delta = 1,chroma=chroma) fv1=super_search.MAnalyse(isb = false, delta = 1,chroma=chroma) a=MDegrain1(super_search, bv1, fv1, thSAD=0,plane=plane) b=MDegrain1(super_search, bv1, fv1, thSAD=200,plane=plane) c=MDegrain1(super_search, bv1, fv1, thSAD=2000,plane=plane) Stackvertical(a,b,c)#.GreyScale() # bigger thSAD: more "false" blocks but not in greyscale #MShow(super_search, bv1) #uncomment to see vectors #super_search #uncomment to see super clip #ConvertBits(8) Uncomment the MShow line above the see those vectors. What I also recognized that the blotchy artifacts occur when the luma-only sad is minimal. Check frame 49, lower right corner. MDegrain is in work, it blends frame #50 into that. You can check it best at the thSAD=2000 clip. (3rd one if using the above stacked script) When you uncomment grayscale conversion, it seem to be ok. I think this kind of clip needs fine-tuning. |
#72 | Link | |
#73 | Link | |
MDegrain makes its decision on comparing this precomputed sad value (per block) with the given thSAD parameter. The position of the artifacts is seen exactly at those places where the luma value (check the greyscale clip) is very similar between the compared - e.g. current - next_by_1 - frames. I think that in this case the SAD of the block (based on luma data only) is well below the given thSAD threshold,thus the blocks are getting blended together. If the difference (SAD) is minimal, then the similar blocks are practically averaged (more or less). So based only by the luma, it happens that two completely differently colored blocks are merged. Although they differ on the chroma very much, but we asked MAnalyze to ignore it with chroma=false. And we can see the result: one block of the current frame is orange, the next frame contains a blueish grey block at the same place, their luma is similar; the resulting block will look nice in greyscale, but the chroma - and our visual feelings - will be somewhat mixed. At least this is what I have learned from the code itself and the usage experiences so far. |
#74 | Link | |
maybe with good chosen of Search parameter in MAnalyze will make it better
#75 | Link |
After having released the first real test build of high bit depth Avisynth+, here is another release:
MvTools2 2.7.1.22 Important note: Built with VS2015, this build is 3-8% slower than previous ICC build. Don't use it if you stuck at YV12 or YUY2 clips and this speed loss makes you unhappy. Changes:
Demo script (avs+): Code:
SetMemoryMax(6000) FFMS2("prores_yuv422p10le_hq_apch_yuv422p10.mov").RemoveAlphaPlane() #if YUVA original ConvertBits(14) ConvertToYUV444() sup = MSuper(pel=1) #pel=2 fv1 = sup.MAnalyse(isb=false, delta=1, overlap=4) bv1 = sup.MAnalyse(isb=true, delta=1, overlap=4) fv2 = sup.MAnalyse(isb=false, delta=2, overlap=4) bv2 = sup.MAnalyse(isb=true, delta=2, overlap=4) fv3 = sup.MAnalyse(isb=false, delta=3, overlap=4) bv3 = sup.MAnalyse(isb=true, delta=3, overlap=4) fv4 = sup.MAnalyse(isb=false, delta=4, overlap=4) bv4 = sup.MAnalyse(isb=true, delta=4, overlap=4) fv5 = sup.MAnalyse(isb=false, delta=5, overlap=4) bv5 = sup.MAnalyse(isb=true, delta=5, overlap=4) MDegrain5(Sup, bv1, fv1, bv2, fv2, bv3, fv3, bv4, fv4, bv5, fv5, thSAD=10000). Info() ConvertBits(8,dither=0) Last edited by pinterf; 20th October 2016 at 19:57. |
#76 | Link |
sure this is right? with
PHP Code:
also seems to be slower
powered by Google Translator Last edited by Motenai Yoda; 22nd October 2016 at 01:27. |
#77 | Link | |
2.) Then I don't understand the second part. You make a d=Dither_convert_8_to_16() from an already stacked clip, and take its lsb that is always zero and filter it, why? Code:
l=d.dither_get_lsb() supL = l.Msuper(pel=1) lsb= l.MDegrain2(SupL, bv12, fv12, bv22, fv22, thSAD=200) Code:
FFMS2("chroma.mp4")#.trim(0, 499) orig8=last ConvertBits(16) sup = MSuper(pel=1) #pel=2 fv1 = sup.MAnalyse(isb=false, delta=1, overlap=4) bv1 = sup.MAnalyse(isb=true, delta=1, overlap=4) fv2 = sup.MAnalyse(isb=false, delta=2, overlap=4) bv2 = sup.MAnalyse(isb=true, delta=2, overlap=4) MDegrain2(Sup, bv1, fv1, bv2, fv2, thSAD=200) converttostacked() stackedresult1 =last orig8 sup2 = MSuper(pel=1) #pel=2 fv12 = sup2.MAnalyse(isb=false, delta=1, overlap=4) bv12 = sup2.MAnalyse(isb=true, delta=1, overlap=4) fv22 = sup2.MAnalyse(isb=false, delta=2, overlap=4) bv22 = sup2.MAnalyse(isb=true, delta=2, overlap=4) stackedResult2 = orig8.MDegrain2(Sup2, bv12, fv12, bv22, fv22, thSAD=200,lsb=true) mt_makediff(stackedresult1,stackedresult2,u=3,v=3) levels(100,1,155,0,255,true) Last edited by pinterf; 23rd October 2016 at 21:58. Reason: Comparison script |
#78 | Link | |
2- that is the way I use mdegrain on stacked clip, indeed lsb filtered part is all 0 if the input clip's lsb is all 0 btw I found a lot of differences even with your method, in the msb part too...
powered by Google Translator |
#79 | Link | |
For 16 bit input, even if the original clip is 8 bits and its straight 16 bit conversion has zero lsb, the lower resolution subclips in Super are already interpolated and have meaningful lsb parts. So the vectors after MAnalyze are possibly different than it would be estimated from a single 8 bit source. Then the weighting and blending inside MDegrain works with higher precision than for a 8 bit input. That is a difference, too. |
#80 | Link |
speaking of MAnalyze, I have an idea in my mind but I don't know if it good or not, or even if I can do it
it's for 8 bit clip, it's by doing convert to yv24 (if it not yv24) then merge Y, U and V in one 16 bit plane (Y16) then use it in MAnalyze to get more accurate motion vectors and then use the vectors for both luma and chroma
