1st June 2006, 09:50 | #1082 | Link |
Moderator, Ex(viD)-Mascot
I'm having some uneasiness about the naming of parameters in the profiles XML files. The parameter 'LumiMasking' seems to be deprecated if this would mean XviD's lumimasking; actually 'AdaptiveQuant' triggers XviD's lumimasking AKA adaptive quantization. Strange, as AdaptiveQuant doesn't seem to be an xvid_encraw input option AFAIK. If one of the parameters is for XviD and one of them for x264, this should perhaps be made more clear?
Also, activating chroma optimization and HQ AC coefficients in the GUI doesn't seem to have any effect; they're not encraw options either, I think.
It's a man's life in Doom9's 52nd MPEG division. "The cat sat on the mat." ATM I'm thoroughly enjoying the Banshee - a fantastic music player/ripper for Linux. Give it a whirl! Last edited by Teegedeck; 1st June 2006 at 11:24. |
1st June 2006, 10:26 | #1084 | Link | |
1st June 2006, 13:06 | #1085 | Link | |
Brazilian Anime Ripper
Capture cards: Compro VideoMate Gold+ (Philips SAA7134 based) (not active) Hauppauge PVR 150MCE (not active) ATI TV Wonder Elite (active) |
1st June 2006, 15:03 | #1086 | Link | |
aka Rabomil
Fixed in version 0.2.3.2160 |
1st June 2006, 16:57 | #1087 | Link |
Here is the log in version 2160 with autoencode in AVI container (XVID encoder) with "pre-rendering job" checked.
I think that the problem is with the frame index. The video is playing like a corrupted file that don't have all indexes. If I mux in Virtualdub or Virtualdub mod the problem is not occuring. Generating jobs. Desired size: 103809024 bytes No audio encoding. Calculating desired video bitrate directly. Encoded audio file is present: C:\encodes\2006-04-01\ygh1.mp3 It has a size of 18241280 bytes. Setting video bitrate for the video jobs to 595 kbit/s Setting desired size of video to 84911104 bytes Starting job job7-1 at 10:47:52 encoder commandline: "C:\encodes\ygh1.AVS" -o "C:\encodes\hfyu_ygh1.avi" -of avi -forceidx -ovc lavc -lavcopts vcodec=ffvhuff:vstrict=-2red=2:context=1 successfully started encoding Processing ended at 11:13:43 ---------------------------------------------------------------------------------------------------------- Log for job job7-1 MEncoder dev-CVS-060515-06:00-4.0.3 (C) 2000-2006 MPlayer Team CPU: Intel Pentium 4/Celeron D Prescott; Pentium D/XE Smithfield; Xeon Nocona,Irwindale (Family: 15, Stepping: 1) CPUflags: Type: 15 MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 0 SSE2: 0 Compiled for x86 CPU with extensions: MMX MMX2 SSE success: format: 0 data: 0x0 - 0x76f AVS file format detected. VIDEO: [YV12] 320x240 12bpp 23.976 fps 0.0 kbps ( 0.0 kbyte/s) [V] filefmt:38 fourcc:0x32315659 size:320x240 fps:23.98 ftime:=0.0417 Opening video filter: [expand osd=1] Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1 ========================================================================== Opening video decoder: [raw] RAW Uncompressed Video VDec: vo config request - 320 x 240 (preferred colorspace: Planar YV12) VDec: using Planar YV12 as output csp (no 0) Movie-Aspect is undefined - no prescaling applied. videocodec: libavcodec (320x240 fourcc=48564646 [FFVH]) Selected video codec: [rawyv12] vfm: raw (RAW YV12) ========================================================================== New_Face failed. Maybe the font path is wrong. Please supply the text font file (~/.mplayer/subfont.ttf). subtitle font: load_sub_face failed. Writing header... ODML: Aspect information not (yet?) available or unspecified, not writing vprp header. Writing header... ODML: Aspect information not (yet?) available or unspecified, not writing vprp header. ODML: Starting new RIFF chunk at 1023MB. Flushing video frames Writing index... Writing header... ODML: Aspect information not (yet?) available or unspecified, not writing vprp header. Video stream: 7659.493 kbit/s (957436 B/s) size: 1091530940 bytes 1140.056 secs 27334 frames This is a CQ job so there's no desired bitrate. Obtained video bitrate: 7665 kbit/s ---------------------------------------------------------------------------------------------------------- Job completed successfully and deletion of intermediate files is activated job job7-1 has been processed. This job is linked to the next job: job7-2 Starting job job7-2 at 11:13:43 encoder commandline: -i "C:\encodes\hfyu_ygh1.avs" -pass1 "C:\encodes\hfyu_ygh1.stats" -bitrate 595 -kboost 100 -overhead 0 -turbo -vhqmode 4 -closed_gop -imin 1 -imax 31 -pmin 1 -max_bframes 2 -bvhq -bmin 1 -bmax 31 -threads 2 successfully started encoding Processing ended at 11:18:14 ---------------------------------------------------------------------------------------------------------- Log for job job7-2 xvid_encraw - raw mpeg4 bitstream encoder written by Christoph Lampert 2002-2003 Trying to retrieve width and height from input header Input colorspace is YV12 xvidcore build version: xvid-1.1.0-beta2 Bitstream version: 1.1.-125 Detected CPU flags: ASM MMX MMXEXT SSE SSE2 TSC Detected 0 cpus, using 2 threads. Tot: enctime(ms) =75864.00, length(bytes) = 68907796 Avg: enctime(ms) = 2.78, fps = 360.33, length(bytes) = 2520 I frames: 353 frames, size = 14825/5233509, quants = 2 / 2.00 / 2 P frames: 9726 frames, size = 5513/53624217, quants = 2 / 2.00 / 2 B frames: 17255 frames, size = 582/10050070, quants = 4 / 4.00 / 4 ---------------------------------------------------------------------------------------------------------- Job completed successfully and deletion of intermediate files is activated job job7-2 has been processed. This job is linked to the next job: job7-3 Starting job job7-3 at 11:18:14 encoder commandline: -i "C:\encodes\hfyu_ygh1.avs" -pass2 "C:\encodes\hfyu_ygh1.stats" -bitrate 595 -kboost 100 -overhead 0 -vhqmode 4 -closed_gop -imin 1 -imax 31 -pmin 1 -max_bframes 2 -bvhq -bmin 1 -bmax 31 -threads 2 -avi "C:\encodes\Yu-Gi-Oh.avi" successfully started encoding Processing ended at 11:28:31 ---------------------------------------------------------------------------------------------------------- Log for job job7-3 xvid_encraw - raw mpeg4 bitstream encoder written by Christoph Lampert 2002-2003 Trying to retrieve width and height from input header Input colorspace is YV12 xvidcore build version: xvid-1.1.0-beta2 Bitstream version: 1.1.-125 Detected CPU flags: ASM MMX MMXEXT SSE SSE2 TSC Detected 0 cpus, using 2 threads. Tot: enctime(ms) =442944.00, length(bytes) = 84758772 Avg: enctime(ms) = 16.20, fps = 61.71, length(bytes) = 3100 I frames: 353 frames, size = 23753/8385101, quants = 1 / 1.00 / 1 P frames: 9722 frames, size = 6617/64335391, quants = 1 / 1.91 / 3 B frames: 17255 frames, size = 697/12038252, quants = 2 / 3.69 / 5 N frames: 4 frames, size = 7/ 28 desired video bitrate of this job: 595 kbit/s - obtained video bitrate (approximate): 599 kbit/s ---------------------------------------------------------------------------------------------------------- Job completed successfully and deletion of intermediate files is activated Found intermediate output file 'C:\encodes\hfyu_ygh1.stats', deleting... Deletion succeeded.Found intermediate output file 'C:\encodes\hfyu_ygh1.avi', deleting... Deletion succeeded.Found intermediate output file 'C:\encodes\hfyu_ygh1.avs', deleting... Deletion succeeded.job job7-3 has been processed. This job is linked to the next job: job7-4 Starting job job7-4 at 11:28:31 encoder commandline: -v "C:\encodes\Yu-Gi-Oh.avi" -a "C:\encodes\2006-04-01\ygh1.mp3" -o "C:\encodes\Yu-Gi-Oh-muxed.avi" successfully started encoding Processing ended at 11:28:50 ---------------------------------------------------------------------------------------------------------- Log for job job7-4 DivXMux: Version 6.1 Build Num: 36 Output File Streams: TrackId 0: Video Stream: From AVI Frame Rate: 23.976024 Resolution: 320x240 TrackId 1: Audio Stream: From MP3 SamplesPerSec: 48000 BlockAlign: 1 Creating Index... ---------------------------------------------------------------------------------------------------------- Job completed successfully and deletion of intermediate files is activated
3rd June 2006, 12:39 | #1088 | Link |
Megui build 2161
I have a problem with encodage audio (same ND AAC and MP3) here is the log : Starting job job1 at 13:16:22 encoder commandline: successfully started encoding Processing ended at 13:34:35 ---------------------------------------------------------------------------------------------------------- Log for job job1 Channels=2, BitsPerSample=16, SampleRate=48000Hz D:\Dvd\Encoder\MeGUI\tools\neroaacenc\neroaacenc.exe -ignorelength -q 0.4 -if - -of "E:\DVD\TEST T01 3_2ch 448Kbps DELAY 0ms.mp4"Error: System.AccessViolationException: Tentative de lecture ou d'écriture de mémoire protégée. Cela indique souvent qu'une autre mémoire est endommagée. à MeGUI.AviSynthClip.dimzon_avs_destroy(IntPtr& avs) à MeGUI.AviSynthClip.cleanup(Boolean disposing) à MeGUI.AviSynthClip.System.IDisposable.Dispose() à MeGUI.AviSynthAudioEncoder.encode() |
3rd June 2006, 13:09 | #1089 | Link | |
HDConvertToX author
@AstaRoth
no problem here with same megui build Quote:
maybe a reboot could help. BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
3rd June 2006, 17:21 | #1091 | Link | |||
aka Rabomil
NTSC-DVD sync problem
3rd June 2006, 19:18 | #1093 | Link |
HDConvertToX author
@parcival
are you sure ? i have searched my hd for this dll and i haven't found it, but i have encoded several audio tracks with CT encoder BHH
3rd June 2006, 19:35 | #1094 | Link |
clueless n00b
@Teegedeck: there might be a bunch of xvid options that made sense for mencoder and no longer make sense for encraw. I must admit I just checked what encraw could do and added that the commandline generator and I did not check it against GUI options. So if you change an option and the commandline preview doesn't change, unless it's an actual bug the option has been deprecated and should be removed.
3rd June 2006, 21:36 | #1096 | Link |
HDConvertToX author
@foxyshadis
thanks ! time to upgrade my winamp ! BHH
3rd June 2006, 23:29 | #1097 | Link | |
BluRay Maniac
5th June 2006, 01:38 | #1099 | Link | |
Banned
So, if anyone can post link for download nscrt.dll and tell me exact path where to copy this file, it will be very nice. |
