#3041 | Link | |
Acid fr0g
My request was originated by the large amount of time and processing required by BM3D for the block matching. I am just curious to know if results could be better or not.
@turment on Telegram |
#3042 | Link | ||
![]() Quote:
#3043 | Link | |
Here's the reasoning about the basename for the call. Basically there are a few Deblock functions, so the basename was to determine from which plugin it came. Basically load a blocky source and try with this: Code:
Deblock_deblock(quant=24,aOffset=1,bOffset=2)
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread |
#3045 | Link | |
![]() Last edited by LouieChuckyMerry; 2nd February 2025 at 02:21. Reason: Redundancy |
#3046 | Link |
Hi... I have a problem with qtgmc+...
This is my script: QTGMCp(Preset="Placebo", TR0=2, TR1=2, TR2=0, Rep0=7, Rep1=7, Rep2=7, DCT=5, SourceMatch=3, Lossless=1, MatchPreset="Placebo", MatchPreset2="Placebo", MatchEnhance=1.0, MatchTR2=2, EZKeepGrain=1.0, Sharpness=0.2, Sbb=3, ThSCD1=250, ThSCD2=95, NoiseProcess=0, SMode=2, SLMode=4, Subpel=4, Search=5, PelSearch=7, SearchParam=7, Overlap=8, EdiMode="EEDI3CL+NNEDI3CL", Ediqual=2, ChromaMotion=True, TrueMotion=true, Precise=True, NNeurons=4) When I use the same script on the old QTGMC with EdiMode="EEDI3+NNEDI3CL" (mix cpu and gpu) and Edithreads=16, I have a speed of 25fps. When I use the complete script on qtgmc+ with EdiMode="EEDI3CL+NNEDI3CL" (total gpu) but without edithreads=16 (because in qtgmc+ edithreads is not accepted), I have 2fps encoding speed. Yesterday I removed one by one all the setting in my script and I found that this occur only when I use Sourcematch... If delete Sourcematch the speed go at 30fps... Please can you tell me why this occur and can you give me the latest version of qtgmc+ with edithreads? Or do you have some other solution for me? Also, what are the maximum values for rep0 rep1 and rep2? |
#3047 | Link | ||
#3048 | Link |
[QUOTE=Selur;2017056]https://github.com/Dogway/Avisynth-S.../QTGMC%2B.avsi, there is no edithreads, it's called Threads here.
Yes, I know, but I am searching for an older version of qtgmc+ after 4.0, like 4.0p with edithreads (if exist) |
#3050 | Link |
@salvo00786, can you check the speed in qtgmc+ when using full cpu "EEDI3+NNEDI3"?, Try also setting 'Threads' to 16, and then without the setting (defaults).
If it goes slow, then play with the 'Threads' value in this line in ResizersPack. https://github.com/Dogway/Avisynth-S...Pack.avsi#L997 GPU versions ignore 'Threads' as usual. From what I recall mixing cpu and gpu in heavy scripts create some race conditions that harm performance. I typically run GPU when they are like 2 (maybe 3 max) simple filters in line.
#3051 | Link |
Fighting spam with a fish
Hello Dogway, thank you so much for your work on ExTools, etc.
I'm currently reading though some of your blurring functions, and I have a few questions just to ensure that I'm understanding things properly. Looking at your ex_median("smart"), it looks like you're processing a 3x3 grid. You take the average of the surrounding 8 pixels, and then use a sorting network on the same 8 pixels. What I'm not totally clear on is what's being stored in the "E^ D^ H^" variables near the end. I see that you are storing some part of the sorting network into these variables and then popping them off the stack before you conduct some squared differences using what's left on the stack and then what's stored in H. So in short, what do the E, D, and H variables contain, and what's left on the stack that's being used for the first squared difference with the average? Edit: I *think* D and E hold the 4th smallest/largest pixel values in the 3x3 grid, and the stack and H hold the 3rd smallest/largest pixels, respectively. Do I have that right?
Site:Adubvideo Zsmooth - Cross-platform smoothing for Vapoursynth Zscene - Scene change detection for Vapoursynth Last edited by Adub; 21st April 2025 at 21:29. |
#3052 | Link | |
So the end of the sorting network is like this: 4 3 (unordered) 3 4 (ordered) Pop 4 (max as E), 3 (min as D), and 3 (unordered, as H), consume 4 for the substraction, then 3 (H now) for the second substraction. Check davidhorman tool here. https://horman.net/expr_sort.php. Select 8 inputs, then checkboxes for 3 and 4. EDIT: I see you are making ZSmooth, one the missing pieces of my project was implementing mt_hysteresis (it's very slow), because that needs to be done on a robust language, maybe you can give it a try.
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread Last edited by Dogway; 22nd April 2025 at 03:35. |
#3053 | Link |
Ahhh got it, I was close but a little off the mark. Thank you for the thorough explanation.
The one last thing I'm not sure I understand is the squared difference logic. I understand the order of operations, but it's more of the "why" that I'm lacking depth on. It seems to be a key part of the the "variance" calculation, but I haven't quite groked what its doing yet. Put another way, what is the motivation for taking the square root of the squared differences and multiplying by 13? Re: Zsmooth - yup, I'm currently implementing spatial/temporal smoothing/denoising functions there. I haven't seen a need for a hysterisis implementation just yet, as none of the algorithms (so far) have utilized a mask. Did you mean that a hysterisis implementation would be nice to have in general, or that it would specifically benefit some of your "smoothing" functions in some way? |
#3054 | Link |
Its not a strict variance although it's based on it. From the formula it's basically an euclidean distance. The reason I didn't divide by the count, or that I multiplied by 13 was too normalize or saturate the output for a consistent thresholding with the rest of modes. Basically I did the full implementation with variance and from there started optimizing the ops for performance.
The problem with hysteresis is that there exists only one implementation. It's in masktools and it's very slow, pairing that with its huge benefits for refining masks (acts as a smart gap filler) makes it in my view a great candidate for revision. I don't know how the scenario is in vapoursynth but I guess it's much faster there.
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread Last edited by Dogway; 23rd April 2025 at 15:30. |
#3055 | Link |
Got it. Thanks again for the clear explanation.
Yeah, Vapoursynth has at least two different implementations of Hysteresis that I'm aware of: 1. https://github.com/vapoursynth/vs-mi.../docs/misc.rst 2. https://github.com/sgt0/vapoursynth-hysteresis I haven't personally done any performance tests though. If I had to guess, the later is likely the most performant. Might be worth asking if they'll create an Avisynth port at the very least. |
avisynth, dogway, filters, hbd, packs |
