Old 22nd December 2024, 11:31   #181  |  Link
neil wilkes
neil wilkes's Avatar
I just ried to download the new 9.4 version from the link & got the old, long since paid for 9.3 version instead, dated March 22, 2010.
Not sure what has gone wrong but I have tried twice - each time I get the wrong version.
www.opusproductions.com
Multichannel Audio Productions
DVD-Audio/Video Authoring specialists
neil wilkes is offline   Reply With Quote
Old 22nd December 2024, 11:33   #182  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
OK, thanks for the info. I will have a look. Please retry in one hour or so...
r0lZ
Old 22nd December 2024, 11:33   #183  |  Link
neil wilkes
Will do.....
Old 22nd December 2024, 11:54   #184  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
OK, the problem was due to a lower/UPPER case mismatch in the filename of the archive. It is fixed now.
Direct download: pgcedit_winexe.zip (The link from the PgcEdit homepage works fine too.)
r0lZ
Old 22nd December 2024, 11:59   #185  |  Link
neil wilkes
Appreciated - you're a star, as usual, and I would strongly suggest anyone who finds this even close to as useful as I do to make with a donation!
People sell tools for a lot of money that are nowhere near as good.....
Old 22nd December 2024, 12:02   #186  |  Link
neil wilkes
Sorry - still seeing the previous version in the 'direct download' link & from the home page too.
This is the Windows installer pgcedit_winexe.zip
Old 22nd December 2024, 13:47   #187  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
For me, it works. Must be a problem with your web browser. Try to refresh the web page, or clear your browser's cache, then close it and retry.
You can also download explicitly v9.4 from the "All versions" folder.
And thanks for your suggestion in your previous post. :-)
r0lZ
Old 24th December 2024, 10:34   #188  |  Link
neil wilkes
All now working as it should be.
Apologies to all for not writinbg this sooner, but I have taken a couple of days off from emails & work stuff so had not spotted these replies.
FWIW, my browser was set to delete it's cache at the end of each & every session, and I did try closing it & restarting it (although not, it must be said, physically making sure the cache was deleted) and I did also try accessing from the 'Help' dropdown in version 9.3 using both 'check for new version' and 'homepage' options, neither of which worked at the time.
I suspect that I was simply being impatient though - maybe I should have given everything a good couple of hours to settle, but I didn't.
Anyway it is all fully functional now thanks to the hard work from r0lZ and I am profoundly grateful for this unexpected present of a release, and will absolutely be re-donating.
Old 26th December 2024, 19:56   #189  |  Link
ggtop
PgcEdit v9.4 is finally available (after a while, sorry!)
It's a major update, and probably the last version, now totally free.
The main additions is the new verifier. Check it.
Have fun, and a nice Xmax ![/URL].
Wow, thank you very much. Haven't used PGCEdit since years as I don't deal with DVDs nowadays but used it on each and every looking back. I feel old :-) Many thanks for your contributuon to the community over the last years.
Have a nice Xmas
ggtop
ggtop is offline   Reply With Quote
Old 27th December 2024, 16:11   #190  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
Many thanks, r0lZ !
I had donated 2008 and back then could upgrade to PGCEdit.exe 9.4.0.1000, modification date 03.04.2017).
Now your recent version shows the same version number (PGCEdit.exe 9.4.0.1000, modification date 22.12.2024).
Using WinMerge as differ shows many differences between both 9.4, so I wonder what to expect:
Same functionality, minus nag, compiled; or extended, plus bugfixed, minus nag, and recompiled ?
Old 27th December 2024, 18:18   #191  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
Not sure what's happening. The official version number is now 9.4, not 9.4.0.1000. 9.4.0.1000 is the version created by the compiler/wrapper (FreeWrap). The real version can be seen in the status bar of PgcEdit when you have just launched it, or in the Help -> About dialog. Anyway, the release date of your version is correct. Maybe I gave you a 9.4 beta, honestly, I don't remember. On the official homepage, v9.3 was still the available version on Dec 21. The complete list of changes since 9.3 has been published here and the full history can be read or downloaded here. Some fixes and changes (including the nag and the availability of the full verifier) are very recent (a couple of weeks) but other changes are old. You should keep the latest version anyway.
r0lZ
Old 28th December 2024, 13:42   #192  |  Link
Emulgator
Emulgator's Avatar
Many thanks, I will do so.
Good work, I just donated again !
Old 28th December 2024, 13:55   #193  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
Thanks!
r0lZ
