27th May 2023, 10:01 | #581 | Link | |
Life's clearer in 4K UHD
27th May 2023, 18:58 | #583 | Link |
I'm assuming your DV file is Profile 5. Profile 5 color space is different from that of HDR (IPTPQc2 which is Dolby proprietary vs BT.2020), so I don't think there is an easy way for you to make a Profile 5 HDR compatible. BTW the difference in bitrate almost certainly won't be noticeable during playback, unless one is 50 Mbps and the other 2 Mbps.
27th May 2023, 19:10 | #584 | Link | ||||
27th May 2023, 19:56 | #585 | Link | |
28th May 2023, 00:05 | #588 | Link |
You could extract the RPU from the DV, convert it to Profile 8.1 and inject it into the HDR to get a hybrid HDR10 DV, that way you won't have to keep both files. That's if you're OK with the lower bitrate of the HDR one.
28th May 2023, 20:44 | #589 | Link | |
QfG Group Germany
3rd June 2023, 02:57 | #590 | Link |
Formally known as .......
I am having some interesting issues retaining the DV info during a remux from .mkv to .m2ts using FFMPEG.
So instead of doubling up posts, please see here :- https://forum.doom9.org/showthread.p...67#post1987967 Any suggestions ? Thanks |
8th June 2023, 18:22 | #591 | Link |
I have a mkv-file with the following HDR info:
HDR Info = [Dolby Vision, Version 1.0, dvhe.08.07, BL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible] Is it possible to remove the HDR10 data from the file, so that it only contains Dolby Vision HDR data? |
8th June 2023, 18:45 | #592 | Link |
AFAIK Profile 8 DV is by design backwards compatible with HDR10. Profile 5 isn't, but then you have to convert the RPU to Profile 5 and the color space of the video itself to Dolby proprietary IPTPQc2, and I don't think there's an easy way of doing so.
8th June 2023, 23:26 | #593 | Link | |
QfG Group Germany
-v0.55 Online
*NEW Checking and repairing MKV Container during muxing. *Updated mkvtoolnix to v 77.0.0.0. *Major Bugfixes. *Reworked Shell Extensions (Hybrid P8 Script now in Shell Background). Quote:
9th June 2023, 09:47 | #594 | Link |
-v0.55
DDVT_DEMUXER is buggy. It does not extract the rpu. My settings were: SAVE HDR BL: NO SAVE DoVI EL: NO SAVE RPU: YES CONVERT RPU: PROFILE 8.1 HDR CROP RPU: YES and also I had set my custom path in DDVT_OPTIONS.cmd Last edited by cool advertise; 9th June 2023 at 10:42. |
9th June 2023, 12:40 | #595 | Link |
QfG Group Germany
Some error messages during demuxing? And which DoVi Profile have the source file?
EDIT: You're right P7 will not demux correctly, will fix them. EDIT2: Fixed in Dolby_Vision_Tool_v0.55_f01.rar. Also fixed the missing path in the extract diroctory.
9th June 2023, 16:06 | #596 | Link |
Now 'DDVT_DEMUXER.cmd' works, but if you put an & in the folder name of the source file, or in the name of the source file, the rpu extraction fails (tested).
Perhaps also if other special characters are used, but I have not tested this thoroughly yet. |
11th June 2023, 04:35 | #599 | Link | |
Thanks for this tool. It's great Last edited by Amateur; 11th June 2023 at 04:45. |
