3rd March 2023, 07:20 | #1681 | Link |
How hard can it be... No Time To Waste...
9th March 2023, 21:13 | #1682 | Link |
Test files to load.
The following bug in the "compare" command has been present in several recent versions of Subtitle Edit. 1. I load the srt file containing text formatting (color) into the left window, 2. I load an srt file with the same content to the right, but without text formatting, As a result I get: And that's OK. After enabling [ignore formatting] I get: Here the result obtained contains errors and is incorrect.
Sorry for my mistakes - I'm using a translator. |
10th April 2023, 07:30 | #1683 | Link |
I'm trying to nOCR some subtitles. Some subtitles are like this:
nOCR sees the first image like this: I just don't... Mind looking after Rosette? Because it's two different characters speaking is there an option to make it look like this: - I just don't... - Mind looking after Rosette? Or do I have to manually go line by line to change it like the latter? |
14th April 2023, 16:48 | #1684 | Link |
14th May 2023, 14:59 | #1685 | Link |
Subtitle Edit 3.6.13 is out now
https://github.com/SubtitleEdit/subtitleedit/releases Video -> Audio to text via Whisper now supports 5 different implementations: @Janusz: The compare issue is hopefully fixed. |
14th May 2023, 18:57 | #1687 | Link |
Seems to me that the change in "find" is not right. Before as the search of the file get to the last line, if you push de "find" botton
again the progran ask to if should start from first line. This is the way it should be because you may start searching in the middle of the file, going back with previous one by one is certainly tedious. |
15th June 2023, 11:02 | #1689 | Link |
about "Fix common errors" "What to fix"
Hello and thanks for Subtitle Edit!
In "Fix common errors" how do I add in "What to fix" missing space - (dash) at start of every new line. Like this: ‐Oh, remember? ‐Yeah. Fix to this: ‐ Oh, remember? ‐ Yeah. I think it was found in the "Fix common errors" "What to fix" in previous versions? Edit: Found it. Options->Settings->Dialog style->Dash both lines with space It does not catch all but close enough for me. In text like this where empty lines are removed it doesn't catch: (Empty line removed) ‐Nope. Thanks and best regards, varekai Last edited by varekai; 15th June 2023 at 17:27. Reason: Got it, close enough... |
15th June 2023, 12:29 | #1690 | Link |
Acid fr0g
Is there any way that the anime community can convince you to have SE able to split upper and lower PGS and proceed with OCR indipendently?
You can't imagine what a PITA is to have to edit timings and subs after having OCRed an anime with overlapping timings.
@turment on Telegram |
15th June 2023, 12:37 | #1691 | Link |
Big Bit Savings Now !
To ease the PITA:
#upper half crop(0,0,0,height/2) Code:
#lower half crop(0,height/2,0,0)
16th June 2023, 08:51 | #1693 | Link |
Ah, I see, PGS it was, sorry for the confusion.
18th August 2023, 08:38 | #1695 | Link |
Hi Nikse
Did I find a little bug in one of the "Fix common errors" functions? Take for example these two lines: 'Line 1.' - Line 2. Note that line 1 is between ' and ' When "Remove dialog dashes in single lines" is checked, the result window prompts to delete the dash of line 2. Where it isn't wished for. I'm on v3.6.13 [EDIT] I think it's because it ends with ' Because Line 1.' - Line 2. also gives that result Last edited by von Suppé; 18th August 2023 at 08:41. |
22nd August 2023, 09:57 | #1696 | Link |
Hi, is there a bug in blu-ray sup creation regarding shadow transparency? I am trying to create a sup with a non transparent shadow, but I can't seem to make it happen.
In the attached picture, you can see the shadow is transparent, although I set its alpha to 255 when creating the subtitle. Last edited by nautilus7; 22nd August 2023 at 09:59. |
29th August 2023, 14:16 | #1698 | Link |
Hi all. I have two .stl subtitle files for the same video - one is exported as EBU STL open subtitling, one is exported as EBU STL teletext with "double height for text" activated.
My client wants me to deliver these two subtitle tracks as one mixed mode .xif file. Whenever I try to merge the two files (Tools > Join subtitles), the teletext properties are lost and I just have a .xif file with all open titles. I have also tried exporting both as .xif and then merging, but still the closed captioning turns into open subtitling. Any way to mitigate this with Subtitle Edit or any other software? Thanks. |
5th September 2023, 07:07 | #1700 | Link |
Thanks for new release:
https://github.com/SubtitleEdit/subt...ases/tag/4.0.0 |
