17th December 2008, 01:19 | #42 | Link | |
I still can't open the file as with previous versions. I get this error: Code:
System.Exception: Parameter is not valid. at System.Drawing.Bitmap..ctor(Int32 width, Int32 height, PixelFormat format) at SupRip.SubtitleFile.ConvertHdSup(FileStream fs, SupData data) at SupRip.SubtitleFile.GetSubtitleImage(Int32 n) at SupRip.MainForm.LoadSubtitleImage(Int32 number) at SupRip.MainForm.LoadSubtitleImage(Int32 number) at SupRip.MainForm.LoadSubtitleFile(String fileName) at SupRip.MainForm.loadButton_Click(Object sender, EventArgs e) at System.Windows.Forms.Control.OnClick(EventArgs e) at System.Windows.Forms.Button.OnClick(EventArgs e) at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ButtonBase.WndProc(Message& m) at System.Windows.Forms.Button.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll ---------------------------------------- SupRip Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Downloads/SupRip.exe ---------------------------------------- System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- I'm sure i have 1.12, but is it possible to add the version number somewhere on the program? Thanks. |
18th December 2008, 22:06 | #49 | Link |
yay sticky!
I tried that but it's a lot harder writing to a proprietary format than reading from it. There's a lot of bytes that I don't know what they do and can safely ignore when decoding, but if they're just set to a random guessed value while encoding, they tend to crash the players that are written to the official Sony spec.
Suprip - HD DVD and Bluray subtitle converter |
21st December 2008, 22:41 | #53 | Link |
For Taktaal regarding sub/idx:
Good overview of the vobsub sub/idx format: http://trac.annodex.net/wiki/VOBSub Doom9 guide for ripping from DVD to sub/idx: http://www.doom9.org/index.html?/dvobsub.htm Misc: http://forum.doom9.org/showthread.php?t=99815 Sourceforge links for vobsub: http://sourceforge.net/project/showf...kage_id=246121 http://sourceforge.net/project/showf...group_id=82303 Manusse's (SubtitleCreator author) explanation of Standard Def subtitle format: http://forum.doom9.org/showpost.php?...&postcount=195 A comment by Manusse on another forum: "VobSub format (sub/idx) is a SD format. The only way to convert a HD-DVD subtitle file to VobSub is using SubtitleCreator. It will downsample it to SD resolution and decrease its number of colors to 4 and allow to export it as sub/idx. However it can't currently open Blu-Ray Sup files." My understanding of sub/idx: The standard definition (SD) sub/idx is a graphical subtitle format viewable on PC's using directvobsub. Zoom player, Media Player Classic, VLC, and maybe others can display subtitles in this format, even when playing HD files such as those demuxed from Bluray. Pros: Subs are graphical, can display any character, and are not subject to OCR errors. Subs can be displayed anywhere on screen. Cons: Subs are SD which looks somewhat blocky on a HD screen. Challenge: The HD subs must be downconverted from HD sup to SD sub/idx format. Some hardware players support the SD sub/idx format when playing HD files. - DVICO TVIX HD M-6500A - supported - Popcorn Hour A-110 - supposedly will be supported in a future firmware SubtitleCreator can convert HD-DVD SUP files to SD sub/idx. Maybe Taktaal is willing to do the same thing with Suprip, and include Bluray support. |
23rd December 2008, 23:43 | #55 | Link |
The problem with recognizing the first character in italic lines and the one with the 0 end time on the last subtitle will be fixed in the next version. I'm currently working on the sub/idx stuff and will release it when that's done.
27th December 2008, 17:59 | #57 | Link | |
IDX/SUB supported (first implementation, only external IDX/SUB) Once this is released, there will be two (that I'm aware) hardware players supporting sub/idx. I have the Popcorn Hour, so I'll be glad to test |
27th December 2008, 18:29 | #58 | Link |
quantum, while it takes a few extra steps you can get vobsub from bluray subs by using supread to convert bluray to hd-dvd and then into subtitlecreator. I agree it would be nice if suprip could support it with one click.
27th December 2008, 19:50 | #59 | Link | |
However, seeing this technique in action is what got me interested in sub/idx in the first place But I found the supread/subtitlecreator path to be awkward, slow, and sometimes would not work at all. But I agree that it is a path that is workable, and maybe others could have better luck with it than I had. With that said, Suprip already supports HD DVD and Blu-ray sups, and Taktaal has been great in tweaking it to support the different variations that have been popping up. If he can get reliable sub/idx output, then it would be close to a one-click answer, maybe even command line we can put in a batch file |
27th December 2008, 22:48 | #60 | Link |
too much lurking
I too have noticed this, but only once. The supread/subtitlecreator method has worked for me with all but 3 disks. I think the issue was with supread since Taktaal needed to spruce up suprip to make the original sup work with it.
suprip |
