View Poll Results: Do you still use MPEG2 in 2019?
Yes 26 44.83%
Yes, for simple content (tv shows, etc) 4 6.90%
No 30 51.72%
I don't know what MPEG2 is... 3 5.17%
Multiple Choice Poll. Voters: 58. You may not vote on this poll
Old 15th July 2019, 19:15   #21  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
I think it would be useful to have x262 encoding working with VirtualDub2, especially as we can now save directly to the .mkv container...
Old 15th July 2019, 19:45   #22  |  Link
sneaker_ger
Who do you think would want or need to encode MPEG-2 to MKV?
Old 15th July 2019, 19:55   #23  |  Link
manolito
manolito's Avatar
Thanks Groucho for the binaries.
I took a quick look at the help, leaves me a little confused. The help always refers to x264, is this just sloppiness? And then I do not see the option to output an m2v elementary stream, are the devs serious about this? Dunno, looks I will stick with HCenc and FFmpeg for my MPEG2 encoding needs...
Old 15th July 2019, 20:06   #24  |  Link
Groucho2004
This seems to produce a perfectly fine mpeg2 elementary stream:
x262_32 test.avs --mpeg2 --output test.m2v
If you need the full help:
x262_32 --fullhelp > x262.txt
Groucho's Avisynth Stuff
Old 15th July 2019, 20:16   #25  |  Link
SeeMoreDigital
It's not necessarily about the container. But having a container the correctly supports b-frames is useful.
And once the elementary MPEG-2 has been extracted it can be muxed into other containers...
Old 15th July 2019, 21:47   #26  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Yep. In my case, I mux MPEG-2 files with BBC BMX in mxf. I was actually using ffmpeg to mux audio and video before, but I found out that some softwares are just too "pretentious" in terms of specifications and refuse MPEG-2 files muxed with ffmpeg but accept them if I mux them with BBC BMX (I'm looking at you AVID!).
By the way, thanks for the updated binaries, Groucho!
+1
Although I've automatized everything via bat, it would be useful to have it available on VirtualDub as well. For the records, by "VirtualDub" I mean VirtualDub2 Filtermod of course.
Old 15th July 2019, 23:28   #27  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
Here are the r2633 builds (32 & 64 bit). Input is Avisynth or stdin.
Standard disclaimer:
I have not tested these at all and take no responsibility if your computer blows up or you grow excessive nose hair using these binaries.
Thanks for this!
Already trimming them so they can regrow in the process.
Win10 (x64) build 19041
NTSC | DVD: R1 | BD: A
AMD Ryzen 5 2600 @3.4GHz (6c/12th, I'm on AVX2 now!)
Old 15th July 2019, 23:44   #28  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
MPEG-2 is still absolutely mainstream, widely deployed, and utterly critical in professional workflows, mostly in broadcast. Just a few examples:
- OTA broadcast via ATSC is still MPEG-2.
- Many cable systems still use MPEG-2 for linear channels due to legacy settop boxes (often live transcoded from the "real" AVC used by the rest of the system). Lots of cable VOD is still MPEG-2 as well.
- Many legacy HD and SD linear channels are originated on satellite via MPEG-2
- DVDs are still very much a thing.
- Most linear TV channels play MPEG-2 files out of their video servers. IMX is common for SD, and XDCAM HD422 is common for HD.
That last one I know a ton about as I worked on the ingest / workflow side of broadcast for many years. Most channels have huge libraries of content in their "house format" which tends to be MPEG-2 based for simplicity and consistency with files ingested 10+ years ago. You change as little as possible when taking channels to air. Storage is definitely expensive, but the businesses tend to prefer spending the money on the old file formats since it mitigates risk elsewhere.
Thankfully nobody doing OTT streaming uses MPEG-2, because as we all know it's utterly outclassed by 2+ compression format generations and 20+years of development. Things move slow
Old 16th July 2019, 13:30   #29  |  Link
filler56789
SuperVirus
filler56789's Avatar
Do you still have any doubts?
I would like to know why x262 isn't a pure MPEG-2 encoder yet...
not sure whether it's impossible to get rid of the H.264 encoder parts, or whether the developer was just too lazy
Anyway, I only knew that x262 suckED in the beginning... but yesterday and today I gave a second chance to the binary.
Well, it's much better now, I have to say. It does not limit the GOP length, accepts the linear quantization scale and custom matrices as well, and is fast.
*THUMBS UP*
filler56789 is offline   Reply With Quote
Old 24th July 2019, 11:34   #30  |  Link
outhud
Hi Sparktank, I needed to encode for DVD recently, and used HCenc also.
Interested to try x262, are there any comparisons available comparing x262 with HCenc? Or have you found any result from your own testing?
outhud is offline   Reply With Quote
Old 24th July 2019, 19:54   #31  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
I'll be doing some testing within the next couple weeks. I just need cannibalize my computers. The old one has the really good drive that does UHD-BD's.
From some limited testing yesterday, it's quite decent but needs a lot of tweaking.
*THUMBS UP*
Have any scripts to share? Some feedback on the source types (grain,noise,flat,animation,etc)?
Old 24th July 2019, 21:20   #32  |  Link
filler56789
SuperVirus
Not yet. I ran just a couple of test encodes in a VERY unscientific way ...
but the visual quality AND the small filesize were similar to the results produced by the (already-old) Mainconcept Reference MPEG-2 Encoder.
Old 24th July 2019, 23:40   #33  |  Link
qyot27
qyot27's Avatar
x265 was basically forked and refactored away from the reference HEVC implementation, IIRC. x264 might have been developed similarly in the early stages, but I don't know that for sure. x262 was basically a set of changes to x264's already-mature codebase which allowed it to encode MPEG-2.
So to use an analogy, x264 and x265 are like cousins. x262 is like x264 grew a second head.
Old 23rd August 2019, 19:08   #34  |  Link
benwaggoner
I haven't made MPEG-2 content for delivery in a while, but it still gets used for older sources and some pre-distribution workflows.
Ben Waggoner
My Compression Book
Old 20th October 2020, 15:36   #35  |  Link
TheSpectre
TheSpectre's Avatar
The last time I used MPEG-2 was to convert a few DVD9 films to DVD5
TheSpectre is offline   Reply With Quote
Old 21st October 2020, 07:32   #36  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Since you're resurrecting the topic, speaking of MPEG-2, will the FFMpeg encoder ever be properly multi-thread?
It's painfully slower than it could be right now on my 28c/56th... Sure, I can run multiple encodes at a time but still...
Old 29th October 2020, 10:32   #37  |  Link
Losko
Since patents on mpeg2 have now expired I expected a renewed interest in this free codec.
Curiously, despite the age, still mpeg2 video encoding offers many free alternatives to pick: x262, HCenc, ffmpeg and, if you have a recent intel cpu, qsv encoding (through ffmpeg as well). And all them can run cross platform (HCenc runs smoothly under linux using wine).
It would be great to see a great, comprehensive comparison (speed-wise, quality-wise, feature-wise) among them all.
Losko is offline   Reply With Quote
2019, 480p, mpeg2, sd content, x262
