Old 21st February 2017, 00:28   #81  |  Link
KingLir
Anyone was able to build this for macOS ? I am getting:
$ ./configure
generating config.mak ...
error: patches welcome
KingLir is offline   Reply With Quote
Old 23rd February 2017, 00:52   #82  |  Link
KingLir
I was able to build on macOS with this. Anyone able to do a commit with this patch - please do.
gcc -c -fPIC  ${CFLAGS} ${CPPFLAGS} -I. $(pkg-config --cflags vapoursynth) -o main.o rawsource.c
g++ -dynamiclib -undefined suppress -flat_namespace *.o -o libraws.dylib
Old 23rd February 2018, 04:59   #83  |  Link
ifb
Is there some trick to making a working windows build? I can usually preview a frame or two in VS Editor before it dies. vspipe also crashes and I can't get a backtrace with gdb. I messed with this a few weeks ago and gdb pointed at history_add(), but I've since changed something and I can't even get that far anymore.
I haven't tried building with visual studio yet. The same script works fine in a Linux VM.
import vapoursynth as vs
core = vs.get_core(threads=1)
# https://media.xiph.org/video/derf/Chimera/Netflix_WindAndNature_4096x2160_60fps_10bit_420.yuv
c = core.raws.Source('Netflix_WindAndNature_4096x2160_60fps_10bit_420.yuv',4096,2160,60000,1001,src_fmt='YUV420P10')
c.set_output()
vspipe script.vpy output.raw
Ultimately, I'd like to use walisser's vsrawsource repo with pipe input, but it's only a few commits ahead of Myrsloik's tree which doesn't work either so I don't know what I've screwed up here.
ifb is offline   Reply With Quote
Old 23rd February 2018, 12:22   #84  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Originally Posted by HolyWu View Post
Use this repo which has fixed the crash and other issues.
Windows binaries.
How many forks are there now? Which one should I point to?
Myrsloik is offline   Reply With Quote
Old 23rd February 2018, 18:18   #85  |  Link
ifb
Windows binaries.
Thanks. I did manage to debug it with vs2017 last night and find the crash, but it was late and the fix wasn't immediately obvious to me.
I didn't know there was yet another fork and the work had already be done for me.
Old 2nd November 2019, 18:00   #86  |  Link
logicom
logicom's Avatar
piping trough rawvideosource
I am experiencing dificulties to make this working:
ffmpeg -y -re -f lavfi -i testsrc=duration=30:size=720x576:rate=25 -c:v rawvideo -pix_fmt yuv420p -r 25 -an -f rawvideo - | vspipe --y4m live.vpy - | ffplay -f rawvideo -pix_fmt yuv420p -s 720x576 -i -
where live.vpy is:
core = vs.get_core()
clip = core.raws.Source("-",720,576,src_fmt="YUV420P8")
clip.set_output()
could someone provide win binary that accepts input from "-"
logicom is offline   Reply With Quote
Old 2nd November 2019, 18:58   #87  |  Link
Myrsloik
Myrsloik's Avatar
It's been a long time since I looked at this but I think reading from stdin on windows never worked well.
Old 2nd November 2019, 19:44   #88  |  Link
logicom
logicom's Avatar
Any advice on how to move on from this point?
Old 4th November 2019, 12:30   #89  |  Link
DJATOM
DJATOM's Avatar
Looks like it works, thx.
Me on GitHub
PC Specs: Ryzen 5950X, 64 GB RAM, RTX 2070
DJATOM is offline   Reply With Quote
Old 4th November 2019, 16:51   #90  |  Link
poisondeathray
Awesome, works well, thanks
Is raw pipe (or yuv pipe) in, or anything like that possible with avisynth ?
Old 4th November 2019, 23:53   #91  |  Link
logicom
logicom's Avatar
Try this. I think it should work.
Thank you for looking into this. I tested 64 bit version
and piping was working. But I was wondering why I could not have any influence on framerate.
whithout vsrawvideo pipe: 25 tbr, 25 tbn, 25 tbc
with vsrawvideo pipe: 29.97 fps, 29.97 tbr, 29.97 tbn, 29.97 tbc
I tested with yuv420p yuv422p and yuv444p
Kind Regards.
Old 5th November 2019, 00:01   #92  |  Link
poisondeathray
@logicom -
core.raws.Source(fpsnum=25, fpsden=1)
If you add --y4m headers for vspipe , the receiving application should take that information
Old 5th November 2019, 01:04   #93  |  Link
logicom
logicom's Avatar
Thank you!
Old 5th November 2019, 13:05   #94  |  Link
DJATOM
DJATOM's Avatar
@poisondeathray
you can wrap core.raws.Source call with AVS plugin VapourSource (function VSEval), it should work as intended.
Me on GitHub
