Old 4th June 2021, 23:45   #30661  |  Link
spotswood
Originally Posted by gonca View Post
In a BD the thd and ac3 tracks are "interleaved" into 1 track.
When remuxed to mkv you will get a thd and an ac3 track.
Two audio tracks in the mkv
Yes, I understand this. It's not the problem...
Originally Posted by MrVideo View Post
Yes, but the AC3 core shouldn't be mono.
It's the THD track that is being converted to Mono, not the core track. Log from my post above:
[12:06:09] Importing MKV: 1917_4K_HDR
- Collecting audio/video streams from source...
- Converting audio, Track #2, THD to AC3...
- Building pseudo-BD source structure...
[12:47:02] Video import completed successfully.
Unless the original core was mono
It's not, the core is AC3 Multi-Ch @ 640...
Originally Posted by ggtop View Post
I suggest you compare the audio characterics of both, the original and your mkv e.g. with MediaInfo and come back with the results.
ggtop
You are suggesting I compare the audio characteristics of a mono track to a multi-ch surround track? There is no comparison...
spotswood is offline   Reply With Quote
Old 4th June 2021, 23:47   #30662  |  Link
spotswood
I looked at the code and it specifically excludes printing that line when in MOVIE-ONLY mode. Now I have to figure out whether I did that for a reason -- or was just goofy that day.
EDIT: I realize now that I used the wrong variable for that check. It should have suppressed the message for ALTERNATE output, not all MOVIE-ONLY encodes. I fixed it for the next release.
No problem, and thank you...
Old 5th June 2021, 05:13   #30663  |  Link
MrVideo
MrVideo's Avatar
You are misunderstanding the log entry. Track #2 on the disc is a THD track and it is being converted to AC3. It should do so by extracting the AC3 core.
Again, use MediaInfo to look at the specs for the the THD audio track.
Old 5th June 2021, 22:05   #30664  |  Link
spotswood
OK, here you go...
MediaInfo pre reencode for my 1080p Anna MKV:
Video
Format                         : AVC
Format/Info                    : Advanced Video Codec
Format profile                 : High@L4.1
Format settings                : CABAC / 4 Ref Frames
Format settings, CABAC         : Yes
Format settings, Reference fra : 4 frames
Codec ID                       : V_MPEG4/ISO/AVC
Duration                       : 1 h 58 min
Bit rate mode                  : Variable
Bit rate                       : 33.0 Mb/s
Maximum bit rate               : 35.0 Mb/s
Width                          : 1 920 pixels
Height                         : 1 080 pixels
Display aspect ratio           : 16:9
Frame rate mode                : Constant
Frame rate                     : 23.976 (23976/1000) FPS
Original frame rate            : 23.976 (24000/1001) FPS
Color space                    : YUV
Chroma subsampling             : 4:2:0
Bit depth                      : 8 bits
Scan type                      : Progressive
Bits/(Pixel*Frame)             : 0.663
Stream size                    : 27.4 GiB (88%)
Language                       : English
Default                        : Yes
Forced                         : No
Audio #1
Format                         : MLP FBA 16-ch
Format/Info                    : Meridian Lossless Packing FBA with 16-channel presentation
Commercial name                : Dolby TrueHD with Dolby Atmos
Codec ID                       : A_TRUEHD
Bit rate                       : 3 616 kb/s
Maximum bit rate               : 6 318 kb/s
Channel(s)                     : 8 channels
Channel layout                 : L R C LFE Ls Rs Lb Rb
Sampling rate                  : 48.0 kHz
Frame rate                     : 1 200.000 FPS (40 SPF)
Compression mode               : Lossless
Stream size                    : 3.01 GiB (10%)
Language                       : English
Default                        : Yes
Forced                         : No
Number of dynamic objects      : 15
Bed channel count              : 1 channel
Bed channel configuration      : LFE
Audio #2
Format                         : AC-3
Format/Info                    : Audio Coding 3
Commercial name                : Dolby Digital
Format settings                : Dolby Surround EX
Codec ID                       : A_AC3
Bit rate mode                  : Constant
Bit rate                       : 640 kb/s
Channel(s)                     : 6 channels
Frame rate                     : 31.250 FPS (1536 SPF)
Compression mode               : Lossy
Stream size                    : 545 MiB (2%)
Language                       : English
Service kind                   : Complete Main
Default                        : No
Forced                         : No
.inf:
[Status]
LABEL=ANNA_1080P
VERSION=v0.61.22
SOURCE_SIZE=31433637888
SOURCE_VIDEO_SIZE=31433637888
TARGET_SIZE=26306674688
REDUCTION=.836895646050652
RESIZE_1080=0
RESIZE_1440=0
AUDIO_TO_KEEP=eng;
KEEP_HD_AUDIO=-1
SUBS_TO_KEEP=eng;
BACKUP_MODE=1
MOVIEONLY_TYPE=0
USE_LAVF=0
INSTANCES=4
DGDECNV=-1
DGDECIM=0
FRIMSOURCE=0
FFMS2=0
SSIF_MODE=0
UHD_V3_MODE=-1
QUICK=0
ENCODE_STEP=0
COMPLETED=1
REBUILD_COMPLETE=1
[00000]
AUDIO=10
PGS=1
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=26306674688
RATE=27310
NSIZE=0
FLINK=0
MLINK=0
Log:
[06/05/21] BD Rebuilder v0.61.22
[09:02:14] Source:  ANNA_1080P_00000
  - Input BD size: 29.27 GB
  - Approximate total content: [01:58:59.173]
  - Target BD size: 24.50 GB
  - Windows Version: 6.2 [9200]
  - MOVIE-ONLY mode enabled
  - Quality: High Quality (Default), 1-Pass VBR
  - Decoding/Frame serving: NVENCC
[09:02:17] PHASE ONE, Encoding
 - [09:02:17] Processing: VID_00000 (1 of 1)
 - [09:02:17] Extracting A/V streams [VID_00000]
 - [09:03:17] Reencoding video [VID_00000]
   - Rate/Length: 23.976fps, 171,169 frames
   - Bitrate: 27,310 Kbs
 - [09:03:17] Reencoding: VID_00000, Pass 1 of 1
 - [09:19:26] Video Encode complete
 - [09:19:26] Processing audio tracks
[09:19:26]PHASE ONE complete
[09:19:26]PHASE TWO - Rebuild Started
 - [09:19:26] Rebuilding BD file Structure
[09:20:08] - Encode and Rebuild complete
 - WORKFILES folder removed.
[09:20:09] JOB: ANNA_1080P finished.
MediaInfo post reencode to HEVC: I've bolded the Audio parts in question...
[08:46:17] Importing MKV: ANNA_1080P
[08:50:52] Video import completed successfully.
MediaInfo:
Video
Menu ID                        : 1 (0x1)
Format                         : HEVC
Format/Info                    : High Efficiency Video Coding
Format profile                 : Main 10@L4.1@High
Codec ID                       : 36
Bit rate                       : 25.0 Mb/s
Frame rate                     : 23.976 (24000/1001) FPS
Color space                    : YUV
Bit depth                      : 10 bits
Bits/(Pixel*Frame)             : 0.503
Stream size                    : 20.8 GiB
Color range                    : Limited
Color primaries                : BT.709
Transfer characteristics       : BT.709
Matrix coefficients            : BT.709
format_identifier              : HDMV
Source                         : 00000.m2ts / 00000.m2ts
Audio
Menu ID                        : 1 (0x1)
Format                         : AC-3
Codec ID                       : 129
Bit rate                       : 640 kb/s
Channel(s)                     : 1 channel
Channel layout                 : C
Language                       : English
bsid                           : 8
Dialog Normalization           : -31
Dialog Normalization           : -31 dB
acmod                          : 1
lfeon                          : 0
dialnorm_Average               : -31
dialnorm_Average               : -31 dB
dialnorm_Minimum               : -31
dialnorm_Minimum               : -31 dB
dialnorm_Maximum               : -31
dialnorm_Maximum               : -31 dB
dialnorm_Count                 : 1
format_identifier              : AC-3
SamplingCount_Source           : General_Duration
Duration_Source                : General_Duration
Misunderstanding? Sure looks like 1 CH Mono to me. Any ideas?
Old 6th June 2021, 02:15   #30665  |  Link
MrVideo
MrVideo's Avatar
To me, you made it sound like the THD portion of the audio stream was being converted. As pointed out, the AC3 core should be extracted without any kind of recoding. You should be able to use eac3to to extract the AC3 core from the THD stream and then look at it with media info.
I would find it extremely strange that only a center channel would be placed in the lossy AC3 core and all of the other 7 channels of stuff placed in the THD objects.
It is unfortunate that mediainfo does not list the core configuration.
Old 6th June 2021, 05:49   #30666  |  Link
spotswood
I made it sound that way because that's exactly what it's doing. - Converting audio, Track #2, THD to AC3... "Converting" NOT "extracting". You asked for MediaInfo info and I gave it to you. It's right there in the MediaInfo in Bold and white. I don't know what else to tell you. Try it yourself and see what you come up with...
Yes it should, but that's not what is happening. And why should I have to do that? Shouldn't BDRB handle the extraction/conversion correctly as needed on it's own?
Well that's why I'm reporting what I think might be a bug. Like I said, try it yourself. Import a MKV with a THD/Atmos track and see what happens. I'm tired and my brain hurts. Have a good evening everyone...
Old 6th June 2021, 08:54   #30667  |  Link
MrVideo
MrVideo's Avatar
I see below that I missed a very valuable clue and that this is a MKV file, and not a Blu-ray M2TS. Not sure how I missed that, but I did.
With a MKV file, the THD track from a M2TS file has already been split into the THD objects file and the AC3 core file. All BDRB needs to do is pull the core from the MKV file. That may be what it is doing and the wrong choice of words was used. I'm not sure you can do anything with the high def audio component, because what is also needed is the core component. I'll leave that to JD to explain.
I do not have the file you are dealing with, so I can't do any testing. Using a different MKV file containing THD audio would not be the same.
You can use the MKV toolset to create a new MKV file with only the AC3 core and see what mediainfo now reports. I know, not your job, but it would help with troubleshooting since I suspect that JD doesn't have that file either.
Old 6th June 2021, 10:03   #30668  |  Link
tebasuna51
tebasuna51's Avatar
Of course it is a mistery how a THD Atmos 8 channels can be converted, by ffmpeg I suposse, to an AC3 1 channel.
But, if you want an AC3, for what not select the track 3 of pre reencode mkv?
It is clearly the core of TrueHD track from m2ts's BD.
Old 6th June 2021, 13:02   #30669  |  Link
ggtop
Hi spotswood,
it seems to me you are still selecting the wrong audio track...
Given the fact that your imported source follows a natural numbering audio #4352 is track 1 (previously borked THD) and #4353 is track 2 (AC3@640) according to your MediaInfo log.
Looking in your .inf file you are selecting track 1:
REBUILD_COMPLETE=1
[00000]
AUDIO=10
PGS=1
What does happen if you select audio track 2 BDRB should show you in the stream window?
I suggest you also disable "remove WORKFILES after rebuild" so that you have the chance to examine the temporary files afterwards. Especially AUD_00000_4352.AVS in this case.
ggtop
EDIT: Just had a look with MediaInfo into a random disc containing a THD stream:
Audio #2
Menu ID                                  : 1 (0x1)
Format                                   : MLP FBA AC-3 16-ch
Muxing mode                              : Stream extension
Codec ID                                 : 131
Duration                                 : 1 h 30 min
Bit rate                                 : 640 kb/s
Maximum bit rate                         : 5 904 kb/s
Stream size                              : 414 MiB (1%)
Number of dynamic objects                : 13
Looking into yours it seems it is indeed missing the core as gonca wrote due to MKV restrictions.
ggtop is offline   Reply With Quote
Old 8th June 2021, 22:11   #30670  |  Link
spotswood
Pilot error...
Hey guys... jdobbs and I had a little educational conversation and he corrected the error in my ways. Who knew you could use MakeMKV to backup to a folder! Not me! What a dumb a**... (wipes a carton of eggs off face). So please disregard my recent ramblings and I'll say it again, what a dumb a**. Crisis caused by pilot error averted... ;^)
Old 10th June 2021, 23:59   #30671  |  Link
spotswood
Fyi...
So just FYI and for those curious as to the source file for my previous posts, attached is the full MediaInfo from my original Anna BD that includes the THD-Atmos/core track in addition to the foreign language tracks.
So what I did originally was rip the movie only straight to MKV, keeping only the THD-Atmos/core English track, which I now know is split into 2 seperate tracks per MKV specs. When attempting to convert the movie to UHD/x265, rather than load the original disc into BDRB, I imported the previous movie only MKV into BDRB. During the import process BDRB wants to extract/convert the THD core track to AC3.
Here's where things got wonky. Since the core was already extracted in the previous rip to MKV, there is no core to extract from the THD track (I'm guessing, but what do I know). BDRB now "converts" the THD track to AC3, but converts it to Mono. That is the big mystery and I'll leave that to you and jdobbs to figure out if you want to.
It's actually moot at this point as instead of trying to import my existing MKV files to convert them to UHD/x265, I'll just start over and load the original disc into BDRB and convert from there. Hope this info helps for those interested in what is happening. Sorry for any confusion and thanks for the help provided...
EDIT: The MediaInfo is too large to include in my post so I uploaded as an attachment. I've included just the audio portion since the whole thing including the video and subs is too big. Sorry 'bout that Chief!
Old 14th June 2021, 05:00   #30672  |  Link
Lathe
Lathe's Avatar
I don't know if this would also help, but what I do any time I have MKV files with a THD audio track (where the core has been removed) I just run it through UsEac3to, choose the TrueHD track and select the THD+Ac3 as the output. That puts the removed core back into the THD track as it was originally. Then I just use TSMuxer to replace the now restored THD track w/core back into the BDMV format, from which BDRB can take it from there.
Lathe is offline   Reply With Quote
Old 15th June 2021, 01:08   #30673  |  Link
spotswood
UsEac3to
This sounded interesting so I gave UsEac3to a try. Didn't give the same results as you describe at first, but after playing around with the settings I got it to work. Now TSMuxer accepts the THD/core track instead of ignoring it without the core. This helps immensely! Thanks for the tip!
Old 18th June 2021, 06:00   #30674  |  Link
Lowpro
I'm not sure if I've mentioned this or not. It's related to "Quick-Play" menus that contain multiple pages.
The "PAGE" label and "PREV/NEXT" buttons are positioned too close to the last QP menu item on a given page. Example provided below.
The "PREV/NEXT" buttons actually overlap the last QP menu item on a given page. Well, you can't always tell. It depends on the QP menu item characters involved and "PREV/NEXT" button positioning which is determined by the longest QP menu item naming on the page. Here's a closer look. See below.
The spacing from QP menu item to QP menu item is excellent. I'd love to see that same spacing used when the given page includes the "PAGE" label and "PREV/NEXT" buttons as well. It would prevent the overlapping as shown above and look much better in general.
And if you'll indulge me since it's related...
In addition to the increased spacing I'd love to see options added so that one could set the positioning of the "PAGE" label and "PREV/NEXT" buttons respectively. The added flexibility would be very welcome. Something like the below perhaps.
MENU_PAGE_LABEL_HORIZONTAL=n (n = 0-1919 - Offset from left of 1080p screen.)
MENU_PAGE_LABEL_VERTICAL=n (n = 0-1079 - Offset from top of 1080p screen.)
MENU_PREV_NEXT_HORIZONTAL=n (n = 0-1919 - Offset from left of 1080p screen.)
MENU_PREV_NEXT_VERTICAL=n (n = 0-1079 - Offset from top of 1080p screen.)
In my case I'd left justify the "PAGE" label with the QP menu items and position the "PREV/NEXT" buttons, so that the same amount of menu backdrop is to the right of those buttons as is to the left of the "PAGE" label. This would remain consistent from page to page. (My menu backdrop is part of the menu background image in this case as I prefer the menu backdrop to have a fixed width from page to page.) I'd also bottom align the "PAGE" label with the "PREV/NEXT" buttons so that the "PAGE" label was not crowding the last QP menu item.
And below is what the end result would look like which includes the increased spacing after the last QP menu item.
Now tell me that doesn't rock. Symmetry is a beautiful thing. It can make all the difference in the world. The above looks far better than the first image I posted in my reply here. Would love to see BD Rebuilder improved in this regard.
Old 18th June 2021, 13:50   #30675  |  Link
jdobbs
@Lowpro
I'll take a look at it.
Website: www.jdobbs.net
Old 19th June 2021, 16:30   #30676  |  Link
Lowpro
@Lowpro
Excellent. And so you know, the thought hadn't occured to me that I could reposition the "PREV/NEXT" buttons using BDedit. For each QP menu item, including the "PREV/NEXT" buttons you can change the "X" and "Y" values. Works like a charm. The only thing I haven't figured out yet is how to reposition the "Page" label. Well I assume it's a label as it's not listed as a button in BDedit anyway. If it were I could just reposition it how I like and call it a day.
As for the current spacing, from BDedit I can see that the "Y" value increases by 50 from QP menu item to QP menu item. The "Y" value from the last QP menu item to the "PREV/NEXT" buttons only increases by 40 however, hence the "PREV/NEXT" buttons overlapping the last QP menu item. See below taking note of the "Y" value from button to button.
And here's what the end result looks like when the same spacing is used, i.e. increasing the "Y" values for the "PREV/NEXT" buttons by 10. Much better wouldn't you say. (Using TotalMedia Theatre 3 on an old Windows XP desktop to take screenshots of the actually Blu-ray menus. Comes in handy.)
Before:
After:
So for now I can certainly just increase the "Y" value of the "PREV/NEXT" buttons by 10 using BDedit. Also loving the fact I can slide the "PREV/NEXT" buttons down further to the right now like I want. Just wish I could figure out how to reposition the "PAGE" label. I don't see how that can be done in BDedit unfortunately. I see no reference to the "PAGE" label in BDedit at all. Well, unless I just don't know where to look.
Measuring things out in Photoshop I'd have to increase the "Y" value of the "PAGE" label by 16. The "PAGE" label would then be bottom aligned with the "PREV/NEXT" buttons no longer crowding the last QP menu item as a result. To align the "PAGE" label with the other QP menu items I'd need to increase the "X" value by 38. End result shown below. (I increased the "X" values of the "PREV/NEXT" buttons by 230 as well just for fun. Couldn't help myself. Loving the ability to reposition those buttons now. I updated all my QP menus for this TV series actually. To check out the whole spread see here.)
The above would be much better positioning for the "PAGE" label I think. Perhaps you'll consider having the "PAGE" label use that positioning per a future build of BD Rebuilder. It would be an excellent improvement as would increasing the spacing between the last QP menu item and "PREV/NEXT" buttons of course. Better yet, the addition of hidden options for setting the horizontal and vertical positioning of the "PAGE" label and "PREV/NEXT" buttons. Okay, I better quit while I'm ahead. :-P In any event, I appreciate you having a look. Thanks!
Old 20th June 2021, 13:29   #30677  |  Link
jdobbs
Just note that the amount the Y value increases is dependent upon the font size selected and the number of menu items. But, I think, 50 is the default.
If I remember correctly, the PREV/NEXT buttons are positioned based upon the BACKDROP. I'm guessing that the backdrop in your menus are created as a part of the background image? I guess I could also add an option to force the height/width of the backdrop.
That whole quick menu feature was a lot of work... it's good to see that someone is getting some use out of it.
Old 20th June 2021, 16:33   #30678  |  Link
Lowpro
Are you sure about selection of the font size? I'm not seeing that as an option. Measuring in Photoshop it looks to be a 20pt font. It's the perfect size I think. I've never felt the need to change it anyway.
That's what I've observed. The "PAGE" label and "PREV/NEXT" buttons are positioned based upon the BACKDROP. And yes, I'm not using the BACKDROP. I have it set to be fully transparent. Instead I'm including the backdrop as part of the background image that way I can determine the width and height myself, including how much padding I'd like around the QP menu items. (See below.) My preference is to have the width of the backdrop remain the same from page to page, the height still changing based on the number of QP menu items on the given page. I'm using a unique background image per page.
With "The Andy Griffith Show" my backdrops are actually the same width across all 8 seasons, page to page, season to season. (See above.) It makes for much faster work when creating so many menu backgrounds. More importantly, I like the uniformity. In this case I determined the width of the backdrop based on the longest QP menu item across all 8 seasons. I then set the width of the backdrop so that it extends out 96 pixels or so past the extents of that QP menu item on each side. That's then the backdrop width I used across the entire TV series. (Click here to view the Blu-ray menus for all 8 seasons.)
An option to independently force the height and width of the BACKDROP would be excellent. I'm not sure that would be enough for me to start using the actual BACKDROP again though as I'd no longer be able to control the precise placement of the QP menu items on the BACKDROP. By making the BACKDROP fully transparent I'm able to position just the QP menu items basically. I include the backdrop within my background image which allows for setting the precise height, width and position of the backdrop. I then position the QP menu item selection area using "MENU_HORIZONTAL" and "MENU_VERTICAL", so that the QP menu items fall precisely where I'd like them to on my background image (with included backdrop).
I can only imagine how much work was involved and yes, I'm getting a ton of use out of the feature. It's actually the only thing I use BD Rebuilder for. Well, I do occassionally create a Movie-Only Backup of a given Blu-ray. Most of the time I use Clown_BD to do that though. For everything else aside from Blu-ray menu creation I use multiAVCHD. That being said, for all of my QP menus I'm using BDedit to customize the QP menu item and page navigation behavior anyway. As such, it's not a big deal to adjust the "X" and "Y" coordinates for the "PREV" and "NEXT" buttons myself. Again, it didn't occur to me I could just change the button positioning using BDedt. Setting the vertical spacing between the last QP menu item and the "PREV/NEXT" buttons from 40 to 50 would still be a welcome change though.
And perhaps you can shed some light on this for me. The "PAGE" label is still eluding me. Well, I'm calling it a label. It doesn't appear to be a button and isn't present in BDedit that I can see. I'd love to be able to control the placement. I'd be curious to know how that's being implemented. The "PAGE" label would look so much better if it were lined up with the other QP menu items and bottom aligned with the "PREV/NEXT" buttons per the mock-up in my previous post. An option to hide the "PAGE" label or make it fully transparent would even suffice. I could then just include the "PAGE" label within my backgroud image instead.
Old 20th June 2021, 19:08   #30679  |  Link
Lowpro
He shoots! He scores! I just came up with a workaround, so that I can reposition the "PAGE" label for my QP menus. My goal was to reposition the "PAGE" label, so that it was aligned with the other QP menu items and bottom aligned with the "PREV/NEXT" buttons as shown in the mock-up I posted a couple replies back. So as I mentioned previously, I wasn't seeing a way this could be done from BDedit. For whatever reason it just hit me. The "PAGE" label is actually part of the QP menu item selection area. That I can control the positioning of via BDRB. I can also set the position of each QP menu item using BDedit, hence my workaround. (In my case I set BD Rebuilder's backdrop to be fully transparent. I then include a backdrop within my background image instead.)
Tried it just now. It works beautifully. Once creating the QP menu initially I load the BDMV folder up in BDedit making all my updates as I normally do. This now includes adjusting the positioning of the "PREV" and "NEXT" buttons before remuxing the "99002 & 99004" M2TS files (...the QP menu items). At this point my QP menu is set to go with the exception of the "PAGE" label. To reposition the "PAGE" label I recreate the QP menu shifting the QP menu item selection area to the right by 38 and down by 16, i.e. the BDREBUILDER.INI hidden options, "MENU_HORIZONTAL" and "MENU_VERTICAL". I then copy the "99001 & 99003" M2TS and CLPI files (...the QP menu item selection area) from the resulting QP menu overwriting the same files from my original QP menu. Easy peasy lemon squeezy. Gotta love it!
Old 20th June 2021, 20:20   #30680  |  Link
MrVideo
MrVideo's Avatar
BDRB should be able to all that for you instead. Having to use BDEdit is overkill. JD said that he is looking into it.
