25th March 2021, 06:05 | #30481 | Link | |
The source was from Blu-ray, but I have the older BDP-83; perhaps there were some firmware updates on yours that are not on mine. |
25th March 2021, 06:37 | #30482 | Link | |
BTW, sorry for the delay, but $100 is on the way! I hope that helps make up for the off-chance, miniscule, and extremely rare, probably negligible occurrence if it actually exists, when I might possibly annoy someone (and no comments from the Peanut Gallery please. JD's opinion is the only one that counts and I just made a donation ) |
25th March 2021, 22:15 | #30486 | Link |
[03/25/21] BD Rebuilder v0.61.21
[11:37:58] Source: LOGICAL_VOLUME_ID_00000 - Input BD size: 10.62 GB - Approximate total content: [01:49:39.239] - Windows Version: 6.2 [9200] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MP4 Container, NO_RESIZE, AutoGOP, Auto-AAC - Quality: High Quality (Default) - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 - Resuming from previously started job. [11:38:00] PHASE ONE, Encoding - [11:38:00] Processing: VID_00000 (1 of 1) - [11:38:00] Reencoding video [VID_00000] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 157,744 frames - [11:38:01] Reencoding: VID_00000, Pass 1 of 1 - Encode failed. Aborting. - BD-Rebuilder v0.61.21 - Windows Version: 6.2 [9200] - Working Path Free Space: 32.66GB - AVISYNTH Version: 2.6.0.6, Ok - HAALI Splitter: 1.9.42.1, Ok - FFDSHOW: 4504, Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - AnyDVD settings check: Ok. - X264: Ok - X265: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [12:30:06] - Failed video encode, aborted [03/25/21] Checking System Settings - BD-Rebuilder v0.61.21 - Windows Version: 6.2 [9200] - Working Path Free Space: 32.66GB - AVISYNTH Version: 2.6.0.6, Ok - HAALI Splitter: 1.9.42.1, Ok - FFDSHOW: 4504, Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - AnyDVD settings check: Ok. - X264: Ok - X265: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [03/25/21] Systems Settings Check complete Been using BD Rebuilder for about 6 years now w/o issue. Had to jump to a new machine with Windows 10 on it and Ive been having issues such as that posted above. I am sure it's user error... like I said it worked flawlessly on Windows 7 to the point where I haven't changed the settings in years. A new machine made me do just that and what we have above is the byproduct. Thanks for any help! Last edited by Jackie Treehorn; 25th March 2021 at 22:17. |
25th March 2021, 22:17 | #30487 | Link |
Ooops... INI file below
[Options] VERSION=0.61.0.21 ENCODER=0 MODE=3 ENCODE_QUALITY=2 ONEPASS_ENCODING=0 AUTO_QUALITY=1 MOVIEONLY_TYPE=21 ALTCRF=23 ALT_TARGET=1024 ALT_CRF_TARGET=1024 ALTMETHOD=0 ALTAUTOCROP=0 PRIORITY_CLASS=0 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=all SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=0 RESIZE_1440=0 RESIZE_720=0 DEINTERLACE=1 SD_TO_1080=0 IGNORE_3D=0 CONVERT_WIDE=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=1 AUDIO_DRC=0 DECODER=0 AVCHD=1 REMOVE_WORKFILES=0 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=0 IVTC_PULLDOWN=0 ASSUME_DVD_PAL=0 FRIMSOURCE=0 COMPLETION_BEEP=0 OUTPUT_SBS=0 NEROAAC=0 SUPTITLE=0 PGSTOSRT=0 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=1 CUSTOM_TARGET_SIZE=23500 [Paths] SOURCE_PATH=D:\ WORKING_PATH=C:\USERS\JWALTMAN21\DOCUMENTS\WORKING\ |
26th March 2021, 13:58 | #30488 | Link | |
27th March 2021, 04:49 | #30489 | Link | |
NEVERMIND... The item was pulled. My order got cancelled. CRAP! The seller must have figured out his asking price was WAY too low. Can they do that? UPDATE... I called eBay and was told since my order was confirmed and my card was charged before the item was removed, the seller is required to ship the item. I can file a claim if he doesn't. So we'll see what happens, fingers crossed... Last edited by spotswood; 27th March 2021 at 21:09. Reason: addl info... |
27th March 2021, 15:14 | #30490 | Link | |
27th March 2021, 15:21 | #30491 | Link | |
27th March 2021, 16:49 | #30493 | Link |
Good morning. I have a doubt. if when I make a backup in bd25 the estimated time is 50 hours with 2 passes, how much will the estimated time be if I make a backup in bd50 of the same film with the same settings? 25 hours?
28th March 2021, 14:54 | #30495 | Link |
@Jackie Treehorn
After the job has failed, check the file LASTCMD.TXT in the BD Rebuilder folder. It has the command line that failed contained within it. Please post that command line here so I can see if there is something obvious wrong. Also, open a CMD window and cut/paste the command into it and see what error is occurring. Then please paste that here as well. |
28th March 2021, 15:54 | #30496 | Link | |
As a temporary fix, you can set UHD_V3_MODE=1 in your INI file while doing that disc -- but don't forget to reset it when done (it has the same effect as selecting "Convert BD to UHD-BD (HEVC) Format" from the output menu). |
28th March 2021, 16:38 | #30497 | Link | |
28th March 2021, 16:48 | #30498 | Link |
Microsoft Windows [Version 10.0.19042.867]
(c) 2020 Microsoft Corporation. All rights reserved. C:\Users\jwaltman21>"C:\Users\jwaltman21\Documents\BD_Rebuilder\tools\x264.exe" "C:\USERS\JWALTMAN21\DOCUMENTS\WORKING\WORKFILES\VID_00000.AVS" --preset medium --bluray-compat --b-pyramid none --weightp 1 --slow-firstpass --qpmin=0 --crf 23 --level 4.0 --qpfile "C:\USERS\JWALTMAN21\DOCUMENTS\WORKING\WORKFILES\VID_00000.CHP" --aud --nal-hrd vbr --pic-struct --vbv-bufsize 15000 --keyint 24 --min-keyint 1 --ipratio 1.1 --pbratio 1.1 --vbv-maxrate 15000 --threads auto --thread-input --stats "C:\USERS\JWALTMAN21\DOCUMENTS\WORKING\WORKFILES\VID_00000.AVS.264.stats" --output "C:\USERS\JWALTMAN21\DOCUMENTS\WORKING\WORKFILES\VID_00000.AVS.264" avs [info]: 1920x1080p 0:0 @ 24000/1001 fps (cfr) x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2 x264 [info]: profile High, level 4.0, 4:2:0, 8-bit [2.3%] 3689/157744 frames, 36.58 fps, 1080.46 kb/s, eta 1:10:10 |
28th March 2021, 18:21 | #30499 | Link | |
Elit Amans
//LD
Windows 11 Pro 64-bit, AMD Ryzen 9 5950X@3.40GHz, 32GB, NVIDIA RTX 2070 8GB, PIONEER BDR-S09XLT, ASUS BW-16D1HT, LG CX 65", Panasonic DP-UB820EB-K, Sony PS3 & PS5 |
28th March 2021, 23:54 | #30500 | Link |
ABR not VBR?
Hey again... trying different options with the new UHD_CONVERT_ENABLE=1 mode and think I found a bug maybe? After running a job in CQM, I switched to One Pass (VBR) Encoding (pic attached), then when starting the job the log shows the file being encoded in ABR mode instead of VBR mode (see Quality: line in pic). Is this correct? I ran several jobs last night and swore the log showed VBR mode (logs deleted unfortunately). I've tried going back and forth between CQM and VBR using different encoder/output options and it still says ABR mode when selecting VBR mode . Thanks for any help...
