16th August 2013, 07:59 | #1601 | Link |
Oh yeah, you're right. Thanks for the correction as I hadn't even noticed the RGB conversion and then the crops.
Because you can't crop in odd numbers in YV12: AviSynth's Crop Page Anyway, as Boulder points out, cropping interlaced material properly is difficult. I'd suggest waiting until after you make it progressive and then crop in even numbers. |
16th August 2013, 11:37 | #1602 | Link | |
17th August 2013, 08:34 | #1603 | Link |
So after 5 days of waiting after registering on this forum, I finally am able to post something...
I've been using the QTGMC script quite a while now. Two weeks ago I bought a new PC with a Core i7 4770 CPU and damn, a HUGE difference in encoding times compared to my old P4 desktop... Now, I've been playing around with Avisynth MT since I'm using this new setup but I can't seem to get it encoding without crashing. I've been trying out different combinations of avisynth versions and plugins from this topic but it just keeps crashing... I figured out the crashing starts happening whenever I add the "Distributor()" line in the script. If I put this line in comment, the encoding process finishes without any problems. HOWEVER: Not adding this command results in half the framerate of encoding. (Without Distributor() => 45FPS, With Distributor() => 90FPS) (I've read on previous pages in this topic the Distributor command should not be used, but can anyone explain why it drops framerate by half then?). Also, if I don't add the Distributor command only 20% of the CPU is in use so I think the multithreading capabilities of the CPU aren't even used without this command I've played with different SetMemoryMax values ranging from 400 to 1200 but still no go. I also played with the EdiThread value I am using Avidemux + AVS Proxy to route the avisynth scripts to avidemux. My encoding settings are x264 video with MP3 audio in an MP4 container. The source files are lossless DTV captures with Lagarith and uncompressed WAV audio. This is my current Avisynth script: SetMTMode(3, 6) AVISource("E:\capture.avi", true) SetMTMode(2) AssumeTFF() QTGMC(Preset="Very Fast", EdiThreads=1) LanczosResize(720,540) Crop(0, 2, 0, -2) AddBorders(0, 2, 0, 2, color=$000000) # Distributor() Oh and, the crashes occur some point at random in the encoding process. Sometimes it crashes after 4 seconds, sometimes when it hits 90%, sometimes it doesn't even crash at all but then I get an output file with audio or video glitches |
17th August 2013, 11:18 | #1605 | Link | ||
Also, define crashing. What crashes? Is there an error message? Quote:
This very much depends on the application you serve the frames to. I'm only aware of two scenarios where you need the Distributor() call in the script - serving frames to ffdshow and some piping tools like the original avs2yuv which don't call this function.
Groucho's Avisynth Stuff Last edited by Groucho2004; 17th August 2013 at 11:24. Reason: Additional info |
17th August 2013, 17:13 | #1606 | Link | ||
It's the avsproxy executable which crashes while encoding. Quote:
It didn't crash Is there any good alternative to Avidemux I could use (which has a nice GUI and built in encoders for example)? I haven't worked with encoders from commandline yet but I will try it. |
17th August 2013, 18:42 | #1607 | Link | |
No idea about gui options. Many people here seem to use Megui.
Groucho's Avisynth Stuff Last edited by Groucho2004; 17th August 2013 at 18:45. |
17th August 2013, 19:12 | #1608 | Link | |
I will contact the creator of Avidemux about this issue. Thanks alot for the help & hints! |
24th August 2013, 13:45 | #1610 | Link |
The speed of stupid
I seem to be having some.. "Funny" issues with the plugins. Both the "normal" modded plugins and the "updated to the new 2.6 interface" modded plugins return an error that looks somewhat like this:
(Don't mind the "..\AviSynth 2.5\.." location, I do use the latest of 2.6 MT) The real issue comes when most of them work just fine unmodded, except masktools2 - which instead returns an error like this: Any ideas? |
2nd September 2013, 14:21 | #1612 | Link | |
if it was not possible to extract sharpen, at least you know how to disable everything else, including the deinterlace? |
10th September 2013, 07:06 | #1616 | Link | |
Hello guys.. I tried to use this Script and here my result Screenshot Comparison
I used this settings.. Can I do something else to increase quality? Quote:
10th September 2013, 07:33 | #1617 | Link |
You may increase sharpness. But you can never "increase quality". What is not recorded is lost.
And regarding sharpness and artifical detailling, I believe you already exaggerated. Half as slow presets may have provided just as much change. Possibly too much anyway. |
10th September 2013, 08:08 | #1618 | Link |
Yeah I didn't mean literally increase quality (you understood), ok I will play more with the settings, what I wanted to ask is do I need anything more except QTGMC script and MSharper to make image look better?
Edit: I played with settings and ```QTGMC(Preset="Faster", NoisePreset="Faster")``` gave better result from all (actually NosiePreset didnt do any change so i left faster) Last edited by Xoemab; 10th September 2013 at 08:21. |
16th September 2013, 09:07 | #1619 | Link |
Hi. I started using QTGMC recently and I like it very much, it's way better than yadif I was using before. I have a problem with the result though.
Source: http://oi41.tinypic.com/242x1fn.jpg QTGMC: http://oi41.tinypic.com/2vbodhf.jpg Yadif: http://oi42.tinypic.com/2nun2go.jpg Another frame with QTGMC: http://oi43.tinypic.com/2ngwpyr.jpg As you can see there is a problem with court lines, they are blurred. Is there any setting so I can fix that? I encode mostly football and basketball matches so it is very important to me. I am using QTGMC 3.33 (from here), Avisynth 2.6 alpha 4 with 2013.03.09 SEt's MT version and modded plugins package. My avisynth script is this (using StaxRip): Code:
LoadPlugin("---\StaxRip_1.1.9.0\Applications\AviSynth plugins\FluxSmooth\FluxSmooth.dll") SetMemoryMax(1200) SetMTMode(3, 4) DirectShowSource("---\test.ts", audio=false, convertfps=true, fps=25) Crop(0,0, -Width % 8,-Height % 8) ConvertToYV12() SetMTMode(2) QTGMC( Preset="Slow", EdiThreads=3 ) SelectEven() FluxSmoothT(4) Last edited by Hacker?pcs; 16th September 2013 at 09:16. |
16th September 2013, 09:31 | #1620 | Link |
I recommend you index your ts for example with DGIndexNV instead of using DirectShowSource+convertfps.
Depending on your ts splitter and video codec, convertfps may change your video in order to keep it at 25fps. This is not a good thing for interlaced video. Also, there's no need to put that ConvertToYV12() since the .ts is already YV12. |
