5th June 2010, 20:50 | #1 | Link |
Intel i7 and AMD X6 encoding comparision
Hello
I am going to make video encoder server and I can't decide for right processor. Anybody can compare video x264 encoding on i7 and X6 processor. I think first pass and second pass on both processors ( 1 thread ) pure power with same x264 settings I would like to see which frequency get same fps on both processors. Last edited by xlazom00; 5th June 2010 at 21:31. |
5th June 2010, 21:26 | #2 | Link |
i7 (4-cores) at the same clock is still slightly faster than x6.
5th June 2010, 22:03 | #5 | Link |
I saw this picture.
But I would prefer some results from you guys (x264 team or some x264 devs). I don't really think that that guys from anandtech.com know something about x264 and how many threads they used. It's looks like 6 threads on X6 and 8 on i7. maybe cores+1. I prefer pure power per one thread ( what AMD and Intel bake to processors). |
5th June 2010, 22:09 | #6 | Link | |
5th June 2010, 23:30 | #7 | Link |
This is the brand new Intel Core i7-875K (basically a i7 870 with unlocked multiplier) vs.the AMD Phenom II X6 1090T Black Edition.
http://www.hexus.net/content/item.php?item=24850&page=6 Apparently they overclocked it to 4,135 Mhz, as far as I can see they didn't test the Phenom X6 overclocked. |
6th June 2010, 00:52 | #10 | Link | |
From my experience You don't get linear speed up with every core you have. Let's say 1 thread 60fps 2 threads 120 fps it's working only with some configuration of x264 But if you want good output quality(pic/size) you never get linear speed up of x264 That is problem with all the benchmarks we see here In most cases some of cores in your CPU just do nothing. That is reason why I want to see benchmark of x264 1 thread on AMD X6 and INTEL i7 Last edited by xlazom00; 6th June 2010 at 00:58. |
6th June 2010, 01:14 | #11 | Link |
In my opinion unless you are going with super super high end processors (like the Intel Extreme one's), most of the ones listed in the benchmarks are fairly close in comparison. From those tests, most of the decent processors vary in speed from about 5-10%, and each has their own strength.
I recently got the AMD Phenom X6 1055T and have not looked back since. With no overclock (2.8 GHz) at full load and stock fan it only heats up to around 40 degrees (Celsius). So I will no doubt overclock it at least some soon enough. To me, it wouldn't have been worth it to buy those Intel processors plus a motherboard. I found a bundle (cpu/mobo) for $200, where the comparable Intel equivalent was either double or more. To me buying those slightly better Intel processors would have only produced diminishing returns. |
6th June 2010, 01:15 | #12 | Link | |
If you find a site or someone that's done single threaded tests plz post a link. The kicker is most of the I7 1366 socket chips hit 3.8ghz + very very easily, even on a stock cooler. Once you hit those speeds everything changes. Last edited by CpT; 6th June 2010 at 01:17. |
6th June 2010, 03:03 | #13 | Link |
ok heres a 1055T thuban at 3.9ghz 1 threaded and then with 6 cores:
i used a newer x264.exe as it uses all my cpu power at 100% on the first pass, whereas the one in the pack seems to cap at 50% which is bs... Results for x264.exe r1342 -------------------------- 1 thread encoded 1442 frames, 35.84 fps, 3902.49 kb/s x6 threads encoded 1442 frames, 128.72 fps, 3906.74 kb/s encoded 1442 frames, 133.95 fps, 3906.74 kb/s encoded 1442 frames, 133.56 fps, 3906.74 kb/s 1 thread encoded 1442 frames, 6.42 fps, 3967.80 kb/s x6 threads encoded 1442 frames, 36.90 fps, 3959.99 kb/s encoded 1442 frames, 37.09 fps, 3959.18 kb/s encoded 1442 frames, 37.17 fps, 3959.98 kb/s |
6th June 2010, 03:09 | #14 | Link | |
Posts: n/a
So the overclock isn't a feature solely in Intels favor ... Tek |
6th June 2010, 03:13 | #15 | Link |
Which version of x264 did you use?
I'll run the benchmark as well on a 980x using the same x264 version. Currently the chip is at 4.2Ghz, I'll drop the clocks to 3.9 and run a single thread bench. That's good to know. Last edited by CpT; 6th June 2010 at 03:16. |
6th June 2010, 03:34 | #16 | Link |
i used this one, but the x86 version as i am on xp still
http://forum.doom9.org/showthread.ph...28#post1405128 |
6th June 2010, 04:40 | #17 | Link |
1 thread first pass:
56.21 1 thread 2nd pass: 10.08 Frankly I was expecting a lot more fps out of this chip... Especially considering the price... That's on an intel 980x @ 3.9 with hyperthreading disabled using the 32bit version you linked. When I have the time tomorrow I'll let it run and finish all 4 tests. Pretty tired and semi depressed atm... |
6th June 2010, 21:09 | #20 | Link |
There's an interesting x264 benchmarks where everybody can post their results: http://forums.techarp.com/reviews-ar...ark-3-0-a.html
They use rev. 1342 Current results: http://www.techarp.com/showarticle.a...tno=520&pgno=7 (there's no AMD X6) |
amd, intel, x264 |
