6th March 2023, 11:28 | #20021 | Link |
Keep in mind that when you edit video then you will also have to reencode audio stream. Copy stream will not work in this case. You will end up with obvious a/v synch issues.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 6th March 2023 at 11:40. |
6th March 2023, 11:50 | #20022 | Link | |
Formally known as .......
So is it possible to do both in RipBot ?? Last edited by TDS; 6th March 2023 at 12:00. |
6th March 2023, 12:53 | #20023 | Link |
This should work
#AudioSource Import("C:\Temp\RipBot264temp\job1\job1_a1.avs") Trim(0,1) Code:
#AudioSource Import("C:\Temp\RipBot264temp\job1\job1_a1.avs").Trim(0,1)
6th March 2023, 13:51 | #20024 | Link | |
video=Trim(video,100, 0) Code:
#AudioSource Import("C:\Temp\RipBot264temp\job1\job1_a1.avs") Trim(0,100) This is an actual call:- Code:
#AudioSource LoadPlugin("D:\RipBot264\Tools\AviSynth plugins\lsmash\LSMASHSource.dll") audio=LWLibavAudioSource("C:\Temp\RipBot264temp\job1\1_audio_English_DEFAULT.eac3",cachefile="C:\Temp\RipBot264temp\job1\1_audio_English_DEFAULT.eac3.lwi").ConvertAudioToFloat.ResampleAudio(48000) Last edited by TDS; 6th March 2023 at 13:56. |
6th March 2023, 14:31 | #20025 | Link |
#AudioSource Import("C:\Temp\RipBot264temp\job1\job1_a1.avs") Trim(100,0) Code:
#AudioDub AudioDub(video,audio)
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 6th March 2023 at 14:37. |
7th March 2023, 02:23 | #20026 | Link | |
Script/call (generated by RB):- Code:
#AudioSource LoadPlugin("C:\RipBot264_PD 3.0\Tools\AviSynth plugins\lsmash\LSMASHSource.dll") audio=LWLibavAudioSource("E:\Temp\RipBot264temp\job10\1_audio_English_DEFAULT_DELAY23ms.aac",cachefile="E:\Temp\RipBot264temp\job10\1_audio_English_DEFAULT_DELAY23ms.aac.lwi").ConvertAudioToFloat.ResampleAudio(48000)Trim(150,0) #Delay audio=DelayAudio(audio,0) #Tempo #Normalize #AudioDub AudioDub(video,audio) This call (below) doesn't make any sense to me, it seems irrelevant, somehow And the ONLY place I can find this is in job10\job10.avs Code:
#AudioSource Import("C:\Temp\RipBot264temp\job1\job1_a1.avs") Trim(100,0) |
9th March 2023, 14:21 | #20027 | Link | |
9th March 2023, 14:33 | #20028 | Link | |
I have found another app that does the job. Certainly would be nice to have a basic edit function in RB, tho. |
22nd March 2023, 17:24 | #20029 | Link |
Hi all!
Very usefull trim fuction by editing script. thanks! @Atak: Can you add framedbl (for avisynth) for 23,976 fps to play @ 48 fps until 120 fps? (x2, x4x x8 and assume 47.952, 48, 100, 119.88 and 120 fps most common cases used into some uhd movie like gemini man). http://avisynth.nl/index.php/FrameDbl riptbot264 already double interlaced source @50 or @59,94 fps for progressive scan. another plugin: http://avisynth.nl/index.php/SVPflow Other info: https://github.com/baowenbo/DAIN https://github.com/hzwer/Arxiv2020-RIFE https://github.com/nihui/rife-ncnn-vulkan https://github.com/tarun005/FLAVR https://github.com/JihyongOh/XVFI @TDS: missing lut for itu bt 601 to pal in your package 3.0. I've send you pm wirh new .zip. Thanks. Last edited by darkio; 23rd March 2023 at 00:58. |
23rd March 2023, 13:04 | #20031 | Link |
@atak, plesse add invert axis option for auto resize after crop.
For example: 576 for height, automatically find width after crop. (I prefer a lot), or free resize without auto height (I'm using my personal resizer calculator with itu parameters). Then, add 2 or 3 audio tracks in batch mode... very frustrating for multiple episodes.... Last edited by darkio; 23rd March 2023 at 13:59. |
23rd March 2023, 14:14 | #20033 | Link |
ok.
Esample for Blu-ray with 244,0,244,0 crop values (left, up, right, down). My "active" movie is 1432x1080. I prefer set 1080 for width instead 1432 for height. The height box is grey abd cannot set manually this value. I set 1432 on the left box for auto 1080 value. for 540 or 576p I need to set 716 or 764 for auto height. Ripbot264 calculates 574 as value, so then set manually to 576.... Edit: Hybrid encoder have invert axis in resize tab too, but is very boring to use. Last edited by darkio; 23rd March 2023 at 14:36. |
23rd March 2023, 14:32 | #20034 | Link | |
Is that using Batch ?? You need a special script to do all that, and then you could use it in both single & batch job creation. Hybrid is VERY complicated Last edited by TDS; 24th March 2023 at 01:52. |
23rd March 2023, 14:44 | #20035 | Link |
I normally do not mind the black bands above and below if the film is letterboxed.
Ripbot already uses add borders as a script. they bother me more on the left and right for native 4:3 letterboxed video. Hybrid is a good encoder, but not user friendly gui....also have good avisynth or vapoursynth script, but is very boring... https://www.mediafire.com/file/5b200...r1.1b.rar/file this is our resizer written by my dear friend Frandan. It calculates the correct aspect ratio for all video sources with set presets plus a customisable one. Italian language, but very simple to use. Last edited by darkio; 23rd March 2023 at 15:05. |
24th March 2023, 01:55 | #20036 | Link |
I've just downloaded the latest Hybrid (1.1Gb), just to have another "look around".
Tried your little app, and yes, shame it's in Italian, for me. Requries .Net Framework 3.5 to use Last edited by TDS; 24th March 2023 at 02:38. |
29th March 2023, 13:02 | #20038 | Link |
Grumpy Old Man.
It's time for another new build...
A month to the day, here's version 4.0.
Many updates & new scripts & filters, some have been removed Scripts will not be compatible with previous builds. And to keep the build sizes to a minimum, the LUT's folder is a separate download, and can be copied to wherever you like. I'm trying something new today, no more hyperlinks, simply click on the "PD Builds, etc" in my "sig", and hopefully, all will be revealed.
Not poorly done, just doin' it my way !!! Live every day like it's your last, because one day, it will be !! (M$B) Last edited by Pauly Dunne; 4th April 2023 at 01:59. |
31st March 2023, 11:10 | #20039 | Link |
Friend of a friend..
Is there any way to increase the FPS of the video ?
I tried the AssumeFPS, but it actually just sped up the video, but the audio was still "normal", so it's instantly very out of sync It would also be very handy to be able to do some basic Avisynth editing of the video & audio tracks, for those pesky intro's of TV episodes. |
31st March 2023, 13:50 | #20040 | Link | |
