Go Back   Doom9's Forum > Hardware & Software > PC Hard & Software
Old 16th July 2024, 15:43   #1  |  Link
moutezz
Some good software to download Youtube videos ?
Hello everyone... I hope you're okay
This is as indicated in the title, I would like to know if there's a good software which can replace my IDM so that I can take videos coming from Youtube... therefore yes Youtube regularly changes this way of doing things whether for advertisements or how to recover files against software, now I can no longer take videos from Youtube using IDM...
I tried with Download Accelerator Plus (DAP) but I haven't found how to do it yet !!! Any suggestions for me, please ?
THANK YOU
moutezz is offline   Reply With Quote
Old 16th July 2024, 16:07   #2  |  Link
Posts: n/a
THANK YOU
I had this exact same issue a week or so ago, because I download a lot of stuff from YouTube with IDM, and it just couldn't access the server, so I Googled it and it turns out I just had to update the very latest version of IDM and it all worked again
Old 16th July 2024, 22:39   #3  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
Download yt-dlp.exe (2024.5.27.0 works good here ATM) and put it into MPC-HC or MPC-BE root folder.
Configure yt-dlp parameters. MPC-HC: Advanced. MPC-BE: Playback -> Online Media
Copy youtube URL.
MPC-HC or MPC-BE: File -> Open Media -> Paste URL -> OK
File -> Save Copy
Old 17th July 2024, 00:00   #4  |  Link
Posts: n/a
Copy youtube URL.
File -> Save Copy
That's good to know
But when IDM works, it's a lot easier than that.
Old 18th July 2024, 12:07   #5  |  Link
moutezz
Copy youtube URL.
File -> Save Copy
Too much work... I can't past a youtube link in every download !!!
Old 18th July 2024, 12:10   #6  |  Link
moutezz
I tried the IDM 6.42 Build 12 and it didn't work !!!
Old 18th July 2024, 12:11   #7  |  Link
ChaosKing
JDownloader. You only have to copy the link and it will be added to jd.
Old 18th July 2024, 13:52   #8  |  Link
Posts: n/a
I'm using Build 14 and it works, there's also Build 15 available, try them, 14 worked for me.
Old 1st August 2024, 08:57   #9  |  Link
Posts: n/a
Well, the 430 error thing happened again, so I updated to 6.42 b18, and it was good again
download, idm, soft, videos, youtube
