19th May 2013, 13:42 | #184 | Link |
libqxt -> "sudo apt-get install libqxt-dev", sadly not available for Ubuntu 10.04 (probably since 10.04 uses Qt4.6), but on 12.04 (which uses 4.8)
»-std=c++11« requires gcc 4.7+, iirc Ubuntu 13.04 is the first Ubuntu version using gcc 4.7+, sadly it also uses Qt5 as default which breaks some of my projects due to some bugs that might get fixed by 5.0.3. |
19th May 2013, 14:13 | #185 | Link |
Pajas Mentales...
for expample in archlinux is possible use 3 versions of Qt: Qt3, Qt4 and Qt5. the version of Qt to use is selected by the app qtchooser (from Qt project). the version of gcc is 4.8, but can install other version through AUR (user repository, no binary, need build)
https://launchpad.net/ubuntu/+source/libqxt update your ubuntu or change distro XD |
29th May 2013, 03:45 | #189 | Link |
Heya,
I posted an issue on the github page but maybe someone has an answer here... I'm trying to process multi-language idx/subs into xml/png using the CLI, but it outputs only the first language. So, is there a command to either output ALL language streams to different individual outputs, or to select a different language ID from the source file? |
30th May 2013, 14:09 | #193 | Link |
PgcEdit daemon
Strange bugs when converting SUP to XML/PNG
I've tried to convert this SUP file to XML/PNG from the command line, and I've discovered several bugs.
First bug: Many subtitles are made of 2 PNG images. The first one is the correct subtitle, converted to PNG without problem, but the second image is totally black (without transparency). I wonder from where they are coming from. (I'm not sure it's really a bug, but it's strange, and it's the first time I see that black pictures.) Second bug: Many subtitles are made of 2 exactly identical PNG images, apparently correctly converted. IMO, when the images are identical, they should not be saved twice. But that's not the problem. In the XML file, the same subtitle is supposed to use more than 2 PNG images (usually 5). But only 2 images exist in the directory, and therefore the XML file references non-existing PNG images. Of course, that causes many problems. Third bug: Since I have discovered that the bugs 1 and 2 do not happen if I convert all subtitles to IDX/SUB and then the IDX/SUB to XML/PNG, I have converted successfully the subtitles that way. But the original subtitle stream has 3 forced captions, so I have decided to convert them also, with the same method. The first conversion (from SUP to IDX/SUB) works fine, and I have the 3 forced captions in the SUB file. But when I try to convert that SUB file to XML/PNG, BDSup2Sub++ crashes immediately. The crash happens ONLY when using the command line. The same conversion works fine from the GUI. Note that the subtitle stream comes from the Ice Age 3 3D BD given when you buy a Panasonic TV. That BD is well known to have some bugs in the MVC video stream, and maybe it has also somewhat bad subtitle streams. Anyway, these 3 bugs are strange, and I suppose you will be interested in examining the SUP file. BTW, any chance to have the option to convert the SUP to 3D SUB soon? Currently, due to the 3 bugs above, I can't convert them reliably. Thanks in advance.
30th May 2013, 18:22 | #194 | Link | |
Posts: n/a
Yeah, it will be fixed in the next version.
Yeah, it's still something that will be added. Quote:
It will probably come in the version after next. When that will be I can't say. I'm still busy working on a side project I committed to for another person that is taking longer than expected and haven't had tons of time to start work on the next version yet. I'm definitely working on things, it's just coming along slow. Hopefully by mid June I can get back into committing more time to working on it. |
15th June 2013, 13:00 | #196 | Link |
got a small sup file of only 5 lines. bdsup2sub++1.0.2_Win32.exe creates a vobsub file with those split into 48 lines, most with a 0,171 duration. It's the same 5 lines but they repeat themselves several times.
Warning for every line: WARNING: duration of frame 1 is shorter than 520ms tried also with java versions (older and newer) and they seem to keep them at 5 lines. http://www.sendspace.com/file/vtd3ae |
21st August 2013, 08:40 | #198 | Link |
This sub (password is your nick) is ripped straight from DVD with VSrip and locks up BDSUP2SUB++ (and even BDSUP2SUB 5.11) when switching to the second language and browsing items. Can you take a look? Thx.
MultiMakeMKV: MakeMKV batch processing (Win) MultiShrink: DVD Shrink batch processing Offizieller Übersetzer von DVD Shrink deutsch |
8th September 2013, 11:37 | #199 | Link |
"ERROR: Palette ID out of bounds."
Sup here: http://www.sendspace.com/file/fi3pu3 only creates .sub file, works fine with java versions |
