Old 23rd February 2008, 17:19   #1001  |  Link
jamos
Hey Now!
Originally Posted by Thunder2001 View Post
Yes! I need only TSmuxer 1.3.1 to make an working vob file for the PS3. Changing the level from 5.1 to 4.1 an make an m2ts file. After what rename the m2ts file to vob. Thats it! Very fast and simple.
still only works for certain mkvs, you still may need to transcode either the video or audio. that is why you would use this program as it checks the files to see if they can just be remuxed or have to be transcoded.
jamos is offline   Reply With Quote
Old 23rd February 2008, 19:30   #1002  |  Link
gordho
If subtitle support is on the way then how about an option to always transcode if subtitles are detected? The rationale is that if you are letting mkv2vob extract the mkv from a rar, then the user would not know whether or not there is a subtitle track. You might assume the file does not have a subtitle track if the movie is in English but there might be a few scenes where another language is spoken.
gordho is offline   Reply With Quote
Old 23rd February 2008, 19:36   #1003  |  Link
jamos
Hey Now!
I think it will always transcode if you choose subtitles as it forces them on the screen (ie you can not toggle them off).
Old 24th February 2008, 01:14   #1004  |  Link
3r1c
I will try out the new tsmuxer.
and yes it will work without loader.exe, this file only does the download updates, just run mkv2vob.exe directly.
ill try different ways of compiling it so it doesnt set off nod32
3r1c is offline   Reply With Quote
Old 24th February 2008, 01:36   #1005  |  Link
pepitopajas
¿donate a 3ric?
pepitopajas is offline   Reply With Quote
Old 24th February 2008, 01:40   #1006  |  Link
carbonkid
Hi, with this new version I keep getting the same error. Insufficient Disk space, I'm trying to convert a movie with 8 GB and I have 20 GB free. It is set to never transcode because it's a 720p file.
carbonkid is offline   Reply With Quote
Old 24th February 2008, 01:49   #1007  |  Link
gordho
does your temp drive have enough free space?
Old 24th February 2008, 01:53   #1008  |  Link
carbonkid
19 GB on template drive, 20 GB on destination drive.
I'm trying another file and it's working, maybe it's an imcompatibilyti with that specific file.
Old 24th February 2008, 01:57   #1009  |  Link
3r1c
20gb is not enough space to convert a 8gb file.
you need 3x the space of the mkv file.
if new tsmuxer does it directly it will be possible to do it with 1x so maybe wait until tomorrow.
Old 24th February 2008, 02:04   #1010  |  Link
carbonkid
Thanks for the heads up.
Another thing I converted a file with DTS, and now I hear noises in high pitchs sound (hope you understand my english). It's this a problem with the program?
Old 24th February 2008, 02:04   #1011  |  Link
Audioboxer
AWESOME update 3r1c!
I'm thinking of donating some money your way.
I'm waiting for you to update tsmuxer to 1.3.1 - If everything works ok.
I could manually update, but id rather wait incase some other program changes are needed to comply with the new version of tsmuxer.
Audioboxer is offline   Reply With Quote
Old 24th February 2008, 02:15   #1012  |  Link
3r1c
Yeah replacing the tsmuxer.exe in mkv2vob right now wont do anything because mkv2vob wont try to make use of the new functions.
Old 24th February 2008, 02:19   #1013  |  Link
Audioboxer
Thanks for the heads up, patiently waiting on an update then if the new version of tsmuxer works ok.
By the way, does it matter what "output file extension" you use?
Old 24th February 2008, 02:48   #1014  |  Link
carbonkid
Even after having 50GB free HDD, it will continue to say Insufficient Disk Space... , I previously stated it was 8GB but the file is only 6.56GB.
By the way, the file is Queen.Rock.Montreal.1981.720p.BluRay.DTS.x264-CtrlHD, and I've alredy tried Beowulf.2007.DirCut.720p.HDDVD.DTS.x264-ESiR with the same results. Only working file with this version Lost S04E01 720p HDTV DD5.1 x264-CtrlHD
Old 24th February 2008, 03:34   #1015  |  Link
Audioboxer
I had issues with DTS previously in MKV2VOB - It would convert ok but I'd get video speed-up.
I recommend you manually convert you DTS audio to AC3 and then run the new AC3 MKV file through MKV2VOB.
Read my post on how I done it
http://forum.doom9.org/showpost.php?...&postcount=734
Old 24th February 2008, 03:39   #1016  |  Link
3r1c
I will do some actual testing but i just looked over the free disk space code and it looks ok.
Can you tell me how far does it go before it gets to the error.
only thing i can think of is it uses the movie time length and maybe this file is reporting a very long time in error.
Old 24th February 2008, 03:42   #1017  |  Link
3r1c
the poster didnt say anything about dts not working right.
and i tested it several times with every possible transcode remux during the latest version and its working perfectly.
its possible in the older version it did this, but the method has totally changed in the new version.
converting it manually should not be necessary.
Old 24th February 2008, 03:56   #1018  |  Link
Audioboxer
Yeah, it was just a suggestion!
More likely a dodgy MKV file to be fair.
It was a tsmuxer build that gave me issues with DTS previously (1.5.2 I think). Im going to run the matrix though this new build of MKV2VOB and see if it's now working 100%.
I've not converted any DTS movies since 1.5.2 I think.
Just read this,
Great news if true, would that mean a quicker conversion as well? Not that it takes long anyway.
Old 24th February 2008, 05:09   #1019  |  Link
asif9t9
what error message do you get?
Error Extracting AAC to WAV.
asif9t9 is offline   Reply With Quote
Old 24th February 2008, 14:06   #1020  |  Link
Turntabloid
first of all - great stuff!
Now to my problem:
I get the same error - 'insufficient disk space' with the new version!
I am using XP and a 1TB external drive to store and convert with loads of free space.
Is it possible, that the program still uses the TEMP folder on C?
The file is 10GB, my free space on C is 25GB.
Is there any chance, the program will not need to use the TEMP on C in the future?
Many thanks!
Turntabloid is offline   Reply With Quote
