Old 21st August 2023, 16:50   #1  |  Link
jriker1
Skipping NAL Unit 63
I am encoding videos and when I do my dolby vision files I get the message in the subject over and over again thru the entire encode process. Basic encode commands are:
ffmpeg -i <source>.mkv -sn -an -f yuv4mpegpipe -strict -1 -pix_fmt yuv420p10le - | x265-10b - --input-depth 10 --output-depth 10 --y4m --preset slow --hdr10 --hdr10-opt --high-tier --repeat-headers --crf 19 --master-display "G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,1)" --max-cll "1000,629" --chromaloc 2 --no-sao --range limited --keyint 24 --colormatrix bt2020nc --colorprim bt2020 --transfer smpte2084 --dolby-vision-rpu rpu.bin --dolby-vision-profile 8.1 --vbv-bufsize 160000 --vbv-maxrate 160000 <output>.hevc
Should I just be ignoring these constant messages scrolling on the screen or is there a fix/alternative?
jriker1 is offline   Reply With Quote
Old 21st August 2023, 17:52   #2  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
It's harmless. ffmpeg doesn't have all DV profiles implemented in decoding, so you get that message.
TV: Samsung QE50Q60T AVR: Denon AVR-X1700H CD: Yamaha CD-S300 Tuner: TechniSat 143v3 BD: Samsung UBD-M8500 Speakers: Klipsch Reference Phono: Audio-Technica AT-LP120X Amp: Marantz PM6007
microchip8 is online now   Reply With Quote
Old 21st August 2023, 22:12   #3  |  Link
jriker1
Thanks. I'll ignore it but since it's so pervasive on the console window scrolling thru what looks like millions of these messages, guessing it's effecting thruput.
Old 22nd August 2023, 05:12   #4  |  Link
microchip8
microchip8's Avatar
Here is the ticket to that. Might want to comment on it so it hopefully finally gets resolved.
https://trac.ffmpeg.org/ticket/5688
Old 22nd August 2023, 07:44   #5  |  Link
rwill
It is not 'millions', it is one line per frame. A movie has what? 150k to 200k pictures if its 24 Hz?
If you are concerned about speed: pipe the stderr output from ffmpeg to a file instead of console with "2> garbage.txt" after the ffmpeg command. This should prevent a redraw of the console.
For your example this should be
ffmpeg -i <source>.mkv -sn -an -f yuv4mpegpipe -strict -1 -pix_fmt yuv420p10le - 2> garbage.txt | x265...
Old 22nd August 2023, 19:14   #6  |  Link
benwaggoner
You're likely right on the throughput. I remember a version of PageMaker back in 90's was determined to spend 4x more time reporting on the progress of an import than it did on the import itself, as it updated the number of characters processed after every character.
Ben Waggoner
My Compression Book
Old 22nd August 2023, 23:49   #7  |  Link
quietvoid
It's not one per frame, it's one per UNSPEC63 NALU.
It's a whole bitstream, so it could easily go into the millions (parameter sets, SEIs, slices) are all under that type.
That said, I doubt it has any impact on transcoding.
Even for decoding it would be negligible.
LG C2 OLED | GitHub Projects
quietvoid is offline   Reply With Quote
Old 23rd August 2023, 10:32   #8  |  Link
excellentswordfight
Lost my old account :(
If you dont want it to clutter up the console just hide it with setting a less verbose loglevel (e.g -loglevel quiet)
excellentswordfight is offline   Reply With Quote
Old 1st September 2023, 16:47   #9  |  Link
Balling
Technically it does. Just apply the patches: https://patchwork.ffmpeg.org/project...t/?series=7164
Balling is offline   Reply With Quote
Old 3rd September 2023, 12:36   #10  |  Link
microchip8
microchip8's Avatar
They don't fix NAL 63.
Old 13th September 2023, 18:59   #11  |  Link
caphp
Hi jriker1,
you can use the following parameter:
ffmpeg.exe -loglevel error -stats -i <source>.mkv <followed by your parameters...>
This suppresses the NAL Unit messages and still shows you all errors (if any occur), including ones which can be recovered.
Hope this can help you.
Bye
caphp is offline   Reply With Quote
dolby vision, ffmpeg
