Old 27th June 2023, 22:31   #9121  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Solution is Simple. --ctu 16 for SD , --ctu 32 for HD/FHD and --ctu 64 for UHD.
Old 4th July 2023, 19:13   #9122  |  Link
Boulder
Pig on the wing
Boulder's Avatar
I tried encoding one track from a Dolby UHD test disc to see if I can make Dolby Vision work on my TV and to test if it falls back to HDR10 when played in Kodi. I extracted the RPU using the demuxing script here in the forum and fed it to the encoder.
With
c:\x265\x265.exe --input inputfile.avs --input-depth 16 --dither --sar 1:1 --profile main10 --rc-lookahead 40 --min-keyint 5 --keyint 480 --splitrd-skip --colorprim 9 --transfer 16 --colormatrix 9 --master-display "G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(40000000,50)" --max-cll "1000,355" --frames 3576 --chromaloc 2 --hdr10 --hdr10-opt --repeat-headers --dolby-vision-profile 8.1 --dolby-vision-rpu "rpu.bin" --preset slower --crf 16 --output "dolby_test.hevc"
I got these errors:
Dolby Vision requires VBV settings to enable HRD.
Dolby Vision RPU count is greater than frame count in x265.
Well, I checked and the RPU is ok.
Adding --vbv-bufsize 999999999 --vbv-maxrate 999999999, I got the encode going so the complaint about the RPU file is a bug. The encode ran at Level 8.5
My question is: is VBV really necessary? Trying to add --no-hrd didn't do any good. I was thinking of patching the thing to skip that check if it's not needed. I know that I don't need it for my use and have never set it.
I could encode normally and just inject the RPU afterwards, but it would be easier and less diskspace consuming to do everything in one go.
Old 5th July 2023, 04:27   #9123  |  Link
Rousseau
What happened to the "Consecutive B-Frames" stats in the encode log? I just upgraded from Patman's 37 build to JPSDR's 103 build and it's gone. I tried john33's and djatom's binaries with the same result.
Rousseau is offline   Reply With Quote
Old 5th July 2023, 04:52   #9124  |  Link
TDS
Formally known as .......
TDS's Avatar
With
I got these errors:
Don't you have to provide the full path to the rpu.bin ???
This can be Very "TeDiouS"..
Long term RipBot264 user.
Ryzen 9 7950X
Intel i9-13900KF
Ryzen 9 5950X
Ryzen 9 5900X
Ryzen 9 3950X
Link to RB v1.27.0
TDS is offline   Reply With Quote
Old 5th July 2023, 08:56   #9125  |  Link
Boulder
Pig on the wing
Boulder's Avatar
It was lost at a recent commit for some reason.. IIRC quietvoid created a patch to get it back though.
Not needed if the file is in the folder where I launch the command line in. The same for "inputfile.avs".
Old 5th July 2023, 11:48   #9126  |  Link
quietvoid
As said above, it was removed.
The code can be added back with this commit: https://github.com/quietvoid/x265/co...a35be4377e390e
LG C2 OLED | GitHub Projects
quietvoid is online now   Reply With Quote
Old 5th July 2023, 16:57   #9127  |  Link
benwaggoner
It seems like VBV is important in your case !
I think it's always a good idea to set VBV to ensure compatibility with a given decoder. Just use --level-idc 5.1 and it will auto set reasonable values broadly compatible with UHD BD, Smart TVs, HW GPU decode, etc. 5.1 has a 40 Mbps peak, which is fine for 2160p24 content.
Ben Waggoner
My Compression Book
Old 5th July 2023, 19:37   #9128  |  Link
jpsdr
I checked the commit to put back "Consecutive B-Frames" in my moded version, unfortunately, there is big changes, and i don't realy know where and how put the histogram increment count...
My github.
Old 6th July 2023, 10:45   #9129  |  Link
madey83
Have you checked new updated Patman mode?
https://github.com/Patman86/x265-Mod-by-Patman/releases
madey83 is offline   Reply With Quote
Old 17th July 2023, 21:42   #9130  |  Link
LigH
LigH's Avatar
New uploads: x265 3.5+103-8f18e3ad3 / x265 3.5+104-47c18bf12 (might be identical, patch counting mistake or different branches?)
[Windows][GCC 13.1.0][32/32XP/64 bit] 8bit+10bit+12bit
New German Gleitz board
Old 29th July 2023, 08:13   #9131  |  Link
Boulder
Pig on the wing
Boulder's Avatar
I have a simple question regarding frametypes and chapter marks when using a qpfile. Does a chapter mark need an I-frame or is an i-frame enough? I'm using open GOP so setting 'K' in the qpfile would place i-frames in the encode.
Old 29th July 2023, 08:48   #9132  |  Link
LigH
LigH's Avatar
An IDR frame (Intra frame with Decoder Reset) is preferable. When you jump to an intermediate I frame which is not IDR (e.g. to encode a single frame very different from the surrounding video), you will get decoding artifacts from predictions skipping this I frame missing a reference.
Old 29th July 2023, 11:00   #9133  |  Link
LeXXuz
21 years and counting...
LeXXuz's Avatar
Oh darn. Thanks for mentioning that. Now I know why my players always jump a little before or after the specified chapter point. MeGUI sets 'K' as default for keyframes when creating qpfiles. I guess I'll better change those manually to 'I' from now on.
LeXXuz is offline   Reply With Quote
Old 31st July 2023, 06:40   #9134  |  Link
benwaggoner
Yeah, only IDR frames are guaranteed to be independently decodable.
Ben Waggoner
My Compression Book
Old 29th August 2023, 19:31   #9135  |  Link
jpsdr
Hello.
I've made a new build, and also include some new Patman updates.
As usual, check my github.
My github.
Old 1st September 2023, 20:05   #9136  |  Link
Barough
Barough's Avatar
x265 v3.5+108
https://www.mediafire.com/file/h8dmiufrc8al9oc/
Do NOT re-post any of my Mediafire links. Download & re-host the content(s) if you want to share it somewhere else.
Old 4th September 2023, 15:37   #9137  |  Link
Barough
Barough's Avatar
x265 v3.5+109
https://www.mediafire.com/file/ix5f9yr3fes7tpb
Old 13th September 2023, 15:59   #9138  |  Link
Barough
Barough's Avatar
x265 v3.5+110
https://www.mediafire.com/file/qbv4h1a20vxwf5i
Old 22nd September 2023, 03:50   #9139  |  Link
sainome
Question: If I specify --ctu 16, what should I specify for merange?
sainome is offline   Reply With Quote
Old 22nd September 2023, 23:05   #9140  |  Link
benwaggoner
They are orthogonal values, without much connection between optimum values. I'd stick with the one your --preset gives you unless you want to do a bunch of experimentation.
With --ctu 16 I suppose you could try --merange 41, which is 16 below the typical default of 57. It'd be a little faster, and depending on content might not raise bitrate or harm quality materially.
Ben Waggoner
My Compression Book
