Old 18th August 2009, 11:42   #1  |  Link
nitinpushpan
Checking Compressibility
Is it possible to check the compressibility in MeGUI? Just as in Gordian Knot's Compressibility Test. Also I'd really like to know how the compressibility test works and whether is it possible to do it manually.
nitinpushpan is offline   Reply With Quote
Old 18th August 2009, 11:44   #2  |  Link
buzzqw
HDConvertToX author
With MeGUI ?? don't know
for sure you can use it with staxrip and hdcconvertox
for megui you can manually add to avs script
selectrangeevery(280,14)
you will do a 5% encoding
after encding you can check the final size and make your comparison...
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
Old 19th August 2009, 08:30   #3  |  Link
nitinpushpan
So should I do a 2 pass or 1 pass?
Old 19th August 2009, 10:59   #4  |  Link
buzzqw
HDConvertToX author
usually 1 pass CRF, at 20
BHH
Old 23rd August 2009, 11:33   #5  |  Link
Forteen88
Herr
Be sure to use a frame-accurate decoder if you use selectrangeevery, because there might be a problem otherwise.
Forteen88 is offline   Reply With Quote
Old 23rd August 2009, 13:08   #6  |  Link
buzzqw
HDConvertToX author
DG tools are good
just dss is to blame
BHH
compressibility
