Old 27th October 2020, 14:21   #61  |  Link
SaurusX
Fantastic work on this. The results speak for themselves. Definitely improved quality when compared to SuperResXBR.
SaurusX is offline   Reply With Quote
Old 27th October 2020, 19:21   #62  |  Link
Alexkral
Thanks! I have managed to improve the VDSR models considerably, I will make a new release in the next few days.
AviSynth AiUpscale
Alexkral is offline   Reply With Quote
Old 28th October 2020, 10:23   #63  |  Link
ReinerSchweinlin
Nice Thanx for your efforts !
Old 30th October 2020, 04:47   #64  |  Link
Alexkral
AviSynth AiUpscale v1.1.0
Changes:
- Improved the VDSR models.
- Added new parameter to set the output bit depth.
- When the output is less than 16 bit, the conversion is now done on the GPU with ordered dithering.
- Alpha planes are now upscaled with Lanczos instead of being removed.
The VDSR models have been substantially improved for all scale factors after adjusting some training options. About the dithering, I honestly don't remember what I read that made me think that it wasn't good for this, but after doing some tests it is clear that this is not the case. So doing the conversion now on the GPU should mean a nice speed-up, more noticeable for the faster models.
Also, I have found that at least on my system there is a benefit when using four threads, so try using Prefetch(4) at the end of your scripts.
AviSynth AiUpscale
Old 1st November 2020, 07:36   #65  |  Link
gmail123
vdsr model:
AiUpscale1.01--SSIM Mean Y:0.9707451 (15.338db)
--PSNR Mean Y:40.994 U:49.153 V:49.248 Avg:42.249
AiUpscale1.10-- SSIM Mean Y:0.9709488 (15.368db)
--PSNR Mean Y:40.976 U:49.103 V:49.290 Avg:42.233
gmail123 is offline   Reply With Quote
Old 1st November 2020, 11:43   #66  |  Link
Alexkral
Set5 - Photo
1.5x
       Model              PSNR                SSIM
    ____________    ________________    _________________
    'VDSR-1.1.0'     40.303107806444    0.977076850531857
    'VDSR-1.0.1'    40.0231705258812    0.976284959358199
2x
       Model              PSNR                SSIM
    'VDSR-1.1.0'    37.0541978031766    0.957678515410715
    'VDSR-1.0.1'    36.6700956028294    0.955898000384579
2.5x
       Model              PSNR                SSIM
    'VDSR-1.1.0'    34.7290845636078    0.936933199722221
    'VDSR-1.0.1'    34.3833689195523    0.933502938036026
3x
       Model              PSNR                SSIM
    'VDSR-1.1.0'    33.0708644076159    0.914888194061316
    'VDSR-1.0.1'    32.7252438666527    0.910143847730622
3.5x
       Model              PSNR                SSIM
    'VDSR-1.1.0'    31.7451881124588    0.891913536377046
    'VDSR-1.0.1'    31.4385026528417    0.885549575366799
4x
       Model              PSNR                SSIM
    'VDSR-1.1.0'    30.6333993713215    0.868059737258679
    'VDSR-1.0.1'    30.3843028542906    0.861332075381644
Set5 - Illustration
1.5x
       Model              PSNR                SSIM
    'VDSR-1.1.0'    40.3110321290525    0.976887220812664
    'VDSR-1.0.1'    40.1070682034134    0.976346287794712
2x
       Model              PSNR                SSIM
    'VDSR-1.1.0'    36.9362257004149    0.956827635790212
    'VDSR-1.0.1'     36.631527053702     0.95544423942317
2.5x
       Model              PSNR                SSIM
    'VDSR-1.1.0'    34.3816642584093    0.933170040816044
    'VDSR-1.0.1'    34.1517733908771    0.931394422143814
3x
       Model              PSNR                SSIM
    'VDSR-1.1.0'    32.8355848241999    0.911281952451763
    'VDSR-1.0.1'    32.5152354802607    0.907160504583839
3.5x
       Model              PSNR                SSIM
    'VDSR-1.1.0'    31.4385026528417    0.885549575366799
    'VDSR-1.0.1'    31.1604700679502    0.881199445944243
4x
       Model              PSNR                SSIM
    'VDSR-1.1.0'    30.3683034245151    0.861417745548344
    'VDSR-1.0.1'    30.1770642431373    0.857356189888384
AviSynth AiUpscale
Old 13th January 2021, 16:51   #67  |  Link
Shinkiro
ConvertBits(16)
AiUpscale(Factor=4, Luma="HQ", Chroma="Lanczos", Width = 1920, Height = 1080, Double=0, Mode="Illustration", CPlace="MPEG2", OutDepth=16)
does not accept yuv420p16 as input I cannot understand why
Ryzen 2700x | ASUS ROG Strix GTX 1080 Ti | 16 Gb DDR4
Windows 10 x64 20H2
KD-55XE9005 | Edifier R2800
Shinkiro is offline   Reply With Quote
Old 13th January 2021, 23:45   #68  |  Link
Alexkral
Neither do I, it works fine here. That should only show up if the input is YV411 or 32 bits.
AviSynth AiUpscale
Old 17th February 2021, 09:01   #69  |  Link
kopmjj
Hi this looks like an interesting upscale feature
But I'm having trouble making this work, I put the avs and the other folder in plugins 64 but I dont know the basic script.
I'm trying to upscale DVD to 4k
Can someone show me a sample script to enter in my avspmod?
Just cant get my head round it. Thanks.
kopmjj is offline   Reply With Quote
Old 19th February 2021, 00:42   #70  |  Link
Alexkral
Which problem you have? You just need to use a factor equal to 4, and then use some interpolation method to get to 4K, something like this:
AiUpscale(Factor = 4)
LanczosResize(3840, 2160)
Note however that this will change the aspect ratio.
AviSynth AiUpscale
Old 19th February 2021, 02:40   #71  |  Link
kopmjj
hi thanks im getting the following error image attached.
what am i missing?
Old 19th February 2021, 20:06   #72  |  Link
kopmjj
ok looks like the photo upload doesnt work heres my script below, the error i get is there is no function named convertToshader
and the following error in aiupscale avsi in lines
341
217
228
239
DirectShowSource("C:\Users\king\Desktop\VID-20210125-WA0012.mp4")
Import("C:\Program Files (x86)\AviSynth+\plugins64+\AiUpscale.avsi")
LoadPlugin("C:\Program Files (x86)\AviSynth+\plugins64\AddGrainC.dll")
LoadPlugin("C:\Program Files (x86)\AviSynth+\plugins64\mvtools2.dll")
LoadPlugin("C:\Program Files (x86)\AviSynth+\plugins64\mt_masktools.dll")
LoadPlugin("C:\Program Files (x86)\AviSynth+\plugins64\RgTools.dll")
LoadPlugin("C:\Program Files (x86)\AviSynth+\plugins64\dfttest.dll")
LoadPlugin("C:\Program Files (x86)\AviSynth+\plugins64\aWarpsharpMT.dll")
LoadPlugin("C:\Program Files (x86)\AviSynth+\plugins64\nnedi3.dll")
LoadPlugin("C:\Program Files (x86)\AviSynth+\plugins64\TDeint.dll")
LoadPlugin("C:\Program Files (x86)\AviSynth+\plugins64\FFT3dGPU.dll")
LoadPlugin("C:\Program Files (x86)\AviSynth+\plugins64\fft3dfilter.dll")
LoadPlugin("C:\Program Files (x86)\AviSynth+\plugins64\gradfun2db.dll")
LoadPlugin("C:\Program Files (x86)\AviSynth+\plugins64\flash3kyuu_deband.dll")
LoadPlugin("C:\Program Files (x86)\AviSynth+\plugins64\Deblock-x64.dll")
Import("C:\Program Files (x86)\AviSynth+\plugins64\AiUpscale.avsi")
Converttorgb()
Old 19th February 2021, 21:25   #73  |  Link
poisondeathray
You need AviSynthShader, the .dll and .avsi
It's listed under the requirements
https://github.com/Alexkral/AviSynthAiUpscale
https://github.com/mysteryx93/AviSynthShader/releases
Old 19th February 2021, 22:38   #74  |  Link
kopmjj
thank you this worked.
now need to find out whats the best way to upscale dvd to 4k need to see what settings i need to enter.
is there anything else i need besides AiUpscale(Factor = 4) i will do the denoising and sharpening before ai upscale.
Old 20th February 2021, 01:07   #75  |  Link
Alexkral
You will probably find the result too sharp if you use the HQ Sharp model after sharpening the image, you could also try it instead. There are some performance results in the first post of this thread, and everything else is explained in the Github readme.
AviSynth AiUpscale
Old 23rd February 2021, 16:24   #76  |  Link
kopmjj
hi thanks for this, but no matter what i try my video is getting to sharp, doesnt look natural all i done was deinterlace the dvd, before using ai upscale, is there a setting to tone down the sharpness? tried fast setting but not much difference, also tried vdsr but no luck.
Old 23rd February 2021, 21:21   #77  |  Link
Alexkral
Try a factor = 3 or 2 and then some interpolation.
AviSynth AiUpscale
Old 24th February 2021, 12:09   #78  |  Link
ReinerSchweinlin
You could try a slight blurring afterwards, as well as adding some random noise - it helps to get a more natural look sometimes.
Old 28th March 2021, 03:09   #79  |  Link
Alexkral
AviSynth AiUpscale v1.2.0
Changes:
- Changed/Improved all models.
- Removed the VDSR models.
- Added Sharp versions of the Fast and Medium models.
- Removed the Double, Width and Height parameters.
- Added mpv user shaders of all models.
- Renamed the Illustration models to LineArt.
- Fixed: the mpv shaders didn't work properly with vs-placebo.
Now all models are based on FSRCNNX, with Global Residual Learning using Lanczos interpolation, and more layers and Local Residual Learning for the HQ models. I also trained some VDSR models with the processing done in the low-resolution space, obtaining the same results as the previous ones, but even those are outperformed by the new Medium models, so there's no reason to keep them. Also, the processing on the new HQ models is done entirely in the low-resolution space, so the arbitrary resize feature has been removed. I think it was handy, and I was using it myself for some things, but the traditional fractional upscaling method should give better results.
At this point, I think that considering the limitations of AviSynth Shader, there's not much room for improvement for the main application. The mpv shaders could still be greatly improved for use with some of the latest GPUs, but these are not yet available where I live, so that will have to wait.
AviSynth AiUpscale
Old 29th March 2021, 12:19   #80  |  Link
ReinerSchweinlin
Thanx !
