Go Back   Doom9's Forum > (HD) DVD, Blu-ray & (S)VCD > DVD burning
Old 15th January 2013, 19:16   #1  |  Link
unrox
Cannot copy Homeland
I have been tryin to make copies of Homeland,(bluray), I bought the first year. Got the first disk copied, the 2nd and third disk are
killing me, went thru about 8 disks, all good Verbatims. I tried to just get decrypted on AnyDvd and would no recognize either disk.I have
two burners tried both. The whole thing finishes and even has a good quality read. Then when put in the Blu ray player, nothing , tried it
on two players. BTW this was all in the BLU Ray copy mode. Using a 26G Verbatim in DVDFAB full movie.
unrox is offline   Reply With Quote
Old 15th January 2013, 21:38   #2  |  Link
setarip_old
setarip_old's Avatar
Have you checked for information at the DVDFab Forum?
setarip_old is offline   Reply With Quote
Old 15th January 2013, 23:11   #3  |  Link
Capsbackup
Why not try BD-RB instead of DVDFab if you are reducing the original Blu-ray from BD-50 to BD-25? Also, what software are you using to burn the BDMV/CERTIFICATE folders with? You should be using ImgBurn!
Both are free too.
Capsbackup is offline   Reply With Quote
Old 22nd January 2013, 17:08   #4  |  Link
Darksoul71
Can you blush ?
Darksoul71's Avatar
what happens if you play back the M2TS of the "ripped" BD on your PC ?
A BD standalone player is hardly a reasonable option to judge if things went right or wrong during ripping a BD.
Darksoul71 is offline   Reply With Quote
Old 22nd January 2013, 17:29   #5  |  Link
unrox
Both are free too.
Have both BD-Rb and Imgburn, both worked tried to burn on two different Blu Ray players and got nothing on one the other read cannot play this disk, have no problem with any other Blu-Rays, this is a set of three and same on all. Thanks
Old 22nd January 2013, 23:41   #6  |  Link
setarip_old
@unrox
Again - Have you checked for information at the DVDFab Forum?
Old 23rd January 2013, 03:48   #7  |  Link
unrox
Originally Posted by setarip_old View Post
@unrox
Yes , thanks, no help either,
Old 23rd January 2013, 07:30   #8  |  Link
Darksoul71
Can you blush ?
Darksoul71's Avatar
Also @unrox:
Do the M2TS files of your ripped BD play back fine on your PC when you play them with something like VLC ?
Also: Have you found and read this thread ?
http://forum.dvdfab.com/showthread.php?t=18595
Old 23rd January 2013, 15:40   #9  |  Link
unrox
Originally Posted by Darksoul71 View Post
Also @unrox:
Thanks for the reply, feels good to know it was not just me. In Oct. Fentango responded to the issue and was looking into it, but as yet has not given a
solution.
Old 24th January 2013, 02:46   #10  |  Link
setarip_old
@unrox
Glad to hear that you (eventually) followed my suggestion to check at the DVDFab Forum ;>}
