#661 | Link | |||
Good a reason as any I suppose.
Anyways, enjoy your pint. EDIT: Have another dozen pints and your brain will be 'as fresh as a daisy'. ![]() [strange saying, why would a daisy be so extra fresh ???] EDIT: Quote:
EDIT: Quote:
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 12th November 2022 at 20:27. |
#662 | Link | |
Banana User
![]() Looks like "Trim(SubEnd-SubStart+1,-1)" place was always OK and only introduced in v2.10, only this change there and nothing in the log. Probably I was testing something and forgot to change it back. Injustice is eliminated: Code:
# Version 3.3 : 2022/11/13. Corrected a code 'typo' in SubsMask2Img(), introduced in v2.10. Only side effect - the imprecise timestamps. Don't change anything to get the precise timestamps. |
#663 | Link |
Banana User
# Version 3.4 : 2022/11/24. New feature: "Greyscale" parameter, affects positive "Analyze", "Deblend", "Inpaint"... # Up to ~60% speed-up when enabled. # Prevents chroma changes on the greyscale videos by deblend [side effect of "3.1" fix]. # FFT3DFilter replaced by Neo_FFT3D, up to ~20% speed-up. Last edited by VoodooFX; 24th November 2022 at 17:20. |
#668 | Link | |
Banana User
What is your CPU usage when using Extract=-1? Mostly it runs 100% for me on all 4 cores. EDIT: Actually, ReExtract would work. Last edited by VoodooFX; 6th December 2022 at 01:27. |
#669 | Link |
9400f 6 core, 60%-70% most of the time, somtimes 100%.
If it will affect ReExtract option, then I should better upgrade my CPU to speed up the extration process for each instance. I don't really understand ReExtract though, I used ReExtract once, it does not affect the image even if I apply different paramaters from the previous extract=-1, only cuts half of the time. intermediate file is already appeared in black and white, so there is little use applying different masks designed for corlored images. Am I understand it correctly? Last edited by evafans; 6th December 2022 at 01:40. |
#670 | Link | |
Banana User
Then you wouldn't get much benefit running two jobs simultaneously, it would be only ~15% faster than running one job after another.
"InpaintDelogo(Extract)" is same as "InpaintDelogo().SubsMask2Img()" "InpaintDelogo(ReExtract)" is same as "SubsMask2Img()" |
#671 | Link | |
Hi, i can't delogo with this subtitles, can you help?? thanks
frame 28 ![]() scripts: Quote:
#672 | Link |
Banana User
There is some bug with inpainting a dynamic mask, introduced in v3.4, anyway your settings doesn't make sense, check your mask with "Show=4".
EDIT: Fixed in v3.5 Code:
# Version 3.5 : 2022/12/27. Fixed: Dynamic mask inpainting was broken since v3.4. Last edited by VoodooFX; 27th December 2022 at 14:29. |
#673 | Link | |
ok, i tweak and it's detect better but still can't desubtitles
Frame 28 ![]() scripts: Quote:
#674 | Link | |
Banana User
In your parameters you are setting the 3 masks but using only one, you need to mix all those masks with DynMask 2 or 3. |
#676 | Link |
Banana User
I think you don't understand what you are doing with those parameters, maybe the example below will help:
v=LWLibavVideoSource("D:\[ALEXANDROS] - Pray [1440x1080i MPEG2 SSTV HD].ts").TFM.TDecimate.Crop(0, 154, 0, -170).Addborders(0, 154, 0, 170).Trim(400,4599) x=v.crop(1260,194,-20,-194) # the mask by brightness: a=v.InpaintDelogo(Loc="1260,194,-20,-194", Show=4, DynMask=6, DynTune="110 - 155", DynTuneInf=1) # the mask by color: b=v.InpaintDelogo(Loc="1260,194,-20,-194", Show=4, DynMask=5, DynColor=$868185, DynColorTol=65, DynColorInf=2) # the mask by edges: c=v.InpaintDelogo(Loc="1260,194,-20,-194", Show=4, DynMask=7, DynTEdge=1, DynTEdgeThY=5, DynTEdgeInf=1) # the combo mask (mix of the 3 masks [a+b+c]): n=v.InpaintDelogo(Loc="1260,194,-20,-194", Show=4, DynMask=2, DynTune="110 - 155", DynTuneInf=1, DynColor=$868185, DynColorTol=65, DynColorInf=2, DynTEdge=1, DynTEdgeThY=5, DynTEdgeInf=1) # the combo mask temporaly refined by using 40 frames: m=v.InpaintDelogo(Loc="1260,194,-20,-194", Show=4, DynMask=3, DynTune="110 - 155", DynTuneInf=1, DynColor=$868185, DynColorTol=65, DynColorInf=2, DynTEdge=1, DynTEdgeThY=5, DynTEdgeInf=1, Dyn3Seq=40) # Inpainting the temporal combo mask [+DynInflate=1]: o=v.InpaintDelogo(Loc="1260,194,-20,-194", Show=0, DynMask=3, DynTune="110 - 155", DynTuneInf=1, DynColor=$868185, DynColorTol=65, DynColorInf=2, DynTEdge=1, DynTEdgeThY=5, DynTEdgeInf=1, Dyn3Seq=40, DynInflate=1) StackHorizontal(x.AddBorders(0,0,2,0,$F0F080).Subtitle("Original"), \ o.crop(1260,194,-20,-194).AddBorders(0,0,2,0,$F0F080).Subtitle("Inpainted"), \ m.ConvertToYV12.AddBorders(0,0,2,0,$F0F080).Subtitle("T. Combo mask"), \ n.ConvertToYV12.AddBorders(0,0,2,0,$F0F080).Subtitle("Combo mask"), \ a.ConvertToYV12.AddBorders(0,0,2,0,$F0F080).Subtitle("DynMask6"), \ b.ConvertToYV12.AddBorders(0,0,2,0,$F0F080).Subtitle("DynMask5"), \ c.ConvertToYV12.Subtitle("DynMask7")) ![]() Last edited by VoodooFX; 27th December 2022 at 17:05. |
#677 | Link | |
My edit script before your post. I think same same your
![]() Quote:
#678 | Link | |
Your settings still don't clean from frame 2276-2306
![]() Scripts: Quote:
delogo, hardsubs, ocr, remove, watermark |
