Old 26th January 2024, 10:33   #941  |  Link
color
color's Avatar
How do I do so it pull into from the left and right instead of all size?
Automatic Colorization
color is offline   Reply With Quote
Old 26th January 2024, 16:37   #942  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
I can't understand what you are asking.
Share your full avs script with masks and a video sample!
VoodooFX is offline   Reply With Quote
Old 26th January 2024, 20:38   #943  |  Link
color
color's Avatar
I can not share cause I don't know.
I want the it to pull the image => and <= not all sides. I think it was called "Pixel Aspect" in DeLogo.
Old 26th January 2024, 22:21   #944  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Still, I've no idea what "pull the image" or "=> and <= " means.
Share what you know.
There was something named like that, an useless arg doing practically nothing.
Old 27th January 2024, 08:53   #945  |  Link
color
color's Avatar
I don't know how to make it clearer, sorry....I do not want this when inpaint.
I want this:
I am editing a text in a movie and it has lines, so when using it and putting on a new text (another font that is not 100% same) does not good wwhen its like the first image, but much better if it can pull from left and right instead of all sides.
I wrote the same as my post and let chatGTP do explain it more clearly.
"I have a video with a logo that I want to remove using a delogo tool. The issue is that the current tool I'm using removes content uniformly from all sides, which doesn't look natural in my video. I'm looking for a delogo tool that can intelligently pull or stretch the background from the left and right sides, creating a more seamless and natural appearance."
For example, thats why I want to know how to make it pull from left and right instead of all sides, cause it does not look correct.
lets say this is original:
and lets say this is the text I want to add to it after "delogo"
but I need to pull from left to right instead of all sides, so it could look like this:
I need it to work with the mask to be even clearer, so I can not just put a square and pull together, then I will loose alot of image.
Old 27th January 2024, 09:27   #946  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Try Turbo=-1 or Turbo=-2 presets.
And if you want to block something from bottom and top then "crop" with Loc the video at those places.
Old 11th February 2024, 18:43   #947  |  Link
Guilbert
I'm having trouble OCRing the part of the sample I sent you, VoodooFX.
Can you please take a look?
Here is my parameters:
Loc="300,840,-300,-60", Show=4, DynMask=4, DynMask4H=150, DynTune=180, DynMaskUp=2, SubMinDur=4, FourCC="X264"
Guilbert is offline   Reply With Quote
Old 11th February 2024, 19:09   #948  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Your parameters doesn't work or the sample is wrong. Post the working ones.
Old 11th February 2024, 20:11   #949  |  Link
Guilbert
Okay, it's because I used LanczosResize(1920, 1080).
Here is the parameters:
Loc="300,560,-300,-40", Show=4, DynMask=4, DynMask4H=150, DynTune=180, DynMaskUp=2, SubMinDur=4, FourCC="X264"
(I sent you another sample.)
Old 11th February 2024, 22:29   #950  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
You won't get rid completely of the titles behind the subtitles.
Try this:
InpaintDelogo(Loc="300,570,-300,-50", Show=4, DynLocUp=2, DynMask=3, Dyn3Seq=20, DynTune=160, DynTEdge=1, DynTEdgeThY=50, DynTEdgeInf=4, KillNoise=5, KillBlobs=-5, Extract=-1, CorrTh=0.7, ImgDir="D:\img")
Old 11th February 2024, 23:51   #951  |  Link
Guilbert
Strangely, no images were extracted (on the whole movie).
Old 11th February 2024, 23:56   #952  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
It extracted all subtitles from your sample.
Old 12th February 2024, 00:09   #953  |  Link
Guilbert
Indeed. Thank you, it helped a lot!
Old 14th March 2024, 11:27   #954  |  Link
HeinrichI
Hello. Can you give me some advice? Launched analysis by command:
InpaintDelogo( mask="Unfabulous\Unfabulous.bmp", Automask=1, Loc="450,0,150,174")
4 files were created:
But when I run the preview after, with the command
InpaintDelogo( mask="Unfabulous\Unfabulous.bmp", Loc="450,0,150,174", Mode="Deblend") then instead of removing the logo, colored spots appeared:
The logo itself:
HeinrichI is offline   Reply With Quote
Old 14th March 2024, 13:27   #955  |  Link
kedautinh12
You need show your mask image
Old 14th March 2024, 13:46   #956  |  Link
HeinrichI
Unfabulous.bmp:
Unfabulous_AutomaskTemp_A2.bmp:
Attachments Pending Approval
File Type: zip Unfabulous.zip
Old 14th March 2024, 14:07   #957  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
ebmp file is not created by Automask=1.
Because logo is not transparent, so there is nothing to deblend.
Old 14th March 2024, 14:52   #958  |  Link
kalehrl
Any advice how to create a mask for this kind logo:
It is faint and the resulting automask is no good because I just get a jumbled mask like this:
I used this command:
InpaintDelogo(mask="D:\Videos\Encodes\output3.bmp", Automask=1, Analyzeth=70, Loc="1800,908,-36,-0", Mode="Inpaint")
kalehrl is offline   Reply With Quote
Old 14th March 2024, 14:57   #959  |  Link
HeinrichI
How to create ebmp? I still donít understand it from the description in the script.
The logo is still slightly transparent, as you can see in this shot.
Old 14th March 2024, 15:18   #960  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
It's created automatically by analysis on the first deblend delogo run.
Probably not transparent enough for video compression level. Or maybe you are doing something wrong.
delogo, hardsubs, ocr, remove, watermark
