Old 8th January 2014, 00:40   #21  |  Link
Originally Posted by pistacho View Post
Coming soon also 2D video supported => VC1, AVC, MPEG2 decoder...
With robust frame accuracy, correct pulldown handling, etc.? What supported input container formats? Output to AVCHD only? Avisynth source filter? Inquiring minds want to know.
Old 9th January 2014, 10:55   #22  |  Link
pistacho
The idea is to keep it as simple and fast as possible.
Decoding 2D VC-1, AVC, MPEG2 is just an added bonus.
Since no seek is allowed, the frame served is always the next. But yes, it is robust!
Input only elementary streams and the ouput is raw YV12 (is only a decoder)
pistacho is offline   Reply With Quote
Old 9th January 2014, 13:50   #23  |  Link
Thanks. No threat to DGSource() then.
Old 19th January 2014, 12:04   #24  |  Link
WBL
tried to load a MVC file created by Panasonic Z10000 - I get an error 'Invalid or not supported stream header' - but the MVC file from this 3D camcorder is correct and valid (e.g can be loaded without problem in Sony Vegas Pro)
greetings
Werner
WBL is offline   Reply With Quote
Old 19th January 2014, 17:29   #25  |  Link
pistacho
greetings
Werner
As we have commented in the other thread, only elementary streams are allowed as input.
I guess the camcorder produces .ts or .m2ts container.
Old 16th February 2014, 19:57   #26  |  Link
pistacho
Test version
v2.1.1 (test version)
- Updated to Intel Media SDK 2014.
- Load libmfxsw32.dll from same folder as MVCsource.dll (no system path required)
- Some code optimizations and speed improvements.
- Workaround to fix corrupted frames in some streams (e.g. Pacific Rim – root cause seems Intel Media SDK bug)
=> MVCsource_v2.1.1.rar
More info about "Intel Media SDK bug" here:
http://forum.doom9.org/showthread.ph...68#post1668668
Old 16th February 2014, 20:41   #27  |  Link
Since you have followed my lead on this feature, may I please know what you did for this:
Thanks!
Old 18th February 2014, 09:39   #28  |  Link
pistacho
The key is the version of sample_decode.exe that uses ssifSource v4.1 (by slavanap).
But not for the changes introduced by slavanap but the version is earlier than that are based all other decoders (FRIM, DGMVC and mine).
The workaround therefore is to use Intel Media SDK 2013 instead of 2013 R2 and use the sample code in this release. Unfortunately the Intel sample code (all versions) is plenty of bugs and poorly optimized (apparently done by interns) but this is another issue. Anyway, once compiled, the fix is still maintained using libmfxsw32.dll from SDK 2013 R2 or even SDK 2014.
But as I said in another thread, this is not a real solution because the bug is still there and can only be solved entirely by Intel.
As for the sample code "sample_decode.exe", I try to avoid everything possible for the reasons I mentioned (I made a complete refactory) and that is why my plugin (for now) is that it consumes less RAM/CPU and has a much larger throughput that others.
I've got ~700 fps on HW in the latest test version
Old 18th February 2014, 15:21   #29  |  Link
Thanks, that's very interesting, especially claims of 700fps decoding! Would you be willing to share any of the architectural changes that led to that?
Old 19th February 2014, 19:14   #30  |  Link
Thalyn
Hmm... I grabbed 2.1.1 and tried to run the Pacific Rim fragments through it, but I got the same errors as before. Is that perhaps a bad upload (ie the wrong file), or is it that I'm using hardware decoding (as I suspect) that's causing the problem?
Thalyn is offline   Reply With Quote
Old 19th February 2014, 21:27   #31  |  Link
Nico8583
pistacho said bug is still present in HW mode :
At the moment, I do not know the exact conditions that have to give, but I found a way that seems to solve the problem in SW mode. It is a "workaround" because I do not think it can be a long-term solution and the bug is still present in HW mode.
Have you tried to force SW (if it's possible) ?
Nico8583 is offline   Reply With Quote
Old 20th February 2014, 04:10   #32  |  Link
Thalyn
There's no way, that I know of, to force software mode through MVCSource. At least it hasn't been documented if it exists.
Old 20th February 2014, 05:21   #33  |  Link
allanlee
It's mentioned here
Since MVCsource has not an explicit param. to force hw/sw decode, to ensure SW is used and workaround fix is "active" you can rename temporally Intel Quick Sync driver location e.g.:
C:\Program Files\Intel\Media SDK to C:\Program Files\Intel\_Media SDK_
allanlee is offline   Reply With Quote
Old 20th February 2014, 05:41   #34  |  Link
Thalyn
Well, I'll just sit in the corner and be silent. Feel free to provide a dunce cap.
*ed: It's still not right. It doesn't glitch, but the same scenes are still missing frames in the same place. In the Pac1 short clip there should be additional frames between 71 and 72 - roughly 45 of them judging by when the scene blanks at the end. This puts the audio significantly out of sync (almost 2 seconds). I haven't studied Pac2 closely but I imagine it's much the same again.
Demonstration time:
CoreAVC (via DirectShowMVCSource)
Intel Media (via MVCSource)
Both streams are produced via MKVMerge, set to split out frames 95,000 to 95,499, with the only difference being the video source. Yes, I realise they're both only 472 frames and not 500 but that's MKVMerge's doing - at least it's consistent. The only other variation is in the x264 settings used but that has no relevance.
Old 1st March 2014, 12:46   #35  |  Link
pistacho
I have not gone back to spend more time on this matter. But I'm beginning to suspect that the problem could simply be the source (bad source).
In any case, the workaround is based on which has reported that ssifSource4.1 solved the problem. The MVCsource workaround produces the same output as ssifSource4.1.
Therefore, if it turns out that this version of the MVCsource not fix the issue, ssifSource4.1 either.
But we are talking that this is a fault in a single scene of a single Blu-Ray. It seems logical that if there really it’s an Intel decoder bug, should affect more sources...
Old 4th October 2014, 15:56   #36  |  Link
pistacho
Version 2.2.1 (10/04/2014)
  • Updated to Intel Media SDK 2014 R2.
  • Some decoder throughput improvements (both HW and SW decoding).
BENCHMARK:
Quick Sync decoding
Software decoding
For more deatails see first post...
Old 13th October 2014, 09:34   #37  |  Link
Nico8583
Does the new Intel Media SDK 2014 R2 resolve the bug from Pacific Rim ?
Thanks !
Old 13th October 2014, 19:43   #38  |  Link
pistacho
Originally Posted by Nico8583 View Post
Thanks !
Nope!
Old 14th October 2014, 07:38   #39  |  Link
Nico8583
Nope!
Ok, thanks
Old 23rd October 2014, 12:33   #40  |  Link
Nico8583
Hi, another question : have you tried your plugin with a new Intel CPU and last Intel Media SDK ? It seems there are bugs with new Intel CPU and hardware acceleration, for example with Intel Haswell Refesh (Core I5 4590S), if we use the lastest Intel Media SDK. We don't know if it's a problem with our decoder or with Intel DLL.
Thanks !
mvc decoder, mvcsource, sbs, tab
