Go Back   Doom9's Forum > Capturing and Editing Video > DV
Old 6th May 2023, 21:06   #1  |  Link
cypher007
best way to capture DV and analogue?
currently im using an old DV camcorder and firewire card as a capture device from an svhs deck to pc.
is there a better way to capture these old tapes? and maybe some newer software as i think im using windv at the moment.
cypher007 is offline   Reply With Quote
Old 6th May 2023, 21:58   #2  |  Link
lollo2
lollo2's Avatar
A better way is to capture your analog S-VHS/VHS tapes in YUV 4:2:2, 8bit, lossless (HuffYUV or similar), using a specific analog capture card.
AmarecTV is the best analog capture software.
A channel on S-VHS / VHS capture and AviSynth restoration https://www.youtube.com/channel/UCMs...h1MmNAs7I8nu4g
lollo2 is offline   Reply With Quote
Old 3rd August 2023, 12:19   #3  |  Link
Orikson
If you are familiar with the german language or you can get it done with a translator, there is a great tutorial: https://gleitz.info/forum/index.php?...en-und-andere/
I personally am using a Canopus Edius NX PCIe card, as this specific card has a ProcAmp on board which might be usefull for some tapes.
Before that, I also used a digital8 camcorder which was connected via firewire. The quality was absolute crap, compared to the method in the link
Orikson is offline   Reply With Quote
