Go Back   Doom9's Forum > Video Encoding > (Auto) Gordian Knot
Old 15th January 2012, 00:25   #1  |  Link
znelbok
AGK, Win7 and Range Check Error
Hi all
i recently loaded AGK 2.27 onto my Win 7 PC and I get teh following error
[15/01/2012 8:41:15 AM] Source resolution: 720x576
[15/01/2012 8:41:15 AM] Found PAL source.
[15/01/2012 8:41:15 AM] Source aspect ratio: 16:9
[15/01/2012 8:41:15 AM] Analyzing source.
[15/01/2012 8:43:02 AM] Source is considered to be progressive.
[15/01/2012 8:43:02 AM] Output will contain 147211 frames
[15/01/2012 8:43:02 AM] Running single pass encoding.
EXCEPTION: Range check error
[15/01/2012 8:43:02 AM] Job finished. Total time: 2 minutes 24 seconds
I have it installed on an older Win Xp machine and it works fine.
I have read that an uninstall and re-intall i supposed to work, but it has not for me.
Does anyone have any clues on how to fix this.
(Don;t sugest an upgrade. For various reasons an upgrade is not possible). Others have reported that this version working fine on W7.
Mick
znelbok is offline   Reply With Quote
Old 16th January 2012, 13:23   #2  |  Link
hello_hello
I don't have an answer and I won't suggest an upgrade but I can't help my curiosity.... why are you forced to use an old version?
