Old 23rd May 2020, 17:15   #121  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
Originally Posted by Funky080900 View Post
First denoise the video
ffmpeg -i ToS.y4m -vf nlmeans=s=1.5 denoised.yuv
Then use the noise_model application located under ./examples/noise_model: https://aomedia.googlesource.com/aom.../noise_model.c
noise_model --fps=24/1 --width=1920 --height=800 --i420 --input-denoised=denoised.yuv --input=ToS.yuv --output-grain-table=film_grain.tbl
I only kept sY sCb and sCr because the generated .tbl didn't look good.
well I read this paper:
https://norkin.org/pdf/DCC_2018_AV1_film_grain.pdf
In fact I think that you must encode denoised.yuv and FGM will add grain after stream decoding.
It's logical because if you use FGM at medium/high bitrate with noisy source, codec will able to retain noise and FGM will add more noise at this same encoding natively noised.
The good way seem to be:
aomenc --passes=2 --pass=2 --fpf=firstpass.log --target-bitrate=1220 --kf-max-dist=120 --cpu-used=0 -t 4 --deltaq-mode=2 --film-grain-table=film_grain.tbl -o AV1-0.ivf denoised.yuv
I will try that. Where I can find compiled noise_model.exe ?
Le Sagittaire ... ;-)
1- Ateme AVC or x264
2- VP7 or RV10 only for anime
3- XviD, DivX or WMV9
Old 23rd May 2020, 17:40   #122  |  Link
Tadanobu
Here is one https://drive.google.com/open?id=1T3...Lwkx9tmnqaTCyj
Built for Windows 2 months ago.
Tadanobu is offline   Reply With Quote
Old 24th May 2020, 19:44   #123  |  Link
benwaggoner
The task of denoising with parameterization so the noise can be reconstructed is a tricky one. And doesn't need to be normative in an encoder, so they punted that part?
Ben Waggoner
My Compression Book
Old 29th May 2020, 22:49   #124  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
Is it reasonable to generate the grain table with a heavily denoised reference, yet do the actual encoding with a more gently denoised clip?
I've found that getting full grain elimination using tools like SMDegrain or KNLMeansCL requires some pretty heavy handed settings, which can result in the plastic face effect. The grain synthesis is really nice, but I'd like to dial back the denoising strength when actually encoding a bit.
Old 29th May 2020, 23:16   #125  |  Link
benwaggoner
Sounds like a worthy experiment. I can imagine that the grain at playback could wind up being more intense than in the source if the grain table is based assuming more grain was removed than actually was.
Ben Waggoner
My Compression Book
Old 30th May 2020, 03:34   #126  |  Link
quietvoid
Yes, that is a good way of doing it. That way it's helping the encoder, but it's probably doing a filter pass either way so more detail might get wiped in the actual encode (maybe).
It's at least better than leaving aomenc do the denoise and the grain modeling at the same time, because it's using very basic denoise methods.
quietvoid is offline   Reply With Quote
Old 12th October 2020, 01:29   #127  |  Link
H2sixty
Not a Registered User
H2sixty's Avatar
how was the source file created?
H2sixty is offline   Reply With Quote
Old 12th October 2020, 09:05   #128  |  Link
excellentswordfight
Lost my old account :(
https://mango.blender.org/about/
https://media.xiph.org/tearsofsteel/
excellentswordfight is offline   Reply With Quote
Old 12th October 2020, 12:40   #129  |  Link
H2sixty
H2sixty's Avatar
Originally Posted by excellentswordfight View Post
benwaggoner's file is not listed there, and it says dithered in his download file name. i assume its a dithered copy made from the website file...
Old 12th October 2020, 17:01   #130  |  Link
benwaggoner
Yes, I rendered it out from the 4K 16-bit PNG files.
IIRC, I went from those to uncompressed v210 in After Effects, and then used FFMPEG for the final conversion to yuv420p .y4m, using xdither.
Ben Waggoner
My Compression Book
Last edited by benwaggoner; 12th October 2020 at 17:16. Reason: Specified color space
Old 7th December 2020, 18:06   #131  |  Link
benwaggoner
Thanks for the 2 Mbps AV1. Could you also try a 1 Mbps and a 500 Kbps? We've got samples at those rates in other codecs.
Ben Waggoner
My Compression Book
Old 25th April 2021, 20:01   #132  |  Link
easyfab
First try with VVC codec and vvencapp codec (Fraunhofer Versatile Video Encoder )
tos.266 -> https://www.sendspace.com/file/qk2ko0
vvencapp -i ToS_1920x800_xdither.yuv -s 1920x800 -r 24 --preset fast -q 29 -o tos.266
Total Frames | Bitrate Y-PSNR U-PSNR V-PSNR YUV-PSNR
17620 a 912.8453 52.1495 59.0134 58.8494 40.7851
Total Time: 5167.89 sec. Fps(avg): 3.40952 encoded Frames 17620
I don't know a player that decode vvc, I'm using vvdecapp + mpv to play it for the moment :
vvdecapp -b tos.266 -o - | mpv.com --demuxer=rawvideo --demuxer-rawvideo-w=1920 --demuxer-rawvideo-h=800 --demuxer-rawvideo-mp-format=yuv420p10le --demuxer-rawvideo-fps=24 -
or to use with ffmpeg to do what you want :
vvdecapp -b tos.266 -o - | ffmpeg -f rawvideo -s 1920x800 -r 24 -pix_fmt yuv420p10le -i - ....
Here a build of vvcdecapp for those who don't want to build the source : https://www.sendspace.com/file/uhc8j6
easyfab is offline   Reply With Quote
Old 28th May 2021, 22:48   #133  |  Link
dipje
Any new link? MSVC 2019 build-tools are installing, but finding a compiled version to play around with will make life easier :s.
dipje is offline   Reply With Quote
Old 3rd June 2021, 22:29   #134  |  Link
benwaggoner
I've finally added a new source for the challenge, an interesting hybrid anime/CGI title. Links and details in the updated first post.
It's got some very different properties from Tears of Steel that should stress different encoder features. I look forward to seeing what we all can do with it!
Ben Waggoner
My Compression Book
Old 7th June 2021, 20:19   #135  |  Link
benwaggoner
Here's my first test encode, at 1 Mbps ABR.
https://1drv.ms/v/s!AlvIQZWsyeO-k9ly...a-TPQ?e=baJVUi
Even though a ton of its runtime is just white text/graphics on black, it's still a MUCH harder clip to encode than Tears of Steel. Perhaps something could be done with --zones to further save bits from the credits sections to help the hard bits.
I've not done any actual tuning with the parameters. I just did a 2-pass placebo with --tune animation and throwing in a bunch of other features that would hopefully help with this kind of content. So --cu-lossless and --tskip for all the very sharp lines in the text
I did a simple --tune animation --preset slower without the fancy stuff and quality and bit distribution came out pretty much the same; just a hair lower . Which confirms the extra stuff didn't cause some qualitative regression. As expected, 20x faster with -1.5 dB PSNR and -0.22 dB SSIM.
Looking at the .csv log file, it seems that --frame-dup didn't actually set any frames to dup. so raising the threshold there might be helpful. Maybe the dithering added just that extra bit of noise?
I'm not sure if --tune animation is appropriately tuned either. I fear that preset is exactly copied from an email I sent a x265 dev extrapolating a starting point for tuning a --tune animation, and I know I didn't do adequate testing of it .
I doubt this is a clip that particularly benefits from --hme either.
I should also try --hevc-aq for comparison.
x265.exe --input SolLevante_SDRv2_1080p24_8bit.y4m --level-idc 4.0 --preset placebo --pass 1 --ref 5 --bframes 16 -F 1 --hme --hme-search 2,3,4 --fades --frame-dup --tune animation --tskip --cu-lossless --rd-refine --multi-pass-opt-analysis --multi-pass-opt-distortion --keyint 120 --rc-lookahead 120 --bitrate 1000 --vbv-maxrate 12000 --hrd --aud --vbv-bufsize 12000 --colorprim bt709 --transfer bt709 --colormatrix bt709 -o SolLevante_SDR-1080p_1000_placebo_p1.hevc --psnr --ssim --csv-log-level 1 --analysis-reuse-file SolLevante_SDR-1080p_1000_placebo.dat --stats SolLevante_SDR-1080p_1000_placebo.stats --csv SolLevante_SDR-1080p_1000_placebo_p1.csv
x265.exe --input SolLevante_SDRv2_1080p24_8bit.y4m --level-idc 4.0 --preset placebo --pass 2 --ref 5 --bframes 16 -F 1 --hme --hme-search 2,3,4 --fades --frame-dup --tune animation --tskip --cu-lossless --rd-refine --multi-pass-opt-analysis --multi-pass-opt-distortion --keyint 120 --rc-lookahead 120 --bitrate 1000 --vbv-maxrate 12000 --vbv-bufsize 12000 --hrd --aud --colorprim bt709 --transfer bt709 --colormatrix bt709 -o SolLevante_SDR-1080p_1000_placebo_p2.hevc --psnr --ssim --csv-log-level 1 --analysis-reuse-file SolLevante_SDR-1080p_1000_placebo.dat --stats SolLevante_SDR-1080p_1000_placebo.stats --csv SolLevante_SDR-1080p_1000_placebo_p2.csv
Ben Waggoner
My Compression Book
Old 7th June 2021, 22:05   #136  |  Link
rwill
Your rules state:
4 Mbps peak bitrate
You specified:
--vbv-maxrate 12000
Old 8th June 2021, 17:59   #137  |  Link
benwaggoner
Originally Posted by rwill View Post
Your rules state:
4 Mbps peak bitrate
You specified:
--vbv-maxrate 12000
Crap! Good catch. Will fix .
Ben Waggoner
My Compression Book
Old 9th June 2021, 01:23   #138  |  Link
videoh
Useful n00b
Why is this thread a sticky? Is it to spam your obsolete book? Just wondering.
Old 9th June 2021, 06:32   #139  |  Link
rwill
What is this forum for anyway ?
To advertise x265 binary builds no one runs ?
A place for foreign students to get their university multimedia assignments solved without the need to do any work ?
Another place for trolls to unleash their time wasting and irritating nonsense posts ?
Now regarding this encoding challenge I could post some Sol Levante encode like this which is quite different from Bens:
https://drive.google.com/file/d/16ya...ew?usp=sharing
And then people would take a look and compare and discuss and whatnot.
But no, people nowadays are more interested to post pictures on Insta and toxic one liners on Twitter. Makes no sense to do an encoding challenge with most people on this BBS anyway as everyone only has access to x265 which is a broken encoder. Encoding the sequence in high quality AV1 will take a year and other OSS encoders are still in their infancy. And I get an aneurysm every time I see someone doing encodes at a medium like preset and then still complains about encoding speed because in their opinion it runs too slow on their 15 year old 4 core SSE2 CPU.
Old 9th June 2021, 18:56   #140  |  Link
benwaggoner
If y'all don't like Doom9, you're welcome to not participate, or suggest a better place for these kinds of discussions.
We've had a variety of tests in this challenge provided in a variety of codecs and encoders.
Ben Waggoner
My Compression Book
